Page 2564 of 2774 FirstFirst ... 1564206424642514255425622563256425652566257426142664 ... LastLast
Results 38,446 to 38,460 of 41608
  1. #38446
    Deto starts the bottom of the ring /piston seal surface then migrates up to the sharp piston timing edge , so that in my mind dictates what should be shiny and what should not.
  2. #38447
    In my mind it also dictates what should be sharp and what should not .
    Partly kidding; I use a radiused piston timing edge mainly for reasons of flow and cooling; the Coanda effect makes the incoming cool charge cling to the piston dome.
    But the radiused edge also counteracts deto, killing two birds with one stone, Or, as my esteemed colleague would put it: a free lunch.
  3. #38448
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    In my mind it dictates what should be sharp and what should not .
    Frits!
    Wouldn't you teach us more about coanda Effekt? 🤔😉
    Seems very effektiv and useful in many ways
    Where to use besides of piston edge in a 2 stroke?
    How to size radius ...in which place/ circumstanzes/ speeds of flow?
    Wouldn't you? 👍🤣✋
    Grüße Wolfgang
  4. #38449
    Frits!
    Wouldn't you teach us more about coanda Effekt? ����
    Wouldn't you? ����✋
    My pleasure Wolfgang.
    Coanda effect:
    http://www.youtube.com/watch?v=AvLwqRCbGKY
    https://www.youtube.com/watch?v=6Q8HssqWDDE
Name:	Timing radii.png
    You will find the above info, and a lot of other stuff, in my FOS tips & concepts,
    https://1drv.ms/u/s!Atyzb5b7jtWNmVcX...5eKjL?e=nxuw41
  5. #38450
    Coanda effect:
    Remember now your pics frits 👍... but was not aware this is called coanda. Sorry.
    Whatever...these days teachers have so much more patience with me✋👍 thank you!!!
    Coool to be back at school 🤣
    Wolfgang
  6. #38451
    Remember now your pics frits .. but was not aware this is called coanda. Sorry.
    It's a bit of everything, Wolfgang. Not just Coanda, but also Bernoulli, Reynolds, De Laval, even a bit of me.
    these days teachers have so much more patience with me✋ thank you! Coool to be back at school
    Teaching can be most rewarding if the students appreciate what you're trying to do. For example, as a volunteer I taught Dutch to asylum seekers who had come to Holland from all over the world. After a few lessons they started to communicate in the only language they all had more or less in common: Dutch.
    I had set only one condition: my students had to take the lessons of their own free will and not because participation would give them some privilege
    It's the same here: you visit this forum because you want to, and I'll be glad to oblige if I can.
    I'll let you in on a little secret. While trying to teach, I also learn myself. I try to explain things as understandably and simply as possible and that forces me to think about the best way to put everything into words. As a result, things sometimes become clearer to me as well. And I'm sure I am not the only one here who has experienced this.
  7. #38452
    Its more than simple talking here frits!
    Triple win for me
    Refresh and widen english
    Learn and understand more about 2 strokes.
    talk discuss communicate to same adicted nice people arround the world
    Good job not only for integration of foreigners in netherlands frits👍
    At school i was never happy, cause my mother was a teacher and there was a subtle expectation to bring very good certificates 😐🤮
    The more happy i am, to be free... free now too learn what i am interested in...without pressure 🥰👍and it feels/ is suddenly easy to learn... wow😎
    Be sure frits!!
    Have next question in back up✋🤣
    Wolfgang
  8. #38453
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    Thanks
    Figured this might be a good time to speak up and say thanks to Frits, Jan, Wobbly, Neels, TZ, and all of the other very knowledgeable contributors to this thread. Amazing how much info is on here and shared so freely!
    Even more impressive that some of the contributors are speaking in a second language and able to communicate complex subjects so eloquently!
    Eventually I'll ask some questions but wanted to start off by showing some appreciation. I've been lurking for quite some time working my way through all of this (there is a lot!) and it really is much appreciated, I'm guessing I'm not the only one that reads but doesn't comment so at least know that we are out there.
