Page 2571 of 2774 FirstFirst ... 1571207124712521256125692570257125722573258126212671 ... LastLast
Results 38,551 to 38,565 of 41608
  1. #38551
    What is the manifold being used on , im interested in the project ?
  2. #38552
    13th April 2022 - 19:08
    None
    Florence, Italy
    hello wob, will be used on my 50cc self designed cylinder on an old Cagiva 50 engine.
    still work in progress cause we lack time on the cnc machining end of the project... my partner in crime is spending all his f.cking days building his new house. I hope he's finally done with laying the damn parquet later this month
ID:	353766   Click image for larger version.
ID:	353767   Click image for larger version.
  3. #38553
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Quote Originally Posted by Gradella23 View Post
    Very Nice. I like three exhaust ports over bridged exhaust ports and just not because Aprilia did on there High HP RSA125 but because big exhaust bridges have all ways given me problems.
    . . . That shit's Nasty.
  4. #38554
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Is that a 3D printed cylinder?
    Lohring Miller
  5. #38555
    None
    Florence, Italy
    hello guys, little update, almost ready to melt some aluminium....
    Lohring Miller
    hello lohring, no it's a casted cylinder, i quote here my previous post where you can see the sand cores: the inner core is 3d printed directly in sand, while the outer core box was self built by me using 3d printed plastic models.
ID:	353771   Click image for larger version.
ID:	353772   Click image for larger version.
ID:	353773   Click image for larger version.
  6. #38556
    Gradella , when you said 40mm bore I thought you were referring to the spigot - not the cylinder bore as it obviously is.
    I have done a TZ50 where the spigot exit was 26mm = 100% of the port effective , and that was the same as the venturi size of the 30mm HV Lectron carb
    it was fitted with.
  7. #38557
    Sewing machine?
  8. #38558
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    Cool
    Quote Originally Posted by Peljhan View Post
    I will be there and make some photos. Bump me up we'll have a chat, can't miss me, guy in a wheelchair with camera. I will be with my friend Cerar, he is driving freetech.
    20+ riders will participate. I think it is a record. And it's 10th aniversary this year.
    Will you race?
    I did,😎
    We met😉
  9. #38559
    None
    Florence, Italy
    it was fitted with.
    sorry, maybe I wasn't clear. Anyway i got a 29mm spigot exit = 660mm2 of exhaust port total area.
  10. #38560
    None
    Florence, Italy
    Sewing machine?
    if you mean FDM print, yes, the external core box models are 3 printed in ABS, coated with a filling primer and sanded to the desired roughness.
ID:	353780   Click image for larger version.
  11. #38561
    25th August 2022 - 19:08
    RS125
    Spain
    hello,
    Wobbly, Why the kz R1 take little channel for water and kz10 take bigger channel?. Im no seeing any hole under the channel?.
    Regards
  12. #38562
    7th March 2018 - 05:39
    Kart
    Europe
    Hi Rudex,
    This small milled groove is only for the air to escape that cooling chamber.
  13. #38563
    The factory deleted the water entry up under the Exhaust duct completely with the R1 , as this means the duct heats all the cold water before it runs over the transfer tops.
    The 10B and 10C they added a side water hose to push cold water over the duct top only.
    The best solution is to use an extended spigot over the top of the duct with holes pointing back over the transfers , and have 2 x3mm holes up from the case to keep some flow
    travelling up to the head.
    Thr R2 has my spigot extension within the casting , it just needs the 3mm holes to move water around the duct from the case.
    This can also be done to a Vortex , as it has a threaded hole in the cylinder - the CIK have confirmed to me in writing this is legal.
Name:	TM Water.jpg
  14. #38564
    24th April 2016 - 19:07
    2001 zx9
    bop
    Re auxillary exhaust ports; i am assisting a small amount with building a set of kawasaki triple cylinders - modern port layout with reedvalves fitted but still non powervalve. at this stage the aux exhaust ducts need to do a gentle loop around the outside of the forward cylinder studs - would this be a no go? the alternative is to relocate the studs but this is not the most preferred solution. any thoughts?
  15. #38565
    RS125
    Spain
    Thanks Wobbly and Vortex,
    Yes, You are right. I checked in R1 case and cylincer is closed. I read the whole thread and see your spigot sometime ago, great idea.
    But , my question if the spigot input and the output are connected with ineer conduit, I cant see in picture. Do you have better pictures of case?.
    Best Regards.
ID:	353820   Click image for larger version.
Name:	TM KZ-R2_2022 SUP.jpg
