Page 2524 of 2776 FirstFirst ... 1524202424242474251425222523252425252526253425742624 ... LastLast
Results 37,846 to 37,860 of 41626
  1. #37846
    Thanks Frits , the disparity in my CCR description never even occurred to me - criticism fully accepted.
    The " bigger is better " thing came from the fact I have never ever , had to make a case smaller - its always been longer rods , cylinder spacer plates , pockets around the mains , reed spacers
    etc trying to correct a small volume.
  2. #37847
    15th December 2022 - 06:58
    Tomos BT50
    Croatia, Virovitica
    I did, Skako. You can find the axial angle calculations below, and as you'll see, transfer durations do not play a role. But a transfer timing of 144°?
    For an engine with only two transfer ports I think it would be best to use the radial angles of the A-ports below and the average of the axial angles of the A-ports and the B-ports.
    Attachment 352448
    Thank you Frits,
    I will try to post a video of the simulations. The simulator simply took me to angles of 144°. I combined different exhaust pipe designs and transfer times. The goal was to achieve greater power and elasticity (wider power range combined with gear ratios).
    https://streamable.com/279h89
  3. #37848
    its always been longer rods , cylinder spacer plates , pockets around the mains , reed spacers etc trying to correct a small volume.
    Same here .
    And it's my pleasure to show your input below:
Name:	FOS transfer targets.png
  4. #37849
    Tomos BT50
    Croatia, Virovitica
    Same here .
    Attachment 352453
    Frits,
    Do you have perhaps a scavenging efficiency graph as a function of scavenging (volumetric) ratio for your type of transfer channels.
    Which known and measured scavenging type best describes your transfer channels.
  5. #37850
    Post
    Quote Originally Posted by skako View Post
    Frits, Do you have perhaps a scavenging efficiency graph as a function of scavenging (volumetric) ratio for your type of transfer channels.
    What kind of graph would that be Skako? Efficiency along the Y-axis, OK. But what about the X-axis? Primary compression ratio? Revs? Throttle position? Mixture strength? Engine temperature? Environmental temperature? Environmental air pressure? We can handle 2-D graphs and 3-D maps. But 7-D...?
    The 'known and measured scavenging types' you mention remind me of the Yahama papers, the various SAE-papers and Blairs "Design and Simulation of Two-stroke Engines".
    But a lot of research has been done since then. My name appears on some of the publications, but it really was Jan Thiel who carried it all as far as we are now.
    So if you feel the need to give it a name, think of him.
  6. #37851
    26th April 2013 - 21:55
    BMW R1200R 2009
    Undersquare means: the bore is smaller than the stroke. So an engine with 54 mm bore and 54,5 mm stroke is (granted: just) undersquare, or long-stroke as I prefer to call it.
    And long-stroke Honda, Yamaha, Suzuki and Aprilia engines did win a GP or two....
    Frits, I know see that I wrote my question extremely clumsy...
    Of course in GP racing, the bulk of GP's were won on 54 x 54,5 bore to stroke engines (what i should have called 'square')
    In gp mx, in the 250 cc class all engines are long stroke. (66,4 x 72 )
    You write that square engines like the 300's from KTM, or Beta, Sherco and TM are the optimum way to go.
    That was what I thought, since all the modern 300cc two strokes are 72 x72 and being very succesful...
    Sure, if you already have a twofifty on the shelve and all you have to do is overbore the cylinder. From a technical point of view it's not the best solution, but try telling that to the bean counters. A factory that would design a new two-stroke 300 and that has NO plans to make a 250cc version, would definitely come up with a long-stroke 300.
    Thank you for a your answer. I assumed (wrong) that square ratio would be the optimum in a 250 or 300 MX engine.
  7. #37852
    BMW R1200R 2009
    Yes, it has the option to design a 5-port scavenging systems based on Frits' recommendations, giving the results in either Blair or FOS geometry.
    Thank you, Neels.
  8. #37853
    Tomos BT50
    Croatia, Virovitica
    I meant something like this graph
Name:	SEff - SRv.jpg
  9. #37854
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    That is the single most difficult thing to find! There used to be a special test bench at QUB to measure it but is has since been scrapped as QUB has moved away from engine development. They printed over a thousand cylinders to test but I have not been able to find the results anywhere. Honda built their own but according to Prof Blair they could never get it to function correctly. Today the characteristic is an output of unsteady moving piston CFD simulations which is another ball game altogether.
  10. #37855
    I was going to say it looks uncomfortably like something from a Eugenics site. But I decided against it. Until Friday night happened.
    PS search Adam Ruderfords(?) Bad Blood podcast BBC fir a balanced history from a Biologist.
  11. #37856
    TwoStroke Stuffing .......
  12. #37857
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Soeedway bike frame? Many years back a guy I competed against was seriously looking into putting a KX500 motor into a Jawa DT frame but rules wouldnt allow two stroke in speedway
    (PostalDave on ADVrider)
  13. #37858
Name:	65CC and Turbo.jpg
    Many thanks to Speedpro for his help with turbine housing for this.
    A turbo charged Suzuki RG with a aftermarket 65cc big bore cylinder. The next project after I get the Kawasaki F81M 250 running properly on Methanol.
  14. #37859
    13th September 2009 - 03:15
    all of em
    Oklahoma USA
    The beauty of the turbo rg50 is you can use all the power a lot and it can't get out of hand try to hurt you. Good for tuning driveability
  15. #37860
Name:	Burst Dyno Battery.jpg
    So much for a quiet afternoon trying different needles to improve mid range throttle response.
    You know you are getting close to success when Murphy (Murphy's Law) finds other ways unrelated to your project to stuff you up.
    Last week it was an explosion in the extractor fan, sounded like a massive back fire from a big old truck. This time the battery burst with a loud bang when I rolled the engine over, internal hydrogen explosion I guess.
There are currently 18 users browsing this thread. (2 members and 16 guests)
  1. JanBros,
  2. pirkka1
