Page 2559 of 2774 FirstFirst ... 1559205924592509254925572558255925602561256926092659 ... LastLast
Results 38,371 to 38,385 of 41606
  1. #38371
    TM KZ engine with 0.82 squish will kiss the head at 15500 , we rev them to 14800 all day.
    In this application 0.82 is a little wider than mechanically possible , but any less and i have to retard the spark more to keep the overev, but this ruins the front side power. NFG,
    I have just finished doing a rod model in SolidWorks and now have the rod inertia force ( less the combustion pressure ) at TDC
    from Thomas Johansson so will do an FEA for the predicted rod stretch tonight.
    You are punished by the rulebook that won't let you use a variable ignition timing.
    Wob, it's too late in the day for me to do the math, but my gut feeling tells me rod stretch is not the main factor in dynamic stretch. I suspect crankshaft bending is the number one culprit.
    Yeah I know, I keep telling everybody else that gut feeling should not enter the equasion
  2. #38372
    Well said Frits , I have all the nominal bearing clearances , so I can add these to the rod stretch , and see how much extra
    dynamic elongation can be attributed to the crank ( big end and small end pin bending I can add into the FEA analysis as well ).
  3. #38373
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Wobbly and Frits,
    Nearby all calculations or simulations 😉...that i am not able to do..
    Heard about seeing the touch of piston in builded up coal on piston surface...
    Idea is to add /Find to add... a material for surface piston, that keeps footprint of head to measure, evaluate Real gap at highest rev...without doing damages anyway...that we as a non pro could not afford😥
    Mayby kind of spray paint...or what ever
    Ideas welcome! 😉
    Wolfgang
  4. #38374
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Tanks Frits,
    One of best things in life...are Kisses����... when piston kisses head...slighty an smooth������
    If i am right, rsa had 0,7 mm squish!?
    This is more than 1%?
    Reason?
    Dont know the stretch of all involved parts at the yz 125 at 13000 in overrev... 0,7 works...no marks on piston... mayby next 0,65...
    The only way to find minimum gap... seens to risk piston kissing head??? ���� ...����
    Other ideas???
    Tanks meister!
    Grüße at all!
    Wolfgang
    The RSA piston did not touch the head with 0.4 squish.
    It gave much more power until 12000, but would not rev whatever we did..
  5. #38375
    Hey jan!✋👍
    Wow 0,4 mm...thats a really strong rod and crank😎😲
    Mayby squish has "blown out" spark...?
    On the other hand...i am quiet sure you had best available ignition system
    Whatever...kongratiolations to your sucesses!! 😉
    Grüße Wolfgang
  6. #38376
    I am guessing that under full load on the dyno the combustion pressure pushing on the piston would negate the bearing clearances and some of either rod
    stretch and or crank flex. I think on the overun into a corner , with no throttle it would be sudden death.
  7. #38377
    Way, way back in those heady Ryger days (2015 = 8 years ago...time flies hey?) I did a calc of the net piston forces.
    The main inputs being piston acceleration, its mass and the opposing forces provided by a known cylinder pressure trace.
    The attached shows these net forces at various rpms.
    Please don't ask me if these are accurate though.
    Piston forces at varying rpm2.doc
  8. #38378
    i was reading something about a tuned Ducati it went along the lines as when they reset the squish the power went up.. but also the Decibel's went down. I can understand the hp but with the Db's
    Is it due to more complete or faster combustion? Do we have a physicist...
  9. #38379
    24th April 2016 - 19:07
    2001 zx9
    bop
    Time flies alright! re crank flex about 20 years back i did the calcs for a short stroke (64mm) rm250 and (from memory) at 12000 rpm there was something like 11000 N of reciprocating inertia, diluted with 50% balance factor leaving the equivalent of a bit over half a ton of load carried by the main bearings. Ignoring combustion pressure to allow for upshifting and closing the throttle i then set up the rm crank supported by the bearing journals and carefully applied 550 kg to the crank pin... i can't remember the value now but the crank flexed steadily as the load was brought up to what it would see in service - possibly something like 0.2 mm (or more) at the middle of the rotor's taper
  10. #38380
    Longer time in my mind...
    The squish gap in a kind of air cushion...the closer the more damping...
    And maybe this has influence of the tilt of piston at tdc...
    Clarify me if wrong! 😉
    Thanks!
    Wolfgang
  11. #38381
    i was reading something about a tuned Ducati it went along the lines as when they reset the squish the power went up.. but also the Decibel's went down. I can understand the hp but with the Db's. Is it due to more complete or faster combustion? Do we have a physicist...
    We do. More effective squish = faster combustion = more time between end of combustion and initial exhaust opening = longer expansion phase = more combustion gas energy used for piston movement = less combustion gas energy left for noise.
  12. #38382
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    do you have any idea of the power in millijoules of the ignition of the aprilia?
  13. #38383
    Polini had a variable combustion chamber... when cylinder pressure overcame pressure in cylinder head dome, it moved lowering compression.
    I had read Yamaha had tried this as well. Why didn't it catch on?
  14. #38384
    Thanks Frits
    Attachment 314930Attachment 314931Attachment 314932
    What is this head ... could it be a variable compression head????? Help Please.
    https://www.kiwibiker.co.nz/forums/s...post1130892885
  15. #38385
    28th October 2018 - 06:30
    Tomos D6, Cagiva Mito
    Idrija, Slovenia
    As we are speaking about heads and squish etc. I have a riddle here and maybe you guys have some ideas before I get into it.
    In 2021 I made a new chamber for my Tomos D6 [50cc watercooled, bridged exhaust 195°, two stransfers 128°, piston port, PVL kart ignition]
    New head has better cooling and more structural rigidity but it lost power drastically. Dimensions should be same as with old head, except squish went from old 0,55mm to new 0,48mm (will measure both heads again in future).
    You can see black graph was best power a year earlier and there was no driving between tests. Red graph is new head and I never saw so much power lost and I made lot of modifications over years.
    Another mod made in same time was repositioning of EGT probe (5mm thick stack gauge probe) from about 250mm exhaust length measured from piston to about 120mm length. I tought this was the case for low power but with removing a probe there was not much difference - blue graph.
Name:	Tomos D6 new head.jpg
ID:	353568Click image for larger version.
Name:	Tomos D6 old head.jpg
ID:	353569Click image for larger version.
Name:	Tomos D6 b-old head r-new head.PNG
There are currently 58 users browsing this thread. (0 members and 58 guests)
