Page 2505 of 2776 FirstFirst ... 1505200524052455249525032504250525062507251525552605 ... LastLast
Results 37,561 to 37,575 of 41632
  1. #37561
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Quote Originally Posted by Peljhan View Post
    I did tune a 90cc moped some time ago and measure it on dyno and now I am working on simulating it in EngMod.
    Would Wobbly, Vannik or someone with more EngMod experience know, how can I better align curves to have a good base line for optimising the engine for further tuning?
    https://www.vannik.co.za/download/En...on Results.pdf
  2. #37562
    28th October 2018 - 06:30
    Tomos D6, Cagiva Mito
    Idrija, Slovenia
    Way too many unknown variables to give any reasonable answer.
    I will PM with my contact email.
    Thanks Wob. I have you email. You helped me few times allready (thanks ), but in spirit of Frits, I think it's better to ask here so others can see and also learn. And I don't want to bother you too much
    Thanks Vannik, this document will be good for now. I allready reduced pipe wall temp, it helped a bit. Will try also lambda, exhaust duct temp change and efficiency. Is turbulent run needed after lambda change or can proceed with burnrate prescribed directly after change?
    I lost count how many times my friends had problems with Ignitech. I went with Zeeltronic for my Cagiva Mito and freetech 50cc bike. It worked awesome on Cagiva, 50 is still not finished.
    I was trying to roll exhaust on 40mm straight rollers. At the end it was easier to hammer each on piece of steel bar. And used hydroformed header pipe. Still waiting for dyno comparison with coned vs. hydroformed header.
    Wob, in what units is your 3 something gas flow when TIG welding?
ID:	352101   Click image for larger version.
ID:	352102   Click image for larger version.
  3. #37563
    TeeZee , if you look down inside the coil plug holder with the two connector blades sticking up , you will see they are marked +/-
  4. #37564
    Needed a torch and my glasses but found it. Thanks Wob.
  5. #37565
  6. #37566
Name:	The Good Oil.jpg
    "The Good Oil" well maybe not. Shell Ultra 2 fortified oil has served us well for years but it wont mix properly with methanol and stay in suspension even with a good dose of Acetone.
    Does anyone have a favorite methanol two stroke pre-mix oil preferably with Ester, and available here in New Zealand.
  7. #37567
    Just R40 and Acetone? He says with no experience.
  8. #37568
    I use Motul Micro 2T, expensive but mixes well with E85.
  9. #37569
    Yes Castrol R40 and Shell M are great. It is what I used back in the 70's but they had a tendency to promote corrosion in the bearings even with purging.
    Thanks. I have seen Motul Micro 2T from Google searches. I will give it a try, hopefully it has real anti corrosion properties and not just advertising promotional one's.
  10. #37570
    I don't know about availability in NZ but I've had good results with Maxima Castor927 and E85.
Name:	Maxima Castor927-01.jpg
ID:	352120Click image for larger version.
Name:	Maxima Castor927-02.jpg
  11. #37571
    2nd August 2011 - 11:11
    Connecticut, USA
    Methanol mox
    "The Good Oil" well maybe not. Shell Ultra 2 fortified oil has served us well for years but it wont mix properly with methanol and stay in suspension.
    We run a mix of 80% castor and 20% Red Line synthetic in the methanol fuel for our race outboards. This mix works very well for us.
  12. #37572
    Thanks for the heads up.
    Ok.... After a bit of a search, Motul are going out of the Motul micro 2T apparently. Anyway I could not find any. But I found Moto-1 stocks Maxima Caster 927 at $72/L including shipping. Expensive but I have some on the way so I can at least get started on the dyno with setting up the Kawasaki 250 post classic Road Racer.
  13. #37573
    Supreme Karts has it for $55
  14. #37574
Name:	Screenshot (127).png
  15. #37575
    Quote Originally Posted by dtenney View Post
    950 ml (1 Quart) Bottle Of Morgan CoolPower Pink High Performance Castor / Synthetic Oil which can be blended with Methanol.
    Ok, so it is model RC oil, but it is caster plus synthetic. I think it is blended 80%/20%. I have used it before so it might be worth a re visit sometime.
Name:	Screenshot (128).png
