Page 2588 of 2775 FirstFirst ... 1588208824882538257825862587258825892590259826382688 ... LastLast
Results 38,806 to 38,820 of 41612
  1. #38806
    17th March 2023 - 06:08
    1982,Yamaha RD125LC 10W
    Belgium,East-Flanders
    Thank you very much Jan. I've got Band 2 here but am still looking for Band 1. I will contact them and see what they've got.
    Maybe Band 1 from this other website ? I don't know how Band 1 looks like.
Name:	prof Jante deel1.png
  2. #38807
    15th December 2022 - 06:58
    Tomos BT50
    Croatia, Virovitica
    Quote Originally Posted by skako View Post
    I'm sorry I don't have band 1.
    Band 2 is the only one I have from Jante.
    Excellent, Skako. So you have Jante's books too? For those who are curious now: "Über Verbrennungsmotoren und Kraftfahrwesen, Band 2" by professor Alfred Jante.
    It won't be easy to find those books now, but if you manage to do so, please let me know; there is still a volume missing in my library.
    The research on of the exhaust top edge radius, page 333 and subsequent, shows that Jantes NZD 12.5 research engine had a bore of 90 mm and a stroke of 125 mm.
    My research into the effects of the bore/stroke ratio led me to make the radius dependent not on the bore, but on the stroke, and I found an optimum at 5% of the stroke.
    Attachment 354006
    On page 319, the exhaust duct has a large radius drop that is approximately 78% of the cylinder diameter, at an angle of about 35° to the horizontal plane. The large radius on the upper edge of the port transitions into a smaller radius that is about 11% of the cylinder diameter.
    These ratios are according to my approximate estimation based on the data and drawings that can be seen in book Band 2.
    Sorry, I did something wrong with these double repeats.
  3. #38808
    Thank you once more Jan. I am going to try that.
  4. #38809
    If both the piston and the exhaust port have a timing radius, and if both radiuses are not tangential to the bore, and if the top of the exhaust port has an elliptical shape, then calculating the open port passage degree by degree for the purpose of determining the angle.area becomes quite a job. Thank god for computers.
    Attachment 354007
    Reminiscent of the significant improvement in flow that can be achieved by using multiple angle cuts on poppet valves and seats.
  5. #38810
    Oh he absolutely hates them. They have helped disprove his existence multiple times and you don't even want to know the logical logistics for him to even form that opinion.
  6. #38811
    Watching that image makes me want to cry. What happened to common sense? I can't imagine anyone would want to improve flow by cutting multiple angles on poppet valves and seats. I would leave out the poppet valves completely. I would also leave out the four-strokes completely. But if you insist on four-strokes, imagine the significant improvement in flow that can be achieved by substituting those multiple angle cuts with radiuses.
    I happen to know some otherwise decent people who work on four-strokes, so I'm not completely unaware of what goes on there. Radiusing is common practice in competition four-strokes and has been so for a number of decades.
  7. #38812
    Yes Frits , radiused geometry is now commonplace since Rottler introduced multiple axis CNC porting machines with spindle cutting heads that can also form any shape in the seat area.
  8. #38813
    Just some info of my tzr250 iīm converting to fuelinjection.
    It isnīt by far finished in dyno(mapping) but it seems very promising, a lot of wheelspin halters my progress, but iīll change the tire for the coming weekend(reduce slip).
    But i wanted to share with you the gains of having a seriously short intake compared to normal.
    In my case the normal intake with carburetor was about 130mm long.
    It is now only 35mm long.
    And in picture below, in the white quadrant there wasnīt any power before, it just fell on itīs nose after ~11500rpm, at 12000rpm i had about 5-8hp left, now it is above 50hp.
    And i havenīt really lost anything in midrange and on the left side of the curve, i canīt say exactly as it is slipping on the dyno.(maybe after this coming weekend i got more info on that)
    I also marked with a red arrow some slight misifre i had, probably due to not 100% correct fuelmap yet, it was worse at first, but after some pulls when i richened it up in steps, it started to go away.
    If probably is just adding some more fuel in that area it will go away, and maybe some more hp.
    But my tire was melting so i had to end the dynoday.
    IR gun said the tire was 82-85c hot, it was very 'wet' when i laid my hand on it, i actually got stained black *lol*
    Best before ending it was 71.4hp, i have dynoed more with carburetors.
    That was with a lot less wheelslip, so probably it is equal now, but i canīt say just yet.
    I will when i feel i am very close, mount the wideband sensors and finetune it.
    Best of all, rock solid idle and lowrpm drivability, really smooth.
    And idles perfect from cold to hot, and coming down to idle perfect after some hard pulls on dyno.
    Very pleased so far =)
  9. #38814
    I need to argue with you Frits.
    You are not always correct.
    Radius seats are commonly NOT used due to wet flow do not like it.
    In exhaust you can use it.
    Iīve been porting foulstroke heads on a very serious level for about 5-6yrs ago and further back in time.
    I often reached the same levels of power as professionals did, this with my 'hobbylevel' of knowledge.
    On turbocharged engines i often reached far more power, or to say it otherwise 'the same power' but at far less boostpressure.
