Page 2538 of 2774 FirstFirst ... 1538203824382488252825362537253825392540254825882638 ... LastLast
Results 38,056 to 38,070 of 41608
  1. #38056
    Kawasaki had plasma sprayed aluminium disks on their racebikes years ago. (pre carbon age) No idea how well they worked. Bro-in-law made an aluminium rear disk for one of Bruce Ansteys TZ250 as it only had to work for scrutineering, he never used the rear during races.
    Ha, was going to use his bike as an example. Rear brake lever was made from Perspex.
    Plenty of ally discs in Buckets. Use organic pads.
    for years the 50/80 and 125 gp bikes used alloy disc rotors Zanzani?
    Attachment 352966Attachment 352967
    Harry hunt sold ones in the states
    The first i remember was the MV racers in the 70's
    they were i believe plasma sprayed but you could i assume do one these days out of MMC
  2. #38057
    And remember, it΄s a 201m racebike, not a trackbike that is running lap after lap after lap.
    Yes, I forget that this is for drag race, so suspension less important than weight.
    Another good option for rear could be the very light 16.5 front magnesium wheels. I use few 16.5 front wheels for rear, just made brake disc and sprocket adapter, whose shape allows little torsional movement (add photos).
    A superb brake discs, could be made from car clutch flywheel disc. Stopping power of this special iron material is amazing. Disc can be made small in diameter and therefore much lighter while maintaining efficiency of bigger steel disc. One down side is rust.
    Two other photos, rear ventilated iron disc made from Honda CBX 550 inner type brake adapted to CBR 600 lightened rear wheel 17x4.5. But material is not as good as from car clutch flywheel.
    Some Honda NR/NS/NSR front forks tubes were made from carbon fiber with outside layer of thin chromed aluminium tube.
ID:	352972   Click image for larger version.
ID:	352973   Click image for larger version.
Name:	MFR 16.5x3.6.jpg
ID:	352974   Click image for larger version.
Name:	CBX inner.jpg
ID:	352975   Click image for larger version.
  3. #38058
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    A superb brake discs, could be made from car clutch flywheel disc. Stopping power of this special iron material is amazing. Disc can be made small in diameter and therefore much lighter while maintaining efficiency of bigger steel disc. One down side is rust..
    A friend bought a write-off BMW K100 which required new discs. He had a couple made from LandRover flywheels - worked very well, although, as you say, always a light coat of rust in the morning - wiped off with the first application of brakes. (helped that he had access to a big lathe)
    (PostalDave on ADVrider)
  4. #38059
    Wile we're on the topic of lightweight disc rotors, here's one that we do for karts:
    https://www.kiwibiker.co.nz/forums/s...post1130999910
  5. #38060
Name:	F81M 2022-02-07.jpg
    Blue line was the first cut Red line after some carb adjustments.
    I had machined away the inside faces of the crank wheels as much as possible. I wanted to get as much crankcase volume as I could and with the wider space between the wheels I hoped it would reduce wind-age on the conrod as it passed between the cheeks of the flywheels. Also the big end oiling should be improved as it is completely un-shrouded now.
    A lot of the counter balance had been machined away. No idea what the B/F was now or what it should be so I just tried it as is. The vibration is so bad at 9,000 rpm I had to throttle off. 9k was about 105 mph on the dyno. The aim is to be able to run on out to 10k which looks to be about 115mph.
Name:	Tungsten Slugs (1).jpg
ID:	352979 Click image for larger version.
Name:	Tungsten Slugs (3).jpg
ID:	352978 Click image for larger version.
Name:	Tungsten Slugs (2).jpg
    Ok. Re balancing the F81M 250 crank. Eight 14mm x 16mm slugs of Tungsten (99%).
    Done one side, now have to swap over and do the other side. Looking for a 55% balance factor.
    This engine vibrated real bad at 9,000 plus rpm. I am looking for a useful power spread from 7500, to 10,500 rpm. With the peak at 9,500.
    The ignitions soft limiter is set at 10,500 and hard limiter at 11,000. But the limiter does nothing if the mixture goes leanish as then it runs away like a glow plug engine. On the occasions that it did this, I saw 12,000 plus before I could get my hand over the carb bell mouth and drown the engine into submission. Frightening.
  6. #38061
    2Stroke Stuffing eureka moment.
