Page 2508 of 2773 FirstFirst ... 1508200824082458249825062507250825092510251825582608 ... LastLast
Results 37,606 to 37,620 of 41592
  1. #37606
    6th October 2015 - 13:42
    2001 kx250
    USA
    Ok, I am trying to make sense of Jetting for the F81 Beast as I will have to resort to custom drilling my own. This is something I scraped from the net:-
    Mikuni hex head jets are numbered by bulk flow, while Mikuni round head jets and Keihn jets are numbered by inner diameter in mm.
    The flow difference between a Mikuni 175 hex jet and a 180 is about 6cc ~3%) . Keihn jets are numbered by jet id, and the difference between a 178 and a 180 is about .0008" (I'll let those so inclined do the math to determine the flow difference) .
    Now to further confuse the issue keep in mind that air/fuel ratio is based on weight of fuel and weight of air, but jets essentially meter by volume. So we really need to know the weight of the fuel flowing through a jet to understand all this. In simplest terms fuel weight is a function of the area of the jet multiplied by the value of the square root of the fuel head pressure multiplied by the density of the fuel.
    It looks like this:
    weight of fuel = jet area * ( SQR Root (head pressure * fuel density)
    None of the above takes into consideration the changes in fuel vaporization characteristics as you change altitude, which can have a profound impact on the final air/fuel ratio available in the combustion chamber ( the only place a/f ratio is really significant anyway) when the sparkplug fires.
    As fun as it might be to look at jetting this way, the sad fact is the cross sectional area of two jets marked with the same number can vary FAR MORE than the difference in flow due to small changes in density . Good jets can vary as much as 5% cheap jets can be closer to 10% variance.
    TZ,
    I’m glad to see the old beer can slide carb is providing its secondary benefit!
    Reading your post from my phone, too dark for my eyes, but I’ve found if you can increase the area by 2.25 to 2.5 times from a properly running gas setting you’re in the ballpark. Also it’s much more forgiving on the too Rich side versus the too not enough.
  2. #37607
    Many thanks for the carb and battery. Increase area by 2.25 times I assume is for 100% methanol. Would 1.65 be suitable ball park for 50% Meth?
  3. #37608
    2001 kx250
    USA
    TZ, yes that’s 100% Methanol, If running 50/50 I’d start with 1.85 and confirm it’s plenty enough fuel, Methanol can be overly rich and still run fine.
    Looking forward to your progress!
  4. #37609
    21st December 2011 - 21:49
    1984 CR500
    Prince George, B.C.
    I was wondering if there would be any benefit to adding some form of horizontal ditch groove on the pipe side of a power valve (I.e. ypvs) to help stop the exhaust reversion pulse when it is closed at low rpm?
  5. #37610
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    Curious to what the CCR is on the TM KZ-R1, or any other modern, well developed reed engines. Trying to see how this compares to well developed RV engines such as the RSA.
    With the obvious added job of opening the reeds, it is my assumption (dumb) that the reed motor would have a smaller case volume. If so, is this a shortcoming of reed engines, offering less for the pipe to pull on? Or are there other ways to achieve optimized intake resonance?
  6. #37611
Name:	F81M Seal - 2.jpg
ID:	352161 Click image for larger version.
Name:	F81M Seal - 1.jpg
    On the hunt for the reason gearbox oil is getting into the engine. I soaked the Kawasaki's rotary valve seal in a sample of the fuel I am using for an hour, 50% Meth, 45% 98 and 5% Acetone.
    The seal did not like it much. Swelling up to the point where it had pulled right away from the drive. Maybe not the total answer but certainly a big part of the answer.
    After the seal had been sitting out in the fresh air for a while it went back into shape. That probably explains why the bike started Ok, ran for a bit, smoked like hell and then ran real grumpy. After leaving it for a day or two it started up fine and ran Ok again for a bit then became grumpy. The next day when I pulled it down the seal looked ok until I soaked it.
  7. #37612
    Not such a dumb assumption. Reeds do seem to need help closing whereas the RV Aprilia apparently made more power with every increase in crankcase volume. They did not seem to find the upper limit.
