Page 2570 of 2774 FirstFirst ... 1570207024702520256025682569257025712572258026202670 ... LastLast
Results 38,536 to 38,550 of 41606
  1. #38536
    I havnt done a paper as such , like the Exhaust duct one I did , but I have mentioned several times about the effect of stagger on the scavenging regime.
    Reverse stagger ie RSA type favors top end and overev as it uses the larger width of the B ports being also higher to generate a big STA , also the A port being low reduces the vertical short circuiting
    up to the Aux ports.
    Normal stagger favors a wider power spread by suppressing the peak but pumps up mid and overev as well.
    Both systems work by using the excess Blowdown pressure at TPO to determine what port flows when , and gives rise to the notion that the port to open first , flows last.
  2. #38537
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Below is some wisdom I collected mostly from Wayne.
    Lohring Miller
Name:	Transfer Port Design - Wayne.pdf
  3. #38538
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    Lohring Miller
    Thank you Wobbly and Lohring!
    Lohring I assume what you have there is tidbits that were copied from the forum and saved? I'll go search around and see if I can find all of that in context, was it about a drawing you were working on (a clue for my search, I'll search through your posts).
  4. #38539
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    We'll try to avoid that see you tomorrow!
    cheers #29
    Congratulations to you Daniel and to your team könig motorsport!
    You managed to avoid it in liedolsheim! Hut ab! capeau! 😉 top!
  5. #38540
    Hello together!
    This is what we found in rotax 124 rotary housing
    Expectet a more square inlet shape... dammed oval?
    Slow opening and closing bit by bit.
    Better give it a square shape?
    For quicker harder pulse upstream the long duct to carb???
    Thank you experts in rotary valve!
    Grüße Wolfgang
  6. #38541
    Apparently your embarrassment has scared us all, Neil; no one dares to post anything here anymore. Except for me, I'm too old to worry about losing face anyway .
    We need another Ryger riddle, that put some life into this forum.
  7. #38542
    Lohring Miller
    What became of your OP uniflow engine?
  8. #38543
    I believe ryger and his 2x banned minion were more fiddle than riddle
  9. #38544
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    Anyone riding on GP50 revival next week?
  10. #38545
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    You're correct. Unfortunately I didn't note where that information came from. It was either twostroketech.com or here. Wayne has posted a lot of very similar advice several places. Frits has also posted his porting layouts. A lot depends on what you want in an engine.
    Lohring Miller
    Quote Originally Posted by Storbeck View Post
  11. #38546
    Old Tuning Documents for Rotax 124
    Dear Frits
    Have a look what i found
    Is this from you?
    Grüße Wolfgang
ID:	353698   Click image for larger version.
ID:	353699   Click image for larger version.
ID:	353700   Click image for larger version.
  12. #38547
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    The design lives on my computer. Maybe advances in 3D printing will let me revive it. However, after I turned 80 I decided I needed to limit my projects to less exotic things. I also transferred my big mill, lathe, and cutter grinder to a younger friend who will use them a lot more. I also donated my engines, tooling for cylinder modifications, and inertial dyno to another friend. He has already built some nationals winning engines for himself and some friends. With the above and my newsletter articles I hope I can pass on what it takes to keep the hobby and two stroke knowledge alive a little longer. I have been encouraging them to read twostroketech.com and this forum, but without much luck. I'm off to what may be close to my last national championship race in a few weeks.
    Lohring Miller
  13. #38548
    28th October 2018 - 06:30
    Tomos D6, Cagiva Mito
    Idrija, Slovenia
    I will be there and make some photos. Bump me up we'll have a chat, can't miss me, guy in a wheelchair with camera. I will be with my friend Cerar, he is driving freetech.
    20+ riders will participate. I think it is a record. And it's 10th aniversary this year.
    Will you race?
  14. #38549
    23rd March 2015 - 21:24
    Conti RX356 V3
    Thank you nice to meet you!
  15. #38550
    13th April 2022 - 19:08
    None
    Florence, Italy
    hello everyone,
    just received this beauty: 3d printed exhaust flange with transition from 75% area cylinder duct exit to 100% round area, with aux ducts gradually merging, thanks to @wobbly knowledge
    it's 20mm long (40mm bore so 60mm duct+20 flange). I hope to ramp up cnc machining operations on the cylinder and crankshaft soon (not my machines unfortunately) and see if we can get this wobblyduct to go!
ID:	353757   Click image for larger version.
ID:	353758   Click image for larger version.
ID:	353759   Click image for larger version.
ID:	353760   Click image for larger version.
