Page 2572 of 2774 FirstFirst ... 1572207224722522256225702571257225732574258226222672 ... LastLast
Results 38,566 to 38,580 of 41600
  1. #38566
    Yes , there has to be a slot in the casting between the crankcase and the gearbox as water enters at the bottom , travels up to keep gearbox heat away from the crank , then exits out the side
    up into the cylinder via the external hose.
    I tried to get the factory to change the water flow in the R2 by having the cold water entering as normal at the bottom , then up between the crankcase and gearbox , but then to flow forward
    in passages over the main bearings . This cold water would then enter the cylinder up each side of the boost port.
    Thus cold water cools the transfers immediately . I proved this worked by boring a hole above the boost port , behind the carb , and putting the water hose around into that.
    It looked ugly as fuck , and is of course illegal to race , but added 1 Hp instantly.
    This was a step to far for TM to do this homologation as I was still struggling with the R2 update to the ports and pipe designs.
    I have not split open an R2 case , as no one has done enough Km for a rebuild yet.
Name:	Wobbly Water Hose.jpg
  2. #38567
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    very interesting, I have a picture with flow lines ( the blue lines ) where I think the water flows based on my understanding of your description the other (brown)lines are where I think based on your other descriptions where barriers to flow would have to be place for the water to follow what I think you had said. If I have not done this right please let me know.
Name:	Wobbly Water Hose water flow.jpg
    . . . That shit's Nasty.
  3. #38568
    25th August 2022 - 19:08
    RS125
    Spain
    Yes, I remembered when you tested the idea to put the hose in the front of transfers and You got more power.
    Yes, the little slot is there, my question is If under this slot will be another bigger conduit for more flow travelling from bottom to the upper part before to exit in the hose to cylinder.
    Checking the homologation files, It seems Modena KK3 and Vortex VTZ are similar.
    Modena seems a copy of TM case, very similar. And Vortex with water cooled too is near to TM.
    Vortex doesn't has the slot but the conduit is under for sure, and the water flow from the upper space to cylinder with the holes only. Modena has the holes under cylinder and use the hose output to lateral flow to cylinder.
    BTW, Rexon motors applies similar concept you exposed, only lack the holes between boost port.
    Regards
ID:	353833   Click image for larger version.
ID:	353834   Click image for larger version.
Name:	Rexon Motors (Karlheinz Hahn) 035-ES-17.jpg
  4. #38569
    The best scenario would be to have the cold water going over the main bearings , then up each side of the boost port - but the small trick is to have small 3mm holes under the main Exhaust duct
    This works with the extra spigot tube in an R1 as well as the R2 that has the tube cast in .
    It is important to keep the Ex duct cool , but not use that heated water on the transfer tops - see the small red arrow I added to the R1 flow diagram..
    Even better is having cold water between the bore and the inside transfer radius , that is worth 1 Hp in the RSA , and was done on the BSL500 and the KR3.
    The Rexon looks good , but the water cannot " flow " anywhere ",so will simply heat up , not cool the alloy .
    Unless they are very clever and have the water entry from the case , each side of the boost port.
ID:	353836   Click image for larger version.
  5. #38570
    RS125
    Spain
    Check the pdf, interesting. Look at spigot entry water cooled and the gasked cylinder base and the exhaust port output.
    https://www.rexon-motors.com/wp-cont...on-2019-V1.pdf
    https://www.facebook.com/rexonmotors...s?locale=es_LA
  6. #38571
    Kawasaki used a similar cooling circulation scheme for KR 500, that envelopes the boost port first . Same with Suzuki RG/XR 500.
ID:	353839   Click image for larger version.
ID:	353840   Click image for larger version.
Name:	Suzuki  XR 14 1975.jpg
ID:	353846   Click image for larger version.
Name:	RG 500 cooling.jpg
  7. #38572
    Just feed it E85 and cool everything from the inside.
  8. #38573
    Not this one because its air cooled.
