Page 2522 of 2774 FirstFirst ... 1522202224222472251225202521252225232524253225722622 ... LastLast
Results 37,816 to 37,830 of 41600
  1. #37816
    Two stroke Stuffing.
  2. #37817
    The details of his inertia dyno is here.
    Thanks!
    All I did was tear out the windigs.
    Attachment 316742
    Attachment 316743
    Attachment 316744
    follows on from here.
  3. #37818
Name:	Ignition curve (3).jpg
ID:	352429 Click image for larger version.
Name:	Ignition curve (2).png
    Ignition curve and performance simulation developed using EngMod2T.
Name:	F81M Ign Curve 2023-02-19.jpg
ID:	352431 Click image for larger version.
Name:	F81M Power Curve 2023-02-19.jpg
    Ignetec Ignition curve and dyno results so far.
    More work to do to get rid of the bumps at 7k rpm and the lower rpm range. More advance and/or needle.
    EngMod shows an advance bump at 7k rpm. I will try that.
    When the timing is pretty much spot on I will try playing with re sizing the main jet.
Name:	F81M 2-5 percent water.jpg
    I took a 100ml sample of my Methanol mix, 90% meth, 10% acetone and 30:1 oil.
    I added 2.5cc of water to the 100ml in the jar and let it sit to see if there was any fuel separation. Looks good, no separation.
    Water in Methanol greatly adds to its cooling and anti knock effect. Might try a batch of this brew in the bike next and crank up the advance.
    When I am in the ball park with the ignition and jetting I will strip the motor and see what can be done about the balance factor and getting rid of that horrendous vibration.
  4. #37819
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    For those that are interested in a biography of Jan Thiel in English, send an email to:
    So far we have received 83 emails from people that are interested in the English version and 22 for the Spanish edition.
    We need at least 200 requests to start printing, so we have to wait a little longer... Mail to English@LegacyJanThiel.com for English prenotations
  5. #37820
    I've noticed that some people find it easier to work with lengths rather than angles. That is why I'm considering a graphic representation in which, instead of the various axial angles of the transfer ports, their positions and target points are expressed as percentages of the cylinder bore.
    This may also be helpful in drawing the desired flow paths on a piston dome.
    And here it is: the ability to draw transfer port positions and flow directions without having to use a protractor.
    There is also a drawback: for ports close to the front and rear cylinder walls, for example the C-port, specifying position points by means of bore percentages is not as accurate as using angles. That is why I did not quote an optimum position percentage for the C-port.
Name:	FOS transfer targets.png
  6. #37821
    TeeZee , I see you are running the Turbulent Model in the Combustion page.
    You only need to do this once , when all the Combustion related parameters are finalized , ie Ignition , Compression , MSV . You then redo it if any of these are changed.
    Then save this as a new name and transfer all the Delay /Vibe numbers into your sim.
    Run the Turb sim , open that iteration and its says Write New Combustion File , do that and save it with a new name then open that as an Existing File ( transfer it out of the project folder into Two Stroke ).
    The Turbulent sim is god awful slow , as its recalculating all the values each time ,and Neels has recently made the sim speed way faster.
  7. #37822
    23rd July 2017 - 21:59
    n/a
    canada
    Attachment 352436
    Thank you Frits
  8. #37823
    Frits , thought it might be helpful to add 33% as a nominal width of the C port as many people have no idea where to start with this.
  9. #37824
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Kart pipes
    Just an interesting factoid for those fiddling with butterfly things in the rear cone.
    This setup was used in direct drive karts ( chainsaw engines ) many years ago but they had a simple fixed flat plate @ 50% area about 1/2 way down the rear cone - this was called a plate pipe ( funny that )
    These were quickly replaced by the "new" technology of having a series of perforations spaced radially down the rear cone, within an enclosed muffler tube that was simply an extension of the mid section.
    This methodology has been standard fare on kart pipes for 30 years.
    Even today this is used in several direct drive International classes.
    When it came to modelling the things in EngMod , the assumption ( wrong ) was that there were two functions involved.
    Firstly was that as the bulk flow thru the pipe increased the effect of the holes gradually reduced , and the volume of the parallel " muffler " tube would resonate at a particular rpm , effectively then
    making the holes disappear.
    Thus the return wave was smeared out in amplitude at low rpm , reducing the effect of the pipe being too short down low, and causing the return wave to arrive at the port too soon.
    But then a customer , working for the Tony Kart factory , bought the TFX system and it became clear this is not how it works. ( Frits is now using this same piece of gear ).
    At low rpm the rightward wave is transmitted thru the perforations , and is reflected back , at a much longer TL by the flat plate at the end of the " muffler " tube - well past the rear cones exit hole.
    Then at high rpm the tubes resonance effect overcame this , and the holes do virtually disappear.
    Neels changed the code to reflect this new line of thought , and boom , we had way better correlation with the TFX results.
    The system works unbelievably well , in situations where the crank is connected directly to the load - be that a wheel or a propeller.
    And is KISS to the extreme.
    Very interesting, It reminded me of a diagram of a kart pipe in bell's 2 stroke book but pulling out my old bell's book show that was all it was a diagram. Either he didn't know how it worked or didn't care. The fact it can be modeled in Engmod just makes me more interested in the program.
    . . . That shit's Nasty.
  10. #37825
    Thanks Wob, you do have a point (pun intended). I must think of a way to incorporate a port width percentage within the position points approach.
    Then again, the C-port has to fit between the B-ports rear position points, so there isn't much anyone can do wrong there.
    Hopefully I'll get a brain wave. It's early days yet, and all comments are very welcome.
  11. #37826
    I just thought that as you are proposing optimum port wall % crossing points , and the C port doesn't cross this line , having a reference % width is in essence the same thing when
    its walls are parallel to the centerline.
  12. #37827
    I just thought that as you are proposing optimum port wall % crossing points , and the C port doesn't cross this line , having a reference % width is in essence the same thing when its walls are parallel to the centerline.
    Yes it is. I just need to give some thought to presenting it clear and simple. The ability of some people to misread and/or misunderstand something is amazing .
  13. #37828
    19th June 2011 - 00:29
    Attachment 352437
    so automaticaly a question pops up in my head :
    optimum for what ? only absolute high revving power seakers or all 2-strokes ?
  14. #37829
    so automaticaly a question pops up in my head : optimum for what ? only absolute high revving power seakers or all 2-strokes ?
    All two-strokes Jan. They will all benefit from depositing the fresh mixture where it is needed, while minimizing short-circuiting losses.
  15. #37830
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    the only thing that continues to interest people is the hight compression of the crankcase...
