Page 2520 of 2773 FirstFirst ... 1520202024202470251025182519252025212522253025702620 ... LastLast
Results 37,786 to 37,800 of 41594
  1. #37786
    Getting the cc correct has nothing to do with the equipment , just your patience.
    Spinning the chamber in a battery drill would do , as using 80 grit emery cloth under your finger ( form tool No1 ) you can easily remove 0.05cc at a time by polishing alone.
    And as an aside to all this talk of compression , and the looming threat of detonation - fuel quality is , in racing , of utmost importance.
    As I tell every customer I have in karting or track racebikes , if you leave 98 pump fuel in a 1/2 empty drum , or in a vented tank overnight - its fucked the next day.
    Its now 91 if you are lucky , as every time the lid is removed all the light front ends evaporate to atmosphere.
    The Reid Vapor Pressure has dropped thru the floor , and this results in huge un atomized raw fuel droplets entering the engine.
    These do not burn during combustion , and the tune appears rich on the piston and the egt, so you naturally lean it down and bang - siezure or deto.
    Thus all race fuel should be bought or immediately decanted into 5L containers , with no airspace , and only one mixed and used at a time.
    Absolutely vital if you are reading a weather gauge ( your phone App and the local airport ) and have jetting records based on RAD or Density Altitude.
    So yes a 250MX will be happy with 12:1 but not on 91 fuel thats been in the tank for 3 weeks.
  2. #37787
    23rd July 2017 - 21:59
    n/a
    canada
    Hello everyone . I have a question about the shape of the slight hook of my b port.
    If I measure before the little hook it gives me 20 mm . If I measure at the liner at the bore it gives me 23 mm.
    IF i look on the aprilia rsw(pic CC) the tunnel seems more regular until the end.
    Am I correct in thinking that the port should shrink gradually to the edge of the bore?
    bClick image for larger version.
ID:	352398Click image for larger version.
ID:	352399Click image for larger version.
ID:	352400Click image for larger version.
ID:	352401ecause in my case it opens before arriving at the edge of the bore.
    I would love to hear your opinion on what you would do.
  3. #37788
    This is the age old problem , you want to use Aprilia like technology , but your Transfer Ducts are nothing like one at all.
    Your hook has virtually no radius on it and in the Aprilia both front and rear wall are perpendicular to the bore center line.
  4. #37789
    n/a
    canada
    Ok perfect then I will forget to try to compare with the aprilia.
    To come back to my old B duct what do you see to improve?
    Should I modify the front and rear wall more perpendicular to the center of the bore or am I still wrong?
    thanks.
  5. #37790
    The best B port configuration for max power and overev is both walls perpendicular and a full radius in the hook corner , but for example a TM Kart , where front side
    is important due to no PV , the walls are approx 15* but both parallel , plus the corner radius.
    And the hooks should point to near 1/3 from the boost to bore center.
    EDIT - and the A port front wall does not look angled back enough , where does its radial intersect.
  6. #37791
    n/a
    canada
    It's an acceleration snowmobile engine with a cvt clutch so the front side doesn't really matter.
    The front walls of the A ports intersect in the center of the bore.
  7. #37792
    n/a
    canada
    I just came across a recommendation from tsr software that dates back to 1999.
    What do you think of it 24 years later?Click image for larger version.
  8. #37793
    Quote Originally Posted by porttiming124 View Post
    The front walls of the A ports intersect well in the center of the bore.
    It seems you've already made up your mind, so posting the image below won't be any use. But I'll do it anyway.
    The radial angles of the A-port front walls are more important than any other radials, in any two-stroke. And look where they intersect the center line.
Name:	FOS scavenging concept.png
  9. #37794
    n/a
    canada
    Hello Frits.
    No I haven't made a decision.
    I removed the word well in my sentence. (conflict between me and google translation).
    Thanks for posting the image anyway.
    Indeed from what I see on your image the intersection of the front wall of duct A must be done about more towards the back.
    Thank you.
  10. #37795
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    PT, I do think a Very small amount of focus is to be put towards front side power with a cvt. After all, clutch engagment is lower than maximum power rpm. From data logs, I can see this area is used for 4-6 tenths of a second on my 440cc. Not much… but enough to be important to critical 60 foot times. And much more important than over-rev the way I see it.
  11. #37796
    n/a
    canada
    Hello Condyn.
    Actually, I totally agree with what you are saying.
    This engine will drag on (soft) snow.
    For this discipline (215+hp) we are constantly looking for traction.
    I notice that the stronger the engine is at 6000rpm the bigger the traction problem.
    Example a 600cc of 120 hp does not experience this problem.
    This is why I feel like the front end of the power curve doesn't matter as much.
  12. #37797
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Below are a series of posts by Wayne I copied years ago. They may be helpful.
    Lohring Miller
Name:	Transfer Port Design - Wayne.pdf
  13. #37798
    n/a
    canada
    Thanks Lohring. Much appreciated.
  14. #37799
    My take would be that in this case ( very unusual ) where the initial acceleration phase is traction limited , then the " front side " is important once the thing is hooked up and the clutches are locking.
    This area may only last for a few tenths of a second , but is all important for the 60ft times.
    A port front wall intersection points have been gradually moving back toward the boost port over many years , this being a function of the initial realization that fat pipes can easily
    overcome the A port exit stream coherency , and second , we have had visual wave simulators for long enough now to have got a handle on what area of each diffuser section affects the power
    band shape.
    Having the intersection point well back near the boost , means steeper angles can be employed , and this is just as easy to bias toward peak power for a CVT as it is to generate front side.
  15. #37800
    n/a
    canada
    Okay thanks Woobly.
    Here are the dimensions of a popular pipe for this type of engine that I measured last week and reproduced in engmod.
Name:	jaws replique.jpg
    I know you don't have a crystal ball.
    With the angles of this pipe for example can I point the front wall of duc A backwards as you recommend or else I will have to make a pipe with it more aggressive angles?
There are currently 59 users browsing this thread. (0 members and 59 guests)
