Page 2561 of 2776 FirstFirst ... 1561206124612511255125592560256125622563257126112661 ... LastLast
Results 38,401 to 38,415 of 41631
  1. #38401
    So 90° was the best, followed by 60° and then 30°?
    And the original was a flat roof bathtub style but with edges in the corners (tophat) instead of radiuses? Is that correct?
  2. #38402
    No , the 30* tangent intersection with full radius all the way up into the toroid was best , it made a little more power than the 90* version - ie no vertical flat section before the toroid roof radius.
    Sorry that wasnt clear the way I described it.
    So , 30* , 90* then 60* = same as tophat ( but this toroid also had less background deto like the others over the tophat design ).
    All tests had no corner rad at the bowl edge including the tophat.
  3. #38403
    13th April 2022 - 19:08
    None
    Florence, Italy
    thanks for the insight, may i ask you to post a pic or a sketch of a toroid chamber to understand what dimensions are you higlighting?
    probably it's an english language understanding problem, i'm sorry for this... you can maybe draw them on the blue toroid prototype you posted some years ago
    thanks again
  4. #38404
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    This has been posted in the past.
    Lohring Miller
  5. #38405
    None
    Florence, Italy
    Lohring Miller
    Thanks Lohring. So i guess this is similar to the 30° version (30-7,5°?)
    I'll obtain something like this: i can't find enough volume compared to the standard shape, even if I reduce a lot the squish band. (40mm bore, 0.45mm squish, something around 16:1). Am i missing something?
Name:	Screenshot 2023-08-04 164900.png
  6. #38406
    What chamber cc are you shooting for - I will do a CAD sketch for you - maybe this setup would be best with a small thread plug.
  7. #38407
    So I looked thru my files and found a TZ50 , this is 40 bore with 39.3 stroke.
    With 16:1 the cc is 3.33 and squish is 0.42 and to get 38M/s MSV the width is 50% = 5.84mm
    This uses a 10mm NGK race plug with Iridium fine wire electrode and a Platinum fine wire ground = R0373A - 10 the same nose configuration as the 14mm R 7376 that is the best
    race plug in every other configuration.
    As this isnt a flat top the chamber wall can be steeper to suit as the squish is also angled.
Name:	50cc Toroid.PNG
  8. #38408
    Wob, I noticed that your suish area radius = piston dome radius + squish gap. But in a running engine most of that squish gap disappears, which causes an (admittedly, miniscule) occluded volume at the outer edge of the squish area. Therefore I prefer to make the squish area radius equal to the piston dome radius.
  9. #38409
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Frits, something just for you!
    https://www.youtube.com/watch?v=M92nNsxe7W8
  10. #38410
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    ...so awsome listen to you experts 👍😯
  11. #38411
    A 700cc four-cylinder two-stroke on methanol without any form of supercharging except for the contribution of the pipe, putting out in excess of 350 Hp?
    That's over 0,5 Hp per cc. That would be damn good from a 50cc single. But from a 700-4?? 'If something sounds too good to be true....'
  12. #38412
    Have my daughts too frits.
    Too much friction in 750cc engine
    A kreidler made 440 hp per liter in the 80ties
    Aprilia Rsa 432 hp/ l
    Best 50 cc today frits ?
    Best prooven hp/ liter ever?
    I ve heared about slightly over 26 hp on 50cc....ergo 520 hp/ liter...can that be true? 😉
    Apropos... feavering for liedolsheim/ germany... 50cc 8H endurance Race in September 👍👍😲😎🥰
    Wolfgang
  13. #38413
    25th January 2019 - 01:33
    Southwest of Germany
    Thumbs up
    Wolfgang[/QUOTE]
    I will be there
    Who else?
  14. #38414
    Frits, if you are thinking of the piston/head geometry changing , then we should be addressing the rock over at TDC as well.
    And if we estimate an added 15% power due to Methanol then the RSA would be 506 Hp/L as a benchmark.
    Thus the 700 is making very close to the same power per L , to me the pipes dont look clever enough to do this on a reed engine with 175cc cylinders.
    But they will be measuring power at the crank , the RSA was at the sprocket , so a variation there in favor of the 700.
  15. #38415
