Page 2574 of 2773 FirstFirst ... 1574207424742524256425722573257425752576258426242674 ... LastLast
Results 38,596 to 38,610 of 41592
  1. #38596
    Jan Thiel's book is now available in English. Here are the ordering details:
    Price is 25€ per book plus shipping.
    Shipping costs are:
    Netherlands 7€
    European Union 11€
    Rest of Europe 14€
    Rest of the World 22€
    To order more than one book, email to LegacyJanThiel@gmail.com with details and Dolph will calculate the price.
    Indicative shipping costs to NZ: 22€ up to 2 books, 53€ up to 7 books.
    You can pay either by transferring the total to the following bank account:
    Stichting legacy Jan Thiel
    IBAN: NL95 BUNQ 2085 4413 19
    or by PayPal to
    Please add 3% for the Paypal fee.
    Whatever payment method you use, please add a telephone number for the customs declaration, your email for shipping tracing, and leave your full shipping details in the remarks or email to LegacyJanThiel@gmail.com!
  2. #38597
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Fantastic!
    Shipping costs are:
    Netherlands 7€
    European Union 11€
    Rest of Europe 14€
    or by PayPal to
    I have been waiting for this! Since my dutch " ist Boss "
    . . . That shit's Nasty.
  3. #38598
    Cylinder Cooling. The problem faced is that we have conflicting requirements in different areas.
    We want cold water over ( and preferably ) between the bore and the transfers as well as between the crankcase and the gearbox.
    Plus we want to keep the squish surface area as cool as possible as well.
    The real hard factor to achieve separately is we want the combustion chamber surface to be hotter , to reduce the temperature delta between it and the burning/expanding gases.
    This also reduces the flow of heat energy into the water , directly from the head inner surface.
    The TM factory used my idea of a directional control tube over the Exhaust duct that forced cold water directly back over the transfers
    by including it in the casting cores.
    But they still have the original holes in the case and cylinder , under the Exhaust duct - blocked off.
    Thus now in the R2 we have cooler transfers , but only very indirect cooling of the Exhaust duct within the casting.
    This is easily fixed by drilling two small holes down into the cold water in the case , with matching holes up under the duct.
    Reversing the flow idea may have some advantages , but the worst downside is that no matter how you do it , you will always have hot water between the crankcase and the gearbox.
Name:	TM Water.jpg
ID:	353868   Click image for larger version.
Name:	Vortex S2 (2).jpg
  4. #38599
    So perhaps a 2 piece head with ceramic inset in chamber. Nah probably fall out. Hmm. ,
  5. #38600
    5th October 2023 - 00:41
    Honda CRF450R
    Italy
    cyl cooling
    Thanks Wobbly for the clarification on the water flow in the cylinder.
    I wanted to reverse the water flow in an existing engine to see if there was a performance increase.
    The engine is from a direct drive kart so the heat coming from the gearbox is not present and the water marginally cools the crankcase.
    The biggest problem is the cooling of the combustion chamber dome which could reduce the benefit of the cooling of the transfers.
    What risk do I run if I try to reverse the flow of water?
    Thanks
    AM
  6. #38601
    Bike pit starter
    Wish I'd had one of these https://bikestarters.com/product/2-5...-bike-starter/
    20 years ago when I was looking to buy a mate's 256 Rotax GP bike. I've since used home made versions, but these are clean.
    Main reason I didn't buy the bike was that I'd likely be traveling by myself to Bears events etc.
    With Mikunis it started beautifully with helper pushing. Or 5/10 Χ by yourself. At a trackday I slightly flooded it and arrived at staging hot sweating and puffing.
    Nightmare.
    Of course I couldn't have afforded the bike and starter even home made back then. . .
  7. #38602
    Nightmare.
    A few weeks ago I watched a guy on a modern 4 (honda 600 I think getting pushed up and down the pits with his mates falling in heaps as it refused to fire For about 10 minutes.
    I was struck with the realisation that if only Honda had of thought to add a starter motor to its street bikes over 205cc back in the 1960's.
    one of the reasons that the first KR250's were 180 cranks was it was easier to start as all gp were push starts back then. As well as easier on the coupling gears
  8. #38603
    15th May 2017 - 14:26
    2002 Aprlia RS125
    Shipping costs are:
    Netherlands 7€
    European Union 11€
    Rest of Europe 14€
    or by PayPal to
    Anyone getting this book sent to NZ who what’s to share shipping?
  9. #38604
    I'm happy to contribute to a group buy but I can't walk to post office etc so can't be distributor.
    Local postage might eat up savings?
  10. #38605
    It's other 2 problems we're the ally square tube frame was built '83/84 so wrong side of pre '82 class. And converted to 17' from 16'. No room for wheels that could carry 250 slicks. Chain scrapped against an ancient 150 or the frame if spaced.
  11. #38606
    1981 waddon
ID:	353871Click image for larger version.
    Cameron on KR250
    First was heavy vibration, caused by the engine’s one-up/one-down 180-degree firing order, which broke front exhaust pipes (until the team provided a spring-joint in that pipe at the failure point) and sometimes shook the check-valve in the front brake master cylinder such that the rider could pull the lever to the bar without effect. At the US Loudon national the vibration of Harry Klinzmann’s KR-250 broke four of the six tubes supporting its steering head, allowing the remaining two to bend as the front wheel raked itself out!
    The vibration problem was solved by changing firing order to 360 degrees (both pistons moving up and down and firing together). When used with a 100-percent balance factor this made the engine quite smooth because:
    At TDC and BDC the pistons were going one way and the balance weights the opposite.
    At mid-stroke, the front balance weight was yanking forward and the rear crank's weight was yanking backward.
    The contra-rotating cranks were geared together by two thin, roughly 4-inch diameter phasing gears, which dipped into gearbox oil. Spinning at 12,000-rpm these gears whipped such heat into the gear oil that paint was burned off the early engines. The first-order “fix” was to drop the original 1,100cc gearbox oil quantity (up to the shaft axes) to 600cc (mostly only first and second wheels actually now touched the oil)
    A better fix was to separate the phasing gears from the gearbox oil with a “fence” save for a 1mm hole to let oil in. Gear action would then throw the used oil back “over the fence.” The low oil level required pre-lubing every gear during assembly, for otherwise a dry gearbox would squeal at first start-up.
  12. #38607
    Yeah it (1980 engine) was in an Armstrong frame before I believe (which likely would have been 82 eligible I guess). Holden probably would have had people to push start him, - before my time though.
  13. #38608
    24th April 2016 - 19:07
    2001 zx9
    bop
    Re auxillary exhaust ports; i am assisting a small amount with building a set of kawasaki triple cylinders - modern port layout with reedvalves fitted but still non powervalve. at this stage the aux exhaust ducts need to do a gentle loop around the outside of the forward cylinder studs - would this be a no go? the alternative is to relocate the studs but this is not the most preferred solution. any thoughts?
    bump - just in case this was missed ...
  14. #38609
    Somewhere back in this thread I remember seeing inserts in stud bores which were shaped to be part of the aux exhausts - but had studs screwed into them above and below.
    Husa ? Ring a bell or can we use your search ninja skills please.
  15. #38610
    Easy way is to use oversize 4140 studs ( 1/2" =12.7mm ) with the stock 8mm threaded ends.
    This was done to the TZ350 LSR title wining engine for both a 3port Exhaust , and a bridged reed intake.
    Made over 100 Hp at 12,000.
    The FEA confirmed the stress was equal at the thread root diameter when 1/2 the stud was ground away for the duct width needed.
ID:	353877   Click image for larger version.
