Page 2499 of 2776 FirstFirst ... 1499199923992449248924972498249925002501250925492599 ... LastLast
Results 37,471 to 37,485 of 41626
  1. #37471
    Post the pipe.
    Sorry Wob, this one, and thanks for your great reply.
Name:	RS125 - 800.jpg
  2. #37472
    What was the pipe called , was the EngMod project name up at the top.
    If I get a dull moment I will update it for you.
  3. #37473
    Can't see a name anywhere. Here are the EngMod details
Name:	RS125 - 800 - Spec.jpg
  4. #37474
    3rd August 2012 - 02:39
    yzf 250
    holland
    Dutchpower, this is a pipe you've tested?
    I'm aiming for a tuned length of 820, starting at 35mm with a shallower header than the original drawing.
    I have partial measures of a HGS pipe and probably a standard somewhere, are you asking to see those numbers?
    Forget the 35 we go to 36 and lost lots of hp
    Here you got new exh.
  5. #37475
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    I'll test it.
    You built this in Engmod, or tested on track?
    And it's for the powervalve yz85?
  6. #37476
    yzf 250
    holland
    I'll test it.
    Both track and dyno
  7. #37477
    sweden
    Both track and dyno
    Ok, great, looking forward to test it. How do you face it to the duct, it's smaller than 38mm right?
  8. #37478
    yzf 250
    holland
    You can make it bigger is also oke
  9. #37479
    sweden
    I mean, the cylinder exit on the yz is close to 35mm, I believe. How do you join them?
  10. #37480
    After 40 years of pipe building using Dynamation , then Mota , then EngMod I have never seen anything make good power with a 1.8* header , nor a 12*/30* tailcone ?
    Sure its good to try things that have never been done before , but weird is still weird at the end of the day.
    Its like " Stuffing " telling everyone our headers and diffusers should be 34%/68% - never seen one , never built one - why would I , the code says its shit every time.
  11. #37481
    yzf 250
    holland
    Make it better Wobb and help ( andrea ) maybe I can learn something after 50 years of making exh.
  12. #37482
    Send the .pack to wobblywayne8@gmail.com.
    Its impossible to optimize any pipe in isolation.
  13. #37483
    sweden
    It's fine. Anyway I don't have the data.
    Fitted v-force today, with positive report.
  14. #37484
    23rd July 2017 - 21:59
    n/a
    canada
    Hi there .
    Why did you make them (pipe) in section rather than hydroform?
  15. #37485
    sweden
    Simply, was never acquainted to that method.