    By having two smaller exhaust ports, with extensive water cooling atound the ports and a heavily cooled bridge area, has to be better at keeping 'exhaust charge' cooler?
    How much work has been done on twin port exhaust with water cooling, modern transfer layout and up to date exhaust design?
    If we are in fact after maximim blowdown time / area.
  9. #38574
    So,,,
    Sorry to disturb your discussion, but i had a big success today and want to share it =)
    Ok,, back to your discussion =)
  10. #38575
    So,,,
    No need to be sorry..thanks for sharing!
  11. #38576
    So, the limiting factor for the twostroke ( loop scavenge) is blowdown time / area, ultimately? Run out of time / area to let the gas pressure out.
    So if we could magic up some more area, would it give us more time, i.e. hold max BMEP to a higher rpm?
    Would we leave ports at 195 and 130 respectively?
  12. #38577
    So, the limiting factor for the twostroke ( loop scavenge) is blowdown time / area, ultimately? Run out of time / area to let the gas pressure out. So if we could magic up some more area, would it give us more time, i.e. hold max BMEP to a higher rpm?
    I came to the same conclusion some time (40 years) ago which resulted in my FOS symmetric scavenging system.
    Here is a picture that you may have seen in another forum a while ago Neil.
  13. #38578
    2nd May 2020 - 21:05
    Aprilia RS125
    Barcelona
    Hi wobbly, can I have your advice about EGT?
    I added an EGT probe but now I realise that it is not that easy to understand what to do with that information, even after reading all your good writings on the subject.
    The engine is a Rotax 122 (Aprilia RS125 motorbike) and EGT topped 600 ºC (1112 ºF) and remained constant after >1km pull.
    Would it be correct to downjet 1 size and check if the EGT goes ~55 ºF (~30 ºC) higher?
    Technical data:
    • Unleaded fuel pump 98 octane
    • Compression ratio 13.5:1
    • Squish gap 0.9 mm on toroidal head
    • Ignition timing 15º at 11000 rpm, 6º at 12000 rpm then flat line
  14. #38579
    Your method is on the money , but the devil is in the details.
    Temp rise from a jet change depends on the area delta , and history tells us you simply cannot rely on factory quality control for mass produced jet sizes.
    If you are prepared to bet your motors health on a stamped number - you have to pin size all the orifices.
    There are several flow/time based checking systems on the net , but I have only checked Dellorto sizes against pins and a Diesel injector rig , and confirmed the same results.
    In that case a normal Dellorto change , say 142 down to 140 would give around 20*C , but I have all the measured intermediate odd sizes as well and 142 down to 141 is close to 10*C.
    Next pitfall to be aware of is the timing curve.
    15* at 11,000 is perfect if peak power is at that rpm , but if you are holding close to 12,000 with 6* of timing the egt will continue to rise faster and faster.
    This is a self sustaining loop , in that the extra pipe heat makes more power , that creates more heat , that creates more power Ad Infinium.
    You then have to add more fuel , not to make power , but simply to prevent egt runaway in the overev region.
    This then negatively affects the fueling at 11,000 and you may never see the egt drop - that's why its good practice to flat line the ignition with as much timing as you can,
    as soon after peak as you can , commensurate with how much overev you actually use for every gearchange point.
    Most racebikes I have tuned will drop to 10* about 1000 rpm past peak then flatline , trying to balance the fine line between overev bandwidth and egt at peak.
    Of course a solenoid powerjet changes all that , and can run a longer pipe - then using the switched lean off to extend the rpm.
  15. #38580
    Aprilia RS125
    Barcelona
    Thank you wobbly for the all the good information
    I was not aware of the jet production dispersion being so important, so I will try a method for the measurement.
    Now I understand that without the solenoid powerjet you cannot have both peak power and overev. If fuel is used for peak power then it is not enough for cooling egt in low ignition advance overev, and if fuel is used to keep down that egt then it is too much for the peak power.
    In fact the Zeeltronic ignition came with a curve 15° at 11000 rpm and 10° at 12000 rpm. I will use that one.
    Thanks again wobbly