  7. #38062
Name:	Increased the width between flywheels.jpg
    All this re balancing palaver started because I machined away the inside faces of the crank for better B/E oiling, less windage on the rod squeezing through the original narrow gap between the wheels and more crankcase volume.
Name:	J B Weld.jpg
    The original idea was to drill a size for size hole and hold the slug in with JB Weld. With the excess JB squishing out the 3,5mm pilot holes that were drilled right thru the crank cheek.
    52% balance factor was achieved with seven slugs of Tungsten. I had calculated 6,5 slugs but I guess on the finished job there was some air space behind the slugs.
Name:	3 one side 4 the other.jpg
    It turns out that the old drill cut slightly undersize so the slugs were a press fit and I did not need the J B Weld.
    Seven slugs in total. Four one side three the other. I wonder if this will set up a rocking couple? And would it matter?
  8. #38063
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    A cautionary tale about crank balancing (I know it is 4T but still relevant):
    https://www.youtube.com/watch?v=_RvNt8qWMgc&t=633s
  9. #38064
    Lordy, I think I aged a month waiting for that dude getting to the point. First Tshirt adds, then talk talk talk.
    Rob I think all this palaver actually started when you asked a mild trail bike engine to rev higher than its intended 4-6000 range. Unavoidable.
    Looking forward to progress.
  10. #38065
    CR1000
    excellent but why they dont put nitro in there .maybe scared ?
  11. #38066
    Rob - I have rebalanced many cranks with Mallory using a press fit - twice one slug has moved.
    Its easy to TIG two small spots opposite each other , just fusion weld the two materials together , never had an issue since.
  12. #38067
    Rob - I have rebalanced many cranks with Mallory using a press fit - twice one slug has moved. Its easy to TIG two small spots opposite each other , just fusion weld the two materials together , never had an issue since.
    Yes, off to Machine Parts Welding tomorrow, to stich weld the seven Tungsten slugs.
  13. #38068
    29th January 2015 - 09:21
    kart
    wellington
    questions
    Hi Wobbly,
    Was wondering if you could answer a couple of questions , that may be of interest to others as well .
    1. If you were running 100cc direct drive air cooled reed and rotary engines and your main concern was looking after the engine and extending engine life , what type of oil would you recommend ie either a castor based oil like castrol R or a fully synthetic and why .
    2. Why is it that TM have designed the head and insert on the kz engine to have no coolant flow directly over the insert , I havnt seen this on other engines . I imagine the risk of deto would be reduced if the insert had direct water cooling . If the head and insert were machined to allow coolant flow over the insert would the jetting need to be adjusted leaner to achieve the same egt and if so are you just back to the same situation where you are still one jet away from deto to achieve max performance .
    cheers Richard
  14. #38069
    24th July 2006 - 11:53
    KTM 1290 SAR
    Wgtn
    I'll be real interested to hear how that goes, even using a laser the melting temp difference is huge...
  15. #38070
    TIG welding the Mallory to the wheel is easy , even Flet could do it without a microscope.
    Re questions - the 100cc engines when you really lean ( yea jetting too ) on them always had issues locking up pistons.
    But not bearings flying apart due to 20,000 rpm. Thus as long as you dont lean it down and are looking to extend life I would use a full synthetic like 800 simply due to the film strength.
    Using Maxima 927 or Elf 909 which is what they would normally use ( R is bloody old hat now ) is only needed if it gets real hot.
    In the Timken/Falex oil test machine a castor has bugger all film strength but has a lovely smooth wear pattern , a synthetic has well over 10 times the load capability , but the instant it is abused it breaks down into non lubricating
    components.
    Castor base , even when smoking up on the machine still lubricates the wear surfaces - the synthetic causes metal to tear off due to micro welding.
    Re the TM head insert - I dont think this is covered by an NDA so here you are.
    This idea makes more power - simple. The reason is that a hot combustion chamber surface has less temp delta with the burning combustion gas , thus conducts less of the finite fuel energy
    away into the water. The squish band is closer to water thus stays cooler to help retard deto.
    The only down side is the plug threads are hot as well , but in this case due to the straight line ignition we are deto limited in the squish , not limited by overheating the plug body and thus punching holes
    in pistons due to pre ignition.
    If you really wanted to get trick , put a clear ceramic on the combustion chamber surface only - ceramic is illegal , but hey you cant tech what you cant see.
    I have tested super trick chambers that cooled the squish , and the plug , no dramatic advantage sadly.
ID:	353011   Click image for larger version.
