Page 2510 of 2773 FirstFirst ... 1510201024102460250025082509251025112512252025602610 ... LastLast
Results 37,636 to 37,650 of 41591
  1. #37636
    It would be interesting to find the upper limit on rv case volume before you start going backwards. With no familiarity with that engine, where did the rod/stroke ratio end up?
    I am not sure what a practical rotary valve upper case volume would be. The limit might just be getting enough mixture up into the cylinder to get the fire started. With the pipe doing the rest.
    Rod ratio. 48mm stroke 115mm between centers rod. 115/48=2.4 so rod ratio is 2.4:1. I would have used a longer rod if I could get one.
  2. #37637
    i assume you used a rd rod? If so ktm200 is 3mm longer at 118mm with 22mm and 16mm pins
  3. #37638
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Quote Originally Posted by skako View Post
    Hi,
    For the last few years, with longer or shorter interruptions, I have been trying to make a Two-stroke simulator.
    Hello,
    congratulations on your program.
    there is a very old wave simulator that works in MS-DOS.
    here it is if it can help you compare your results
    http://adardaine.free.fr/file/004Twostroke_F.zip
  4. #37639
    15th December 2022 - 06:58
    Tomos BT50
    Croatia, Virovitica
    Hello,
    philou
    thank you very much, I am looking forward to this gift.
    I currently translating text files into the Croatian language and I embellishing the technical terms a little more for better understanding. I think it could be interesting.
    When I get some comparable results I will present them here.
  5. #37640
    26th April 2013 - 21:55
    BMW R1200R 2009
    Jan Thiel & Frits wrote some very interesting experiences concerning that specific question on Pitlane-biz. ( which is worldwide the second best 2 stroke forum, after the Bucket subforum on Kiwibiker which rules )
    Testing different setups gave the answer : 120 mm rods were best. (when combined with a rotary valve ! )
    Reed valves are a different animal.
  6. #37641
    1988 cagiva freccia
    france
    Pitlane-biz. ( which is worldwide the second best 2 stroke forum).
    French forum speaks a lot and does not do much
    rsw connecting rod of 115 mm and measured 118 mm on an rsa
  7. #37642
    Telflon works okay with Methanol i sent rob some combability stuff
    https://www.methanol.org/wp-content/...ol-Service.pdf.
Name:	Material compatability with Methanol.png
    Thanks Husa for the tip about Teflon seals. I checked the chart and Teflon got an "A" and "D" rating, not sure why.
    But it might explain why some have had luck with Teflon seals and Methanol and the Yamaha Teflon tipped ones did not like it.
Name:	F81M Seal - 1.jpg
ID:	352192 Click image for larger version.
Name:	F81M Viton in Meth.jpg
    The original Kawasaki seal and a Viton one I tested did not like the 50% Methanol 45% 98 5% Acetone mix when soaked for as little as an hour.
    They both returned to their proper shape when they were left to dry out overnight.
Name:	F81M Nitrile Seal.jpg
    I could not get a Teflon seal or an EPDM one which is also rated "A" for Methanol but I did manage to test a Nitrile one.
    Soaked it for 24 hours and it showed no signs of swelling. The good thing is that Nitrile is cheep and the most common.
  8. #37643
    1988 cagiva freccia
    france
    maximum linear speed for the seal lip in nbr : 14 m/s
  9. #37644
ID:	352198 Ready to start sorting the jetting now that it has given up drinking its gearbox oil.
ID:	352199 Ear protection and a respirator for the methanol fumes plus an exhaust fan.
  10. #37645
    I never finished the extraction fan project, but now the dyno is gone, the inline fan is as I type , pumping hot air out the bedroom window so we can sleep tonight.
    Interested in results Rob.
  11. #37646
    Odd i only seen this bit.
    From what i understand with the telflon seals i think only the inner ring that contacts the shaft lip part of the seal is made of or maybe even coated with Teflon
    the rest will be some other form of "rubber"
    That might explain the variable results?
  12. #37647
    Tomos BT50
    Croatia, Virovitica
    That looks very good! Did you base it on Prof Blair's first or second two-stroke book?
    Vannik
    I am looking at the results given by philou in the link above for Cappra_250.
    Now I see an error in my result. My fluid mass flows are not equal.
    DRmass = SRmass = Exmass
    I have deviations there. I have to study the book again. I must see the program code and that all learn and fix.
    It will take more time, but I will be persistent and will not give up. I assume that the error is somewhere in the code Inletflow, Outletflow, Boxstate.
    What do you think about how much these deviations flow-mass could be allowed and acceptable?
  13. #37648
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Vannik
    Skako, the problem you have is that the first book uses the homentropic method of characteristics (MoC) to calculate gasdynamics. The problem is that the MoC is a first order method and it is not conservative so it does not preserve mass or energy. It can gain or loose mass and energy. To preserve mass and energy requires a conservative method, usually a two-step finite difference method like Lax-Wendroff or Harten-Lax-Van Leer with some sort of correction, or the GPB method that Prof Blair developed and use in his second book.
    Even so the MoC has been used for many years with great success but more to study trends and not more absolute values.
    I do not know your background so do not know if my answer above helps you. Hopefully I have not offended you.
  14. #37649
    I used Dynamation for years , but in the end its code writer whom I had become good friends with ( Curt the boss at HotRods ) decided that the MoC was a fundamentally flawed
    methodology and it wasnt worth the effort to create work arounds or rewrite the programming.
  15. #37650
    1988 cagiva freccia
    france
    is this the second book?
There are currently 21 users browsing this thread. (2 members and 19 guests)
  1. JanBros,
  2. lohring
