Page 2553 of 2773 FirstFirst ... 1553205324532503254325512552255325542555256326032653 ... LastLast
Results 38,281 to 38,295 of 41594
  1. #38281
    All way complicated and not necessary, the Dellorto had a 10mm long main jet extension that screwed into the emulsion tube end, and an extended float bowl bowl nut.
    Something like this? And with ultra-open foam (the red stuff) to prevent frothing?
Name:	deep main jet well.jpg
  2. #38282
    All way complicated and not necessary.
    Yes, in the end, the complication may kill the twin fuel idea. But the idea intrigues me. So I would like to prepare a second carb as a comparison. I have some time as I am unable to use the dyno for a while. There is a freshly painted classic Ford pickup parked behind the dyno getting its final touches and no ways am I going to risk blowing a paint pealing mixture of two stroke exhaust over it.
  3. #38283
    Some pictures of the latest KTM SX 125 EFI engine.
    Crank plastic inserts screws must be checked and "re loctited" as they have a tendency to loosen after few rides.
Name:	SX 125 2024 (1).jpg
ID:	353456   Click image for larger version.
Name:	SX 125 2024 (2).jpg
ID:	353457   Click image for larger version.
Name:	SX 125 2024 (3).jpg
ID:	353458   Click image for larger version.
Name:	SX 125 2024 (4).jpg
  4. #38284
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    Really interesting hamster cheeks in the crankcase. If I recall correctly, the 2017 SX did not have that. Whats the reason?
    - pre compression ratio increase?
    - better flow out of reed?
    - extention of the back B-Port wall?
    - all of the above?
    Regards
    Tim
  5. #38285
    - all of the above?
    Regards
    Tim
    They likely could also not get enough material off from the inside whilst supporting the pin.
    thats seems to be a large wall thicknes on the pin.
    #The early at least 85's tend to melt the inside stuffers.
    edit sorry i thought you meant the crank not the cases
  6. #38286
ID:	353462 Click image for larger version.
ID:	353460 Click image for larger version.
    Making good progress on the Meth-Petrol-Carb. Sealing ring in the float bowl nut. Petrol in the carb and methanol in the remote float chamber.
    Petrol for the primary fuel circuit and methanol for the needle and main jet.
    The remote float chamber has 5,5mm galleries and a 4,2mm float valve.
    Next move is to add an adjustable methanol power jet and fuel level indicator like the one on the straight methanol carb.
    Straight methanol carb with Wobblys Dellorto 4,2mm float valve and adjustable power jet. The fuel level can be seen in the clear tube.
  7. #38287
    Oh yeah. Forgot it is Rotary so side of engine.
  8. #38288
    The completed petrol/methanol carburetor with adjustable power jet.
  9. #38289
    23rd March 2015 - 21:24
    Conti RX356 V3
    - all of the above?
    Regards
    Tim
    this was done so some "tuner" can regrind the cases, cut the head, recommend to use 190 octane fuel and make a story how it now revs to the moon.
    kidding aside, I'm sure KTM had a reason to do so - would be interesting to know it, all your reasons make sense.
  10. #38290
    - all of the above?
    Regards
    Tim
    Yes, looks like these crankcase "glands" match the flow from V force type reed block very well. But the last carb engine tuned version, still have 4-5 hp more and it is very noticeable on the track.
    Without easy possibility to change fuel rate on EFI engine, tuning is complicated.
  11. #38291
    Ready to Race.
    With an arm tied behind your back.
  12. #38292
    But the last carb engine tuned version, still have 4-5 hp more and it is very noticeable on the track. Without easy possibility to change fuel rate on EFI engine, tuning is complicated.
    That is interesting, KTM carburetor engine makes significantly more power than the EFI version. My experience with two stroke EFI is that you can easily match or better a carb engine for maximum power and over rev. With access to the fueling maps EFI is so easy.
  13. #38293
    Neutered by having to meet Euro emissions regs ?
  14. #38294
    I am not sure why 2S EFI should find it harder to meet Euro standards than a carb engine.
    Flettner who has way more real world practical riding experience with 2S EFI than me. Reports that with transfer port injection (TPI) there is a noticeable fuel saving which would suggest there is less fuel wasted through charge short circuiting. That has to mean a cleaner engine exhaust.
    KTM copied Flettners TPI idea then went to reed port injection. Injecting before the reed valves looks like a poor mans carburetor to me. With all the problems of a crankcase full of fuel mixture, some of which is lost through short circuiting.
    Again from my 2S EFI experience. A 125 is much harder to map properly than a 300. I suspect, maybe KTM has found mapping a 125 for the vastly more dynamic on pipe/off pipe conditions a challenge. There is a way but it is much more tricky than working with a 300.
  15. #38295
    26th April 2013 - 21:55
    BMW R1200R 2009
    On the ktmtalk forum there are a lot of stories on problems with the SX125 with failing crankshafts since model 2022. Some think that KTM did not properly solved the problem, but in stead limited the Maximum RPM on the TBI 125 SX model 2023 to avoid catastrophic failures... Poor choice. https://ktmtalk.com/threads/2023-125-sx-crank.569456/
    The ktm 125 model 2022 had more HP than the model 2023.
    But the 250 SX TBI 2023 has more HP than the previous model, so I do not think that it depends on the injection but rather to the choices that the ktm engineers implemented concerning the mapping.
There are currently 81 users browsing this thread. (0 members and 81 guests)
