Page 2543 of 2773 FirstFirst ... 1543204324432493253325412542254325442545255325932643 ... LastLast
Results 38,131 to 38,145 of 41594
  1. #38131
    Quote Originally Posted by Peljhan View Post
    I dont know where to curve it anymore. I tried aiming it towards floor but forks are in the way. I try to keep it tidy.
    If space and pipe length are an issue, looking into other types of exhaust pipes might also be an option, e.g. box type, perforated rear cone ones, a shorter pipe with an ATAC and so on.
  2. #38132
    Any header down at 1.4* included will achieve nothing. Never has , never will , double it.
    Why do weird , when weird doesnt work.
    An enclosed perforated rear cone would work well in this application , but the " muffler " tube would end up longer than a normal pipe end point - less the stinger.
    But an internal stinger would help anyway.
  3. #38133
    28th October 2018 - 06:30
    Tomos D6, Cagiva Mito
    Idrija, Slovenia
    I don't want to go over 80mm on belly section because of size. 2,8° header would end with 43,6mm diameter. Wouldn't that weaken the difusor acting as it would need to be shallower to get length back?
    These engines are old school design (small crankcase volume). Is in this case difusor action less expressed as it is can't pull from crankcase that much as modern design?
    If I make perforated cone with enclosed chamber, I will put a hole in side of enclosure and make standalone muffler facing back. Or similar as on attached picture.
    Wobbly, is that a design I should use? Should total exhaust length be changed or it should be same as with full (classic) cone?
    I used a picture from Frits files.
Name:	Vevey100 cc exhaust.gif
  4. #38134
    The header angle increase would have more beneficial effect than any down side from a shallow diffuser. Make the diffuser 2 cones , 2/3 - 1/3 lengths.
    You are dealing with no bmep here.
    The vevey was originally designed for an engine pulling more than twice your design rpm , an adaption of this would need to be twice as long.
    So as I said the muffler tube ends up being longer than your " ordinary " pipe design.
    And the later designs that I did of this type of pipe ended up with a 3* tapered header as well.
  5. #38135
    Idrija, Slovenia
    I had the rear cone and muffler design in mind from Vevey picture, not complete dimensions.
    Will make a change. Anyway I must build it for this summer riding and make some development over winter.
    If I understood, the perforated angle cone with enclosure should have smaller angle than same classic style cone?
  6. #38136
    Well its going to be shallower by making the body only 80 Diameter anyway.
  7. #38137
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    how long should the lobe flywheel be for an ignitech?
    does its length have a function? capacitor charging time or other ?
  8. #38138
    Idrija, Slovenia
    I can tell you info only for Zeeltronic. It should be min 2mm height difference and about 25° of "length".
    If you get spark at the end of step, but you want it at beginning, you need to interchange pickup wires. Signal is listening when step happens.
  9. #38139
    The Ignitech lobe height works at anything from 1.5 , but length can be anything from about 8mm to 25mm.
    I have split a 24mm lobe into 2 with an 8mm gap to enable twin fire on a 180* twin that originally ran wasted spark.
    The ECU spits the dummy if the lobe is over about 25mm , it does have a " long lobe " option but I simply shortened a longer 50mm Chinese flywheel lobe in the mill due to misfiring.
    It also differs in that its recommended you use the falling edge to fire, as this is a specific characteristic of lobe triggering - whereas noise can trigger the ECU with rising voltage spikes.
    This is the default situation that occurs when the base timing is set with the falling edge past the trigger pole , with the piston at TDC.
    EDIT - you must use a resistor plug and cap , and note that the trigger input and the coil output are on opposite ends of the connector.
    Keep all other wires well away from the coil outputs - this is the biggest cause of misfire issues people have by insisting on bundling everything together in a " loom ".
  10. #38140
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Just to be clear the pick up coil(or coils) wires should be keep separate from all other wires from the pick up coil until they go into the CDI ? and if it is a multiple coil set up should the wires for each coil be keep separate from each other?
    . . . That shit's Nasty.
  11. #38141
    In a word yes , the input trigger wires should be routed well away from the coil wires. I always have the trigger (s) on one side of the bike , the coil wires (s) on the other.
    These are on opposite ends of the ECU connector for a reason.
    And the grounds for the trigger inputs , and the power grounds , are separate as well , and should also be physically routed apart.
    The white and orange coil drive wires can be side by side and this has no effect on the triggering accuracy.
    But be aware though , the output wires ( such as a PV drive or PJ switching ) if routed in a loom with the trigger inputs will generate errors and misfires due to EMI crosstalk.
  12. #38142
    1971 suzuki T350R
    the best island
    Wiring pick up's
    Interesting stuff, I will be going over my wiring looms very carefully to make shore I have not done something bad by mistake.
  13. #38143
    Its not really doing something bad by mistake , the real issue is Ignitech and others dont tell you this basic stuff , that more often than not prevents anything approaching a " plug and play " scenario.
    The only solution is to spend years of tracking down the issues others have unknowingly created , and going grey and or bald in the process.
    I really wish I had someone telling me how not to fuck it up 20 years ago.
  14. #38144
Name:	Tungsten Slugs (3).jpg
ID:	353179 Click image for larger version.
Name:	Stich Welded Plugs.jpg
ID:	353181 Click image for larger version.
Name:	Re Balanced F81M.jpg
    The re balanced crank works a treat. Reeves to 10k now no problems. Smooth as. Now for a bit of serious tuning on the dyno.
  15. #38145
    Have you polished the crank seals and the Primary drive nut?
