Page 2576 of 2774 FirstFirst ... 1576207624762526256625742575257625772578258626262676 ... LastLast
Results 38,626 to 38,640 of 41600
  1. #38626
    What if the axillary ports and main ports are the same length?
  2. #38627
    That would eliminate the time smearing issue but if you then reduced or eliminated stagger , the quickly increasing area presented to the Blowdown pressure at EPO would be much bigger ,
    thus the initial sonic wave front amplitude and duration would be commensurately reduced.
    Plus then you also have a huge drop in Blowdown pressure at TPO - affecting the staggered transfers scavenging efficiency , and thus front side power capability.
    All this theoretical analysis , for me anyway , only applies to outer limit tuning - playing with low bmep shitboxes holds no interest whatever ,
    for others its the very reason for staying alive , so no adverse judgment on my part.
  3. #38628
    Im not thinking of low BMEP shitboxes, what if you have considerable more blowdown area? What would you do with it? How would you arrange the porting, Being able to push Peak BMEP to higher revs?
  4. #38629
    I really dont know what to think Neil.
    As it stands there is no more real estate for extra transfer area to match a big increase in Blowdown STA , and we are already at the outer limit of reliability
    reving a 125 to 14800 all day - so increasing the bmep at whatever higher level ,to a higher rpm simply isnt possible.
    It would need a complete rethink - Frits 360* radial transfer option comes to mind , but that concept needs a huge amount of practical R & D to work into a viable
    mechanical layout - and of course where is the cash going to come from, and who is going to use it in what commercial environment.
  5. #38630
    13th April 2022 - 19:08
    None
    Florence, Italy
    regarding this, any thoughts about these weird exhaust port shape? i don't know anything about that, only that they're some italian guys selling vespa kits.
    I found them casually on Facebook. Never seen anything like that before tbh, at least it's different
    https://www.zeusengine.it/ and ZEUS special components on FB for more pics
ID:	353894   Click image for larger version.
  6. #38631
    None
    Florence, Italy
    Quote Originally Posted by Gradella23 View Post
    Ok now i got It: It's some sort of symmetric scavenging with a second boost transfer under the main exhaust. Mm i can't decide if It's dumb or interesting, for sure It's out of the ordinary
ID:	353896   Click image for larger version.
  7. #38632
    I remember you once lamenting that if you could lift the head for extra exhaust blowdown, you would. Im not lifting the head (ie no unconventional valve in the head) but I do have the opportunity to build a new cylinder, water cooled, 125cc, with an unusual exhaust port layout that will increase exhaust area. Yes based around the twin port. I just dont want to make a mess of the rest of the cylinder by not taking advantage of an optimised transfer layout, ie timings.
    At the moment Im basing all my information largely on using 2 x 65cc ...... because I dont know any better.
  8. #38633
    Another low BMEP shitter.
ID:	353898 Click image for larger version.
    Having got excited about the idea of radiusing the edge of the piston in the transfer port area. I thought I would try it on the new Suzuki GP110 (48mm stroke) with its 54mm cylinder from a NSR250 twin.
    Max crankcase volume. Long 115mm rod. Crank machined and lightened to within an inch of its life. Balance factor 50%. Tungsten slugs pressed in with 3 tons.
    Probably doing the piston edge radiusing wrong.
    What it looks like down the bore.
    Ok, so this may have been a mistake. The transfer radiuses open the sides of the exhaust port earlier than desirable. Could be an issue. Will see how it goes.
  9. #38634
    Wobbly, if the eye ports are essentially 'one way valves' exhaust out but no reverse pulse back up them, what height would you place them?
    Exhaust out but then about TPO they shut, to not open again until blow down on the next cycle.
    Eye ports and main ports same length.
  10. #38635
    Its all most of us can afford to play with.
  11. #38636
    Tbh it just looks you have created two obvious hot spots on the piston front.
    Reduced squish cooling about 50%.
    And opened the exhaust port early, but only on the sides.
  12. #38637
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Self justification
    I am just going to state this so if I am right I will look good for a week and if I am wrong I will only look bad a week.
    I think Flettner is at least thinking about controlling the port's with a sliding sleeve like a Bistrol aero engine but using a 2 cycle operation instead of 4 cycle operation of the Bistrol.
    . . . That shit's Nasty.
  13. #38638
    No, conventional bridge port except twin outlet but with more ports further round the cylinder where exhaust normally cant go. Extra eye ports but with a rotating valve that can open and shut as needed. Extra blowdown but thats all.
    I still have the sleeve engine in a box waiting for a spare YZ250 gearbox to materialize.
  14. #38639
    So this begs the question - does your engine need more Blowdown STA , and more specifically can that extra port time area be matched by a commensurate increase in Transfer STA.
    Generating oodles of Blowdown has more downside than it does any perceived advantages , by way of seriously killing front side power capability.
    And my previous comments about having excess initial area at EPO still apply , in that this will reduce the amplitude and bandwidth intensity of the wave front exiting into the diffuser.
    Again I reiterate all this I take from the perspective of trying to push the boundaries of what can be achieved with current SOTA techniques.
  15. #38640
    Thats my question, can I add more duration to the TP's
    Or is what we have now peck twostroke? Unsurpassable.
