Page 2579 of 2774 FirstFirst ... 1579207924792529256925772578257925802581258926292679 ... LastLast
Results 38,671 to 38,685 of 41609
  1. #38671
    21st March 2014 - 22:00
    Hanau, Germany
    Quote Originally Posted by beta View Post
    All good, and then when you know that most of the KZ european/world championship winners in the last years had 198° exhaust 194° aux and 138° A port transfers and they work great (Wold Champ winners) what you have to think?
    At the parc fermθ you see all these cylnders with 1.5mm of gaskets underneath
    Maybe because they need more compromise on the given straight line ignition curve whereas any road racer bike used a programmable ignition curve to get the best out of the whole setup and have no gears to shift through?
  2. #38672
    28th October 2013 - 08:19
    1992, f10 malaguti
    Italy
    I don't know but it really surprise me the first time I did measure the port timing of the trasnfers.
  3. #38673
    Beta , the reason behind the jacked port timings is that I have been instructed that the homologated ports/pipe have to suit " the majority " of the factories customers.
    The Euro/Worlds engines are run to over 15,000 rpm all day , then rebuilt after every ( and often replaced during one ) meeting - completely not suited to 98% of the customer base.
    In my perfect world the timings would be left down at 196/132 and I would be allowed to shorten the pipe to get the revs and top end power that is being hamstrung by the straight line ignition.
    Its a very niche scenario with no useful crossover to " normal " tuning knowledge.
  4. #38674
    So what of an extra transfer under the exhaust, an idea worth pursuing?
  5. #38675
    Absolutely , but that involves proving having no Exhaust area below TPO actually works as a concept first.
    Build a cylinder with both ideas and we will never know the effect each has on performance.
  6. #38676
    Surely one cylinder, then jb weld transfer closed for 'after' test. Should last long enough. Then burn out. . . Or put on shelf.
  7. #38677
    Would we make it the same height as the rest of the TP's or should we reduce its timing a little?
  8. #38678
    I'd be very tempted to open it first. You've already got the cylinder contents heading in that direction by that point.
    If the transfer below the exhaust is used to give a pressure pulse to the area below the piston, something's gonna happen.
    Any flow back up that port will of course be exhaust contaminated - but if aimed straight across the piston might not affect the scavenge regime.
    Happy to be shot down in a puff of exhaust smoke....
  9. #38679
    12th October 2016 - 01:24
    1964 Vespa GS
    San Francisco
    In CFD simulations the sharp edge of the exhaust port has very little impact during blowdown but as the pressure ratio drops a larger and larger radius is needed to keep the flow from creating eddies* (mixing the exhaust and fresh charge). From this it would seem that if the exhaust floor was raised then it would be helpful to add as large a radius as possible since it has no impact on timing.
    But this would get in the way of an extra transfer below the port.
    * The downward 25° angle of the exhaust prevents the eddies forming on the roof of the port.
    Patrick Owens
    www.OopsClunkThud.com
  10. #38680
    Possibly some 'challenges' in keeping it well separated from the exhaust duct heat, with a good entry angle.
    Maybe it is the transfer to hold up the 'tower' and the (former) A's need to aim elsewhere??
    Wobbly is right about evaluating one change at a time but if it is to work well it will be the interaction of multiple elements.
    Still... if anyone can, You can do it!
  11. #38681
    Yes, exhaust piston on a OP uniflow gets a thermal hiding, key to a successful design is addressing this ..... as you know Frits.
    Now we are talking about transfers under the exhaust port....how about secondary transfers under the exhaust piston exhaust ports? Cooling plus some extra transfer STA.
    Might also block charge from the intake end escaping out the exhaust. (good for economy, maybe not for racing).
  12. #38682
    ...How about secondary transfers under the exhaust piston exhaust ports? Cooling plus some extra transfer STA. Might also block charge from the intake end escaping out the exhaust.
    We're talking opposed piston uniflow scavenging, right? I'm sure the exhaust piston would love the extra cooling.
    But preventing charge coming from the transfer side from escaping out the exhaust? I don't think mixture coming from the transfer side will be influenced by any charge originating from behind the exhaust ports.
    I'd sooner see it happening the other way around: the main transfer charge pushing the charge coming from behind the exhaust ports, into the exhaust before it has had a change to do something useful, like scavenging the spent gases.
    ​Besides,with transfer streams coming from both sides we couldn't call it Uniflow any more
  13. #38683
    Having a twin exhaust port does change possibilities.
    Water cooling is going to have to be applied very carefully.
  14. #38684
    If we are talking OP uniflow, there are many possibilitys, including differential piston sizes / strokes and certainly piston phasing offsets.
    Three main issues though
    Exhaust piston thermal control
    Combustion chamber shape
    Transfer flow....
    Exhaust piston is a challenge but Im hanging my hat on a steel aluminium composite. To do this I need make an electrode for spark eroding the piston crown underside .... but my CNC is out of action, for some time, so thats put a stop to that, for now.
    Combustion chamber shape for spark ignition does hold both advantages and disadvantages, plenty to sort through to get an acceptable outcome.
    Transfer, an issue because all the charge wants to do is rush straight for the exhaust. Swirl will slow this but leaves an unscavenged plume in the middle. So far with my OP engines Ive used a combination of some ports swirl and some aiming at the centre of the piston directly opposite each other to help clear the central plume. Now I have a completely different system .... involving transfer 'tumble'. Best idea Ive come up with so far to solve OP uniflow charge transfer issues.
    But this will all have to wait ..... CNC electronics are expensive to fix, unfortunately.
  15. #38685
Name:	Petrol-Meth Carb Setup (1).jpg
    Why ......... with the best power main jet fitted. On straight Methanol this thing would run on after a full throttle 10,000 RPM dyno pull. With the petrol meth combination it still runs on after a big dyno pull.
    I would expect that enriching it up would be the cure but interestingly the richer I made the methanol main jet the worse the running on became. Why?????.......
    Two thoughts, one the Methanol float chamber runs low during a pull (4,3 Delorto Methanol float seat) or there is so much combustion-able fuel being blown through into the pipe mixing with air drawn back through the stinger that its feeding the engine through the exhaust port. Could that be possible? I know that at closed throttle the average pressure in the crank case and exhaust chamber are near atmospheric. So atmospheric air does flow back into the system through the stinger.
    When I can I will ask someone to observe the fuel level during a pull to see what happens. Any other suggestions of what to look for would be very welcome.
