Page 2501 of 2775 FirstFirst ... 1501200124012451249124992500250125022503251125512601 ... LastLast
Results 37,501 to 37,515 of 41611
  1. #37501
    3rd August 2012 - 02:39
    yzf 250
    holland
    Erv Kenemoto
ID:	351968   Click image for larger version.
  2. #37502
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Hibernation mode, also reverting back to 0.7 sheet (what was I thinking?)
    Corr typo in the first drawing mid section length.
ID:	352025   Click image for larger version.
ID:	351971   Click image for larger version.
ID:	351972   Click image for larger version.
ID:	352022   Click image for larger version.
ID:	352020   Click image for larger version.
  3. #37503
    sweden
    I did some speculating regarding the advantages of the the increasingly converging baffle. I'm not sure if the reasoning conveys from the scribblings, but being the baffle has a restricted useful length before possitive effects of the furthest part is eaten up by the part that is still in the 2/3 dip.
    So it might be that the wave profile is the key, more suitable for pushing fresh mix, and is better tailored to fit the regime.
ID:	351979   Click image for larger version.
  4. #37504
    Having a 3 angle increasing convergence gives an asymmetric amplitude return wave form.
    Having the steepest portion at the furthest point from the piston , gives an increasing return pressure wave as the piston is closing the port - exactly what is needed for extracting all the remaining energy.
    This will generally increase peak and overev power .
    A one piece steep cone will give more peak , but the then it drops dramatically after peak - and looses front side power.
    The 3 angle can easily be tuned to give more power everywhere.
  5. #37505
    sweden
    Note taken.
  6. #37506
    13th September 2009 - 03:15
    all of em
    Oklahoma USA
    There was talk of the Mikuni or Keihin carbs with full length needle jets to top of bore with a series of tiny holes the whole length. It makes me visualize an even spray of fuel thats somehow better than just spewing up from the bottom. This video of FCR's on a Ducati at 33,000 frames per second tells me carbs work work pretty good already. Alex at 2T stuffing might get some good information with a high speed camera looking down the carb like this
    https://www.youtube.com/watch?v=9KSc_KNGKYg
  7. #37507
    I have seen fast frame video's of a Lectron/Mikuni and a SmartCarb/Fuel Injection.
    Seems one of the reasons the carbs that use a needle with a flat on the engine side work so well , over a wider range of weather , is they atomize the fuel droplet size much smaller.
    EDIT - those fuel droplets in the FCR's are huge.
    The idea of a hollow needle with a multiple series of vertical holes is in fact no better at atomization than the normal emulsion tube/needle , with or without a shroud for main jet air correction.
    Its been done several times , including pumper carbs.
    I haven't seen video of that , but the dyno doesn't lie.
  8. #37508
    sweden
    Party at local shop. TM 450 and 89&93 Honda CR 500.
ID:	351996   Click image for larger version.
ID:	351989   Click image for larger version.
ID:	351997   Click image for larger version.
ID:	351992   Click image for larger version.
  9. #37509
Name:	3rd in F5.png
    Third place in New Zealand F5 (50cc Bucket) Road Race championship.
    There were plenty of other faster riders but I rode and finished all the races in the series. Preparation and consistency beats faster talent to the podium once again.
Name:	Hare and tortoise.jpg
  10. #37510
    Quote Originally Posted by edgefinder View Post
    this is a promo shot of Yoshimura MJM
    it also seemed to be a bit of a gimmick.
    It seems to make odd farty noises.
Name:	3rd in F5.png
    Congrads Rob..
  11. #37511
    We have a MJM carb on one of the RG50's. No more power but it seemed to throttle better than the standard needle/needle jet carb. We liked it. It got past the power dip better than the std OKO carb. The improved throttle response made this one a keeper for us. From experience we know that what works on one engine may not be great on another so we keep an open mind. Best by Test.
  12. #37512
    Congrads Rob..
    And I always thought the fuel was meant to go into the engine...
  13. #37513
    Well sometimes it seem that airfuel mixture goes 2 or 3 times past the mainjet.....
  14. #37514
    Sinply out of curiosity, how does the very early TD pipe with effectively a part - spherical end cone align with this ? Certainly the steepest portion is at the furthest point from the piston, if nothing else.
  15. #37515
    One of the first pipes to use the increasing angle idea were early KT100 Yamaha versions that were developed when centrifugal clutches became the rage.
    It turned out the best of these used a parabolic shape that was spun on a mandrel.
    That TD cone had me fucked for years trying to understand what chemicals were involved in its development.
