Page 2569 of 2773 FirstFirst ... 1569206924692519255925672568256925702571257926192669 ... LastLast
Results 38,521 to 38,535 of 41591
  1. #38521
    Looking at the photo there is a restriction, the adjustment bit, close to the source of fuel. Once the fuel makes it up to the restriction then the flow rate will be restricted. If the restriction was closer to the carb throat like a normal power jet then air will flow through the restriction much more freely and once the fuel makes it that far THEN there will be a restriction to flow. Do like Frits said as well, of course.
  2. #38522
Name:	F81M - 1.jpg
    Blue line was 100% Methanol, 75 pilot + 180 main. Red line is 50 pilot jet on petrol and 190 main on Methanol. Sounded rich, I guess that is due to the petrol component.
Name:	F81M - 2.jpg
    Sucks an amazing amount of petrol compared to the Methanol. Maybe 20% petrol. Dyno's are notoriously thirsty so I expect on the track the ratio of petrol to Methanol will go up, maybe 50% petrol to Methanol. The under the plug cylinder head temperature reached the high 90's C. Exhaust about 360 C. I was expecting a cooler head and hotter exhaust, detonation?. more things to think about.
  3. #38523
    Having said that, I love the way you use separate float bowls for separate fuels.
    Attachment 353670 Attachment 353671
    Herbert Skinner would be so proud of Rob.
Name:	F81M - 1.jpg
Name:	F81M - 2.jpg
    Flanged front rim
    TX650/750?
  4. #38524
    Flanged front rim TX650/750?
    The bike is a real mix and match of bits and bobs. 72 XS650 front end or at least bits of one. https://youtu.be/1QeSHLSwSXc?si=Df3eRCnkcoFWxfeE
    Ducati caliper and 300mm Harley Flat Tracker disk rotor mounted on the XS650 disk carrier. I still have the front wheel for one of these Flat Trackers at home. Not that I ever had one, I just scored choice bits occasionally.
  5. #38525
    soon,, just some cables to do.
    And to add to methanol discussion, a lot of the info applies on twostrokes also:
  6. #38526
    Sorry Husa, I've forgotten how to search this forum using the Site: option in Google.
    Can you remind me please?
    Thank you
  7. #38527
    Thank you
    i never use google for search kb but others do they put kiwibiker in quotes "kiwibiker.co.nz" then search terms or images options
    this took about 20 seconds
    Use the Google "site:" search term to find all the posts about "balance factor" and how to check it posted on the ESE thread.
    Copy and paste this line into your Google search bar:-
    balance factor site:https://www.kiwibiker.co.nz/forums/s...s-engine-tuner
    Attachment 345305
    https://www.kiwibiker.co.nz/forums/s...post1131158831
    There is a lot of gold to be found in this thread.
    To search for it use the good old Google "SITE:" search option which turned up this on Det Buttons: ......
    det button site:https://www.kiwibiker.co.nz/forums/showthread.php/86554-ESE-s-works-engine-tuner
    Attachment 337313
    Choose a likely looking option and check it out and you will probably find a quality post like the one below.
    There are over 12,000 images attached to this thread and there is a lot of gold to be found there too.
    Attachment 337312
    To look through them use the "Thread Tools" option at the top of the page and then the "View Images" option.
    Then they can be sorted by:-
    "Posted Within" ........... I use from the "Beginning".
    "Images Per Page" ....... and I prefer 70 images per page.
    "Order Results" ............ and they can be in Descending or Ascending date order.
    When you see a picture that interests, you can click on it to view it or click on the "N/A" symbol below it to go through to the original Post.
    Page 1000 has a lot of directory information pointing to the good stuff. Click on the Blue chevron in link above to go there.
    Also page 500 about mid way down BucketRacer has a links list on:-
    How to build a 1978 30hp aircooled Suzuki GP125 https://www.kiwibiker.co.nz/forums/s...-tuner/page500
    I just search thread on this page above wobs post then advanced search search single content and add a person if you know who it was or search terms in the keywords at the bottom click search by post not thread.
    or search via person and image or just thread images.
    if you want i will post a picturegram
  8. #38528
    Please do, Husa.
  9. #38529
    Thanks Husa. The Google site: search doesn't seem to work for me anymore. Don't know why. I don't need any naked pictures thanks.
  10. #38530
    No, it does not work for me either. I have been using the KiwiBiker "Search Thread" tool at the top right hand side of this page.
  11. #38531
    https://youtu.be/a4AoXxYKy64?si=HeIVzy8rbr9GEO09
    Turns out it runs a whole lot better when you wire the Ignitech up properly.
  12. #38532
    So now Mr Hintz tell us what not to do - the important part.
  13. #38533
    Too embarrassing, can't say.
  14. #38534
    Apparently your embarrassment has scared us all, Neil; no one dares to post anything here anymore. Except for me, I'm too old to worry about losing face anyway .
  15. #38535
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    I have transfer ports on my mind.
    Much thanks to Frits for the leaning tower of Piza article.
    I could have sworn that at some point I saw a document about transfer ports from Wobbly, but for the life of me I can't find it among these 2500 some pages.
    Am I crazy and imagining things or does such a document exist and if so can anybody point me to it?
