Page 2556 of 2773 FirstFirst ... 1556205624562506254625542555255625572558256626062656 ... LastLast
Results 38,326 to 38,340 of 41593
  1. #38326
    3rd August 2012 - 02:39
    yzf 250
    holland
    125 sx 2023 ecu
    Requested engine load
Name:	Schermafbeelding 2023-07-12 105437.png
  2. #38327
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    [QUOTE=husaberg;1131217587]Those 7 components plus stoke differences add to .8mm if its only .1mm per component.
    [/QUOTE
    Thanks for the Look inside japanese strategies 😯
    I dont know the tolerances of japanese bike builders.
    0.1 mm in japan? This is very huge? 😥
    As a mechanic cant beliefe that husa✋
    Should i better by a minarelli next...🤔
    Grüße Wolfgang
  3. #38328
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    VForce 2 CR 125 reed thickness
    Hello
    Does anybody know what is the standard thickness of vforce 2 reeds for CR 125? probably the same for other 125 motocross!?
    I bought a replacement and it has 0.35, and the ones I had 0.4mm.
    Not sure if I noted any difference in the power, no flutuation at high end and higher idle at least I felt.
    Thanks
  4. #38329
    23rd March 2015 - 21:24
    Conti RX356 V3
    125 sx 2023 ecu
    Thanks Dutch! So which is the controlling factor to change injection mass flow?
  5. #38330
    11th September 2022 - 11:20
    Suzuki PV
    Finland
    Hello,
    Decided to create account here as I have some problems with methanol and this forum has a lot of experience about it.
    I have old air cooled Suzuki DS80 engine that im running with VP fuels M5 methanol. It works quite well and makes 12% more power than with 98 petrol. But problem is that after dyno- or top speed pull when you perss clutch it keeps reving insanely high for few seconds even the throttle is closed.
    It must be killed with engine braking and brakes. Its even detonating after top speed test if clutch is pressed and needs a long engine braking. I've had bit similar problem with petrol but not even nearly so bad and it ends quickly.
    Carb is chinese PWK 26mm with #32 idle jet and #220 main jet. Needle jet and needle are from bigger PWK. Needle is shortened to suit 26mm carb and randomly grinded with drill and sandpaper. It has electric fuel pump from K&N and needle valve flows 6,6dl/min. Engine has around 19whp with short dyno test.
    What is the mechanism behind this behavior and any suggestions how to get rid of that?
    Here is a little video, unfortunately first pull is missing where problem was worst. Second pull still has some and third for some reason is not so bad on this test. https://youtu.be/j8PJIAayKUU
  6. #38331
    Quote Originally Posted by HSuomi View Post
    Electric fuel pump produces 4-7 psi. This is way more than the gravity head in a motorcycle fuel tank.
    Perhaps the float valve is unable to resist inflow from flat out to suddenly zero. Fuel level rises and pilot system over delivers.
    Rather than pressurise the carby, use the pump to feed a header tank with an overflow back to the pump supply.
  7. #38332
    Suzuki PV
    Finland
    It has Y-branch and return line to fueltank with little flow restrictor. At least the carb is not overflowing.
  8. #38333
    But problem is that after dyno- or top speed pull when you press clutch it keeps reving insanely high for few seconds even the throttle is closed.
    "reeving insanely" is a very familiar problem for me with my two strokes and Methanol.
    I think it is due to being a little lean or maybe being exactly on the correct Air/Fuel ratio and Methanol's predilection to auto ignition (which is different to detonation). 5-10% Acetone is said to reduce the tendency of Methanol to auto ignite. Auto ignition can induce detonation, so you can have patches in the rpm range where one or both are happening.
  9. #38334
    I have two questions that may point to what is happening.
    First , what is the actual float valve orifice size.
    Second , if you are using a pump with a return and a jet restriction back to the tank , put a T in the fuel line next to the carb inlet , and run a clear fuel line upwards say 2M off this T.
    Start the pump and rev up the engine.
    What is the pressure height of the fuel in the clear line above the gasket face of the carb bowl , when the engine is reved.
  10. #38335
Name:	Petrol-Meth Carb Setup (2).jpg
ID:	353540 Click image for larger version.
Name:	Petrol-Meth Carb Setup (1).jpg
ID:	353541 Click image for larger version.
Name:	Petrol-Meth Carb Setup (3).jpg
    Petrol Methanol setup. Remote Methanol chamber has a clear hose against the side of the carburetor float bowl so that the Meth fuel level can be seen and adjusted.
    I am looking forward to trying this.
  11. #38336
    yzf 250
    holland
    AFR and EGT
  12. #38337
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Interesting
    AFR? I know what EGT means I even have some gauges to measure it but AFR? and google is not helping.
    . . . That shit's Nasty.
  13. #38338
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    air fuel ratio
    (PostalDave on ADVrider)
  14. #38339
    Methanol post... did you try a surface gap plug?
  15. #38340
    Conti RX356 V3
    AFR and EGT
    I assume thats what you used to change the mapping!? I meant the OE setup, what is the Crank Pressure Sensor for and which factors will influence the injection?
There are currently 50 users browsing this thread. (0 members and 50 guests)
