Page 257 of 2776 FirstFirst ... 1572072472552562572582592673073577571257 ... LastLast
Results 3,841 to 3,855 of 41626
  1. #3841
    Yep, buy one of those "Performance Kits" , a few $$$ for the other Bits like reeds, carb and manifold, more $$$ for any of the race exhusts available, slap it all on and your a talented top line Bucket race engine builder I recon.
    And most likely you haven't wasted a lot of time and money on failed experimentation and useless parts.
  2. #3842
    They are marketed as performance parts. Are they competition parts? That is the grey area. I think they are well out of the spirit of the rules, but that is only my feeling. Anyway this has been argued to death several times.
  3. #3843
    4th February 2005 - 07:32
    Rattlecan blue
    Every time I've seen the debate the spirit of the rules seems to get trumped by the letter of the law.
  4. #3844
    20th October 2010 - 20:59
    Rg50 Fxr's150
    Yes sir, flash the card, buy the parts, and you still have no fu*#%& idea how it all works, suits some I suppose.
  5. #3845
    Works for me.
  6. #3846
    Rg50 Fxr's150
    I get immense enjoyment from getting together with other bucket racers over a few beers to debate all the variables of two stroke tuning and the satisfaction of seeing my efforts on a dyno are worth all the hours spent measuring and filing. Bucket racing is not about what we are prepared to pay for a motor, but more about our collective knowledge, abilities, resources and to develop a class of racing that is both competitive and affordable
  7. #3847
    just on buying bits that cost the earth
    then you get beaten by a girl on an old shitter
  8. #3848
    21st August 2008 - 21:52
    suzuki RM125S 1975
    auckland
    ESE shitter
    are you saying that the ESE GP100 in a RS125 GP frame is a old shitter.it don't know but who is leading the points in A grade.
  9. #3849
    Rg50 Fxr's150
    Beaten
    then you get beaten by a girl on an old shitter [/QUOTE]
    Sounds like Scatological Sadomasicism to me. F@#$k Yeah
  10. #3850
    Kel Lent me an old KX125 to look at.
Name:	A KX125 Head 006.jpg
ID:	236724 Click image for larger version.
Name:	A KX125 Head 001.jpg
    Best as I can tell, squish is 0.85mm
    These are the pistons I have been using, (because I have them) but I had never seen the original head before. The squish area in the head is much wider than I expected, it must make the combustion chamber a funny shape.
    This is the head shape I use with these pistons. It does not give a lot of squish area, but is a better shape (I hope), It runs with 0.8 squish and 16 deg ignition advance at peak torque.
  11. #3851
Name:	B KX125 Porting 001.jpg
    Bore 56mm Stroke 50mm
    The exhaust port is an unusuall shape with the power valve opening the side ports and a small cutout in the top of the exhaust port window and the piston drops below the port floor at BDC.
Name:	B KX125 Porting 012.jpg
ID:	236737   Click image for larger version.
Name:	B KX125 Porting 025.jpg
ID:	236732   Click image for larger version.
Name:	B KX125 Porting 030.jpg
ID:	236733   Click image for larger version.
Name:	B KX125 Porting 032.jpg
ID:	236735   Click image for larger version.
Name:	B KX125 Porting 027.jpg
  12. #3852
    The Transfers
Name:	C KX125 Porting 018.jpg
ID:	236750   Click image for larger version.
Name:	C KX125 Porting 022.jpg
ID:	236751   Click image for larger version.
Name:	C KX125 Porting 023.jpg
ID:	236752   Click image for larger version.
Name:	C KX125 Porting 016.jpg
  13. #3853
    Main Transfer Angles of the KX125.
Name:	D1 Main Trans KX125.jpg
ID:	236767Click image for larger version.
Name:	D2 Main Trans KX125.jpg
  14. #3854
    Secondry Transfer Angles
Name:	E2 2nd Trans KX125.jpg
ID:	236768   Click image for larger version.
Name:	E3 2nd Trans KX125.jpg
ID:	236769   Click image for larger version.
Name:	E1 2nd Trans KX125.jpg
ID:	236770   Click image for larger version.
Name:	E4 2nd Trans KX125.jpg
  15. #3855
    Boost Port Angles
Name:	F2 Boost Port KX125.jpg
ID:	236772   Click image for larger version.
Name:	F1 Boost Port KX125.jpg
ID:	236773   Click image for larger version.
Name:	F4 Boost Port KX125.jpg