  9. #38454
    Quote Originally Posted by Storbeck View Post
    Youre welcome Storbeck
    Nice true words
    Wolfgang ✋
  10. #38455
    Thanks to Frits for (re)posting the link to FOS Tips and concepts
    While looking through this great resource I came across this pic.
Name:	3-way thermostat.png
    It reminded me that back in the 1990's there was an Aussie Automotive Engineer (John Bennett) that did a lot of research on improving the efficiency of older engines, particularly V8's.
    One issue he found was dramatically fluctuating coolant temperatures. He determined this was due to the conventional placement of the thermostat on the inlet side of the radiator.
    When coolant temperature was sufficient to open the thermostat the entire engine was then flushed with cold coolant from the radiator. This produced variable (mostly poor) combustion.
    His solution was to place the thermostat at the bottom of the system where (when required) relatively small quantities of radiator output was blended with the bypass flow to control the input temp and create a more constant engine operating temperature.
Name:	Bennett  thermostat.png
    He marketed machined alloy components for the bypass and thermostat housing (Eco-Therm?) They were well regarded but probably far too easily copied.
    If some 'Bucketeer' wanted to experiment, he/she would have no trouble producing a workable solution
  11. #38456
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Thats a well known fix for a problem the KLR650 (four stroke, sorry) has. The Thermobob bypass, developed and marketed by Wattman. His web page is well documented with the cooling fluctuations that the standard system encounters as the thermostat opens and closes. IN the case of the KLR - the engine runs far too cool, never gets hot unless the bike is not moving. After fitting the thermobob to my KLR, it quickly heats up to mid temp gauge and stays there.
    (PostalDave on ADVrider)
  12. #38457
    The Thermobob is a version of the bypass system shown in Frits' drawing.
    It is certainly an improvement on basic non-bypass systems.
    The Bennett system has the thermostat sited at the bottom not the top.
    It is regulating the coolant Input temperature.
    AND...Happy Birthday Frits!
  13. #38458
    I have tried the thermo housing at the intake side on the bottom of a couple of racebikes.
    Maybe the thermo element body was a bit small , but in both cases the hot running temp ( fully closed bypass ) was a few degrees higher
    as I think even a small restriction on the pump inlet side has a large effect , Whereas any restriction seen on the pressure return side has little effect on the flow efficiency.
    And Happy Birthday Frits , had no idea you are only a day older than the way I feel.
  14. #38459
    I´ve got a couple of questions for you guys that have converted your rides to EFI.
    In what manner do you add fuel 'when on pipe'?
    Compensation relative to crankhouse pressure, or pipe pressure?
    Either way, do you use any sort of 'pulse damper device' between source and map sensor?
    I reckon the map sensor will live a hard life otherwise.
    Rgds
    Patrick.
    A little video of some of the parts i made and will run:
    (nevermind the AMG in the beginning, just an intro)
  15. #38460
    Rgds
    Patrick.
    Nice CNC parts Patrick 👍
    In map sonsors can only talk about of KTM 990 4 stroke twin used in mainfold there.
    No clue how fast readings of Equipment in this case are. gained about 20 HP by getting rid of the limitations KTM set in injection and ignition timings 🙈🤪
    The Ecu is reading the sensors values and is giving decreasing influenz of the two MAPs the higher engine is reving.
    In higher revs main influences on injection durations are fix given in table, corelated from values of TPS opening and RPM.
    MAP values only have 10 percent influence there.
    This is kind of damping in ECU
    Think this is the way to go cause you are free to set necessary pulse damping even when pulses are hard and sensor to slow 🤔😉✋
    Pure mechanical damping can be done by🤔
    Length of hose
    Its stiffnes
    Its diameter
    Avoid overheating sensor🤔
    Take care about the fact, that temperature is changing stiffnes off diffrent hose materials ..maybe use metal tube in hot areas
    GRÜßE Wolfgang