    The Suzuki GP125 special of team ESE's. A special de stroked 110cc rotary valve unit with a NSR cylinder fitted had a very big crankcase volume. The cases and big end pin were widened by 12mm. The inner face of the flywheels trimmed back to the b/e thrust washer faces and the rod was 25mm longer than stock. Massive crankcase volume. The engine still started easily and made more power then ever.
  8. #37613
    That's nasty Rob. Real nasty.
  9. #37614
    Can you make up a mechanical labyrinth type seal for that side ? I'm sure husa can post something about the seals Wooley used in Greeves cases.
  10. #37615
    Telflon works okay with Methanol i sent rob some combability stuff
    https://www.methanol.org/wp-content/...ol-Service.pdf
    i had posted the piston ring seals before Ken was going to dyno one.
    its easy enough to find.
    Sometime ago Hooser got me excited. Nah, nothing to do the (or his?) whole chicken thing, but labyrinth seals (see pic). HP just waiting to be unleashed?
    So, got a Ø20*Ø35*7 teflon lipped seal and wrapped it with a paper strip, slid it over a crank and weighted it up so it was enough to overcome static friction and slowly rotate around the shaft with a 90 gm weight. (see pic).
    Working backwards, this level of friction equates @ 14k rpm, to equal 0 .0226 kW. Stuff all really.
    However, this is without and pressure acting on the seal. I guess the next step would be to mount 2 seals in a sleeve with varying applied pressures from within a drilling in the shaft. See pic. I guess one could do this based on crank angle vs pressure and do some sort of averaged calc of the frictional power over the full 360 deg cycle
    Attachment 325069Attachment 325070Attachment 325071
    Lab refers to the seal type, they can be a series of grooves like the Yamaha and others,
    Attachment 322714
    or a piston ring or rings in a groove
    The first use of the piston ring seal i have seen was in the DKW triples.
    pics to follow.
    Note Teflon has likely rendered them not a HP saver.
    Attachment 322713Attachment 322712Attachment 322711
    PS will it wasn't the design offices it was the company directors and shareholders the brits had amazing designers, that were not able to build anything that would require money spent on retooling the factories.
    Have a look at all the worlds motorsports they are designed and for a major part built in the UK.
  11. #37616
    ETEC 800
    Minnesota, USA
    Surely it was discussed earlier, but what carburetor size and rv timing did you end up with?
  12. #37617
    We have class limits of 24mm for 125s, so perhaps not very relevant for comparison.
  13. #37618
    Carb. Class limit for two strokes over 100cc is 24mm. RV timing on the Team ESE RV engines is typically 145btdc/85atdc. Trans 113atdc. Ignitec ignition.
Name:	110cc Crank.jpg
ID:	352168Click image for larger version.
Name:	110cc Gearbox Spacer.jpg
ID:	352169Click image for larger version.
ID:	352170 Things that Team ESE did to get more crankcase volume for their RV engine.
  14. #37619
ID:	352165Click image for larger version.
    The Kawasaki RV seal after soaking in Methanol mix for an hour.
Name:	F81M Seal - 3.jpg
    The Kawasaki RV seal looks perfect again after it has dried out over night.
    This is the same problem I had with RD250/350/400 Yamaha Teflon lipped seals back in the day. I had no problems with the Suzuki TR250R or any other Suzuki ones.
  15. #37620
    We have two entirely different scenarios in any fully tuned two stroke where one is a Rotary Valve , the other a Reed Valve.
    The Aprilia had a large case in the order of 1.24 , and this was due in large part to the long 120mm rod.
    The R1 is a few cc over 1.3 and the R2 with thinner covers over the flywheels is a few cc under 1.3.
    I have previously cut 5mm off the reed box face on an R1 and lost power , then added a 10mm spacer back in ( ie +5mm over stock ) and that lost power even more so.
    In both cases I changed the reed backups to see what the effect was , and it turns out the smaller case liked slightly stiffer 1st Mode frequency.
    The bigger case liked less tension , but it was obvious in that test , that the reeds fluttered at high rpm and the big case in fact achieved the opposite of what was expected , due to reed effects - not the volume change.
    ie it made a little more front side power , but fell over badly up top due to the thin reeds loosing control.
    So - no you cant run a big case under 1.3 with reeds due to the bigger volumes Helmholtz value requiring thin petals that then promptly bugger the power curve by going spastic at high rpm's.
