Two Stroke EFI. https://www.kiwibiker.co.nz/forums/s...2T-EFI-Project
Rotax 124 rotary valve inlet
The crank web is camfered sharp.
Think bad for the inlet flow...
Better rounden that ?
If yes...
One complet radius?
2 small radiuses to keep volume of crankcase nearly untouched?
Bottom of inlet duct ending is sharp too...what to do there? What uses cranks rotation influences on flow in the best way...?
Thanks..Dankeschön
Grüße Wolfgang
I don't remember chamfers on the 124's crankwebs. But then it's literally half a lifetime ago.
I'd give the chamfers a radius, but not one complete radius, as that might remove too much material from around the big end pin bore. You do need stiffness there.
I'd leave the sharp bottom of the inlet duct alone. But you might radius the side walls of the duct.
Don't worry about increasing the crankcase volume. In fact increasing it may be a good thing.
Frits!
Many many thanks for yor answer and tips!
Crank is cleaer, that we dont should weaken it!...as there is not much Material round
But i am so so confused about my conclusion to your text now...and before text expertices...do not find clear conclusion for me...
Maybe read back would help...maybe your next help!
Or ask without shame
What to do with conrod length? Aiming to longer one to increase volume by length conrod?
Or better increasing case volume by taking off Material on crank webs or case inside?
Still confosed by the fact that there might be my missunderstandings...no clear view...read back...once more...eyeyey...
SOS Frits !��
Thanks wolfgang
PS...not only for fritsDid Saturday testings for liedolsheim...gained "some" reves by ....... catch us!
Hello together ✋
My personal view now to the long intake duct of the Rotax 124.
Thinking about a subwoofer as my model to undersand
Verry simplyfied piston is the speaker...box vomume is case volume...reflex tube is long intake duct.
If i have a very long reflex tube, that i cant change, have to increase volume of box, to come closer to frequency of reflex tube
If case volume would be zero you can restore zero mixture.
In a big elastic volume you can store a lot more mixture and energy, the process of filling this is long...
Yes there is a next thing the pipe resonance...partly coonnected with case...this i left beside
The closing of the door too...
This is my personal simple picture in the moment now frits
Critics welcome✋
Open to learn and understand better
Thanks
Wolfgang
Hello together
Rotax 124
Using crank spin better with halfside radiused bottom of inlet ducts end?
My idea
Inlet is in axe above of crank center
One half of webs intersetion is spinning towards duct, the other half downwards case.
Idea is only radius the downward side of duct end...to ease the downstream finding better down the case, by lower turbulence
Second effect could be, that inlet flow in inlet direction would be less disturbed ...lower turbulence too
Good idea?
Thank you
Wolfgang
my opinion : don't (as Frits already said). you are rounding the crank web so it can flow better over the web. by rounding the bottom of the duct, Coanda-wise part of the mixture will follow it and as a result hit the web and cause turbulence, exactly the thing you were trying to avoid with rounding the web.
Hey jan,
What a pleasure! Yesterday used your fantastic Excel sheet in case of pipe! Thanks for thistop!
And for your answer
My picture was that boundary layer will be scrapt from crank web surface by a sharp edge of duct...and this could be turbulent... clearance there is 1,2 mm there....
But on the other side if sharp as you and frits told... maybe the turbulence there could help the main part of duct flow surfing over the radius on web
Even when my picture is completely wrong...like just to understand what is happening in this scenario ...hungry for this
Grüße Wolfgang
Wos,
I am not a super tuner like a lot of this group, just a 2stroke nut so this might not be the best idea..
What about adding epoxy to the bottom of the intake duct to smooth out that stepped area allowing the mixture to flow smoothly into the crankcase??
Happy to report that petrol in the carb bowl for the pilot jet and a separate methanol feed for the main jet idea works, or at least it appears so with an initial runup on the dyno.
Initial impressions. Idles and throttles Ok. Drank a surprising amount of petrol through the pilot jet. No stumbling when the throttle was quickly opened at any speed. Methanol fuel level stayed constant on heavy pulls. Power jet was suspiciously sluggish.
No dyno results yet, for some reason the PC has stopped talking to the Dyno electronics.
With 3/4 of the power jet supply line, including the control needle, above fuel level in the float bowl, the sluggishness cannot come as a surprise.
That Mikuni fitted their first power jet on top of the inlet tract 45 years ago does not mean we still have to do it that way.
Having said that, I love the way you use separate float bowls for separate fuels.
In the tests I did years ago having the powerjet discharge end mounted down from the top of the carb bore and later , shortened , gave a smoother and more
gradual flow rate transition much higher up the fuel curve. The Keihin carbs with the discharge nozzle mounted below 1/2 throttle , start to flow almost immediately the slide passes the tube.
Of course later , using a solenoid with PWM drive as Dellorto did , gave electronically the same gradual flow ramp up that didnt suddenly richen the fuel curve in the midrange as soon as the slide was high enough.
