Page 2512 of 2775 FirstFirst ... 1512201224122462250225102511251225132514252225622612 ... LastLast
Results 37,666 to 37,680 of 41611
  1. #37666
    Just test it Rob. A bicycle pump, a few fittings and some soapy water will tell you all you need to know pretty quick.
    Exhaust can be most difficult to plug unless it has a bolt up flange. Then it's just flat plate with some rubber.
  2. #37667
    Attachment 352202
    More problems with the Kawasaki. It is leaking around the base of the cylinder. To much oil to ignore.
    To get the 250 barrel of choice to fit I had to fit a spacer plate. I glued and screwed it down to the case.
    Then milled it off square and flat.
    The joint now leaks, I am not sure if its the spacer to case joint or spacer to cylinder joint leaking.
    Or worse, the studs are pulling loose in the case.
    Rob, although you may have a gasket above the split spacers, and a layer of glue under them, there are still two tiny tunnels through the joints between the two spacers, at both front and rear.
    The roof of each tunnel is the upper gasket, the floor is the glue under the plates.
    Although you have the plates as close as possible, the tunnels will still be there, and when bolted down, may become big enough to leak oil out and air in.
    Another possibility is that the glue under the spacer plates has deteriorated to allow leaking.
  3. #37668
    This is actually very likely. A lot of epoxies don't do well around ethanol.
  4. #37669
    19th June 2011 - 00:29
    I cannot speak for you Skako, but me, I am constantly held back by the limits of my knowledge. Whatever its depth, it will never be enough.
    What has age got to do with it? I believe that the moment you decide that enough is enough, that's the moment you are old, regardless of your physical age.
    Me, I'd like to keep struggling on for a while
    "my aim is to die young as late as possible"
  5. #37670
    Well, I may have found the cause of the cylinder base leak. Loose cylinder base nuts.
    I had used fancy serrated nuts thinking they would lock when tightened up.
    But all they did was with all the vibration they ate away at the cylinder base allowing the nut to loosen off.
    They were less than finger tight when I checked them. Hopefully its just a loose nut and not the stud pulling out of the case.
    Hopefully the resulting leak has not allowed methanol to damage the spacer plate glue.
  6. #37671
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    You may have to do double nuts on the base studs, if the Serrated nuts are not working.
    . . . That shit's Nasty.
  7. #37672
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Of all the things my F9 did to itself, that wasn't one of them. Dont actually recall the engine vibrated that badly, but that could have been due to the massive magneto rotor.
    (PostalDave on ADVrider)
  8. #37673
    Use what are sold as cone nuts. Self lockers with the insert metal instead of nylon. They'll take high temps where nylocs won't.
    All self- locking nuts are single use of course.
  9. #37674
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    https://nz.rs-online.com/web/p/washe...E&gclsrc=aw.ds
    Haven't used these for your particular application, but they work better than anything else in most situations.
    The only thing I don't like about them is they feel disturbingly like a thread is stripping when you undo the nut. Which isn't the case, it's just creepy.
    PS: I'd be using a standard flat washer under those in that case.
  10. #37675
    1971 suzuki T350R
    the best island
    This is probably your best way to go as there is probably is not enough room for double nutting the stud's.
  11. #37676
    2Stroke Stuffing having more success with a conventional engine.
  12. #37677
    KTM 1290 SAR
    Wgtn
    Actually, maybe not. It would allow the lock washers to turn....
    They've worked well for me in lots of problem situations, but I've never used them on alloy surfaces where their gripping surfaces may brunel the alloy. I see you can get wider versions, though. May be worth reading their literature.
  13. #37678
    This is where I started with the Pre 72 Classic Racer project. And some great help from Flettner.
Name:	Kawasaki F9 Parts.jpg
    That frame and one of those crusty cases and the old side covers became key parts used in the rebuilt bike.
    I might be having a few teething problems but it will all work out I am sure.
  14. #37679
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
  15. #37680
    1971 suzuki T350R
    the best island
    24/7
    That is very interesting. If there is anything you can let us know about it doing this would be great.