    The idea of not having radiused seat on intake is that you need those abrupt corners between the different faces to keep the fuel atomized and suspended in air column.
    It has been verified many many times in motorsport.
    We can take Pro stock in dragracing, 8liter V8 with poor technology is reaching more power per litre than many highly tuned engines with 4valve technology.
    And the tuners all agree there, you need those non radiused seats.
    Dry flow is an another thing though =)
  10. #38815
    Multiple angle cuts were obviously not optimum but were a means to achieve some consistency in multiple cylinders with manual machining operations. It was more about the similarity of the image than the finer details.
    As wobbly says, Four Strokes now have 5 axis CNC porting machines. The valve pocket and tract is not too hard to imagine as a transfer port or exhaust duct.
    If 'precision' radiused port openings and piston edges are able to produce valuable improvements in flow volume and directional control a Computer controlled tool would allow quick and consistent experiments and/or performance upgrades to production units.
  11. #38816
    2nd November 2023 - 23:26
    east yorkshire uk
    spent the last few days searching this thread and i like the idea of a two stage header with wobblys 2/3 1/3 dimensions but am struggling to fit in the 3.5/5.5 angles along with a 3 stage diffuser with a sharper angle last cone to give more front side power. if i try and incorporate all this and the 32/68%
    my belly goes too large in diameter. over 3.5x my duct exit diameter. 25mm . i cant have the main diffuser more than 12 degrees. and even then my last diffuser isnt much steeper.
    can i use a two stage header but with angles 60% of the recomended @ 2.1/ 3.3 ? that only saves me a fraction.
    or can i ignore belly diameter and my diffuse sections would go 8-12-18 degrees and follow roughly the lengths of the various pipes ive seen on here. wobblys wr200 pipe layout seems similar to my needs except it doesnt have the steeper
    last diffuser
    my rear cone im guessing a bit less by 2 or 3 degrees. 22.
    aiming for wide power emphasis on front side.
    i can make 3 pipes with variations and see how they perform on the dyno.
  12. #38817
    As with all of the results gained from the black art of pipe design everything is a compromise and no free lunches are available.
    To gain front side I would go with a slightly steeper single stage header say 4* with a two stage diffuser , making the second cone quite long and steep.
    But 18* is very steep in any mans pipe design manual ,so I think shooting at that number is too limiting , if a smallish center section is deemed desirable.
    Why the emphasis on a pipe with a narrow belly , this is only mandatory in old engine designs with lift shaft transfer ducts and no inner radius to keep the transfer streams on track,
    away from the Exhaust port.
    EDIT - SwePatrick , just a couple of observations re your SportsDevices printout.
    Why is there a ratio difference with the two files shown ?
    The DIN700 correction is useless for a 2T - JIS D1001 is far better or the latest update V41 has the FOS correction option that works very well.
    Your graph is showing either you do not have enough trigger teeth to give enough data points for better resolution , or you have very low smoothing in operation - no way does
    an inertia wheel jerk from rpm to rpm point like that.
    Here is a sample run off my SportDeviced rig - it has 124 teeth on a starter ring gear 1:1 with the wheel , and minimal smoothing.
Name:	Mats New R2 Jacked.JPG
  13. #38818
    Different days, different gears(front sprocket, and also slip), i thought that was obvious as the name of the runs kind of hinting on that =)
    But upcoming weekend it will sadly enough differ again as iīm about to change rear rim and tire to a known good kombo that doesnīt melt on the roller
    I do run quite low smoothing as i want to se small changes in fuel and ignition map, running more smoothing just lowers the numbers very little, up to only ~1hp.
    And this isnīt any hunt for most hp in the world at this point, so i donīt need to be 100% correct, i only need to see changes.
    Iīm not a fan of FOS compensation as it is the one that adds the most power, but i also need to say i actually havenīt studied what to use, i only just chose the one that a friend of mine runs in heīs cardyno and settled with that.
    Iīm running if i remember 16 tooth on the triggerwheel at the roller, (the one that was included).
    Earlier i had Performancetrends system and it never showed what you mention even though i just had one triggerpoint per revolution.
    And about v4.1, it is actually quite buggy.
    You can also spot there is no torque reported, i later on loaded the runs into v4.0 and it showed torque, so it was recorded, but not presented in v4.1.
    But i also got a starterring, so i might test that in the future.
  14. #38819
    A little video of me just not getting it(to start with)
    I have my excuses, but i wonīt drag them to the surface here
  15. #38820
    Attachment 313065Attachment 313064
    This exhaust port floor dam gave a very positive result on the dyno but the cylinder was written off before I could finish the experiment. An exhaust port floor dam is something I am defiantly going to include in my next motor.
    We Know for a fact that on a 54.5mm stroke race engine lifting the Ex floor several mm made more power.
    It was tested properly in a real back to back by Mr Thiel.
    Blindly thinking lifting it more will automatically be better is a dangerous assumption, and could well end up like most assumptions
    in just being an error waiting to be revealed.
    Sure a longer stroke would need alot more, but how much has still actually to be tested properly.
    TeeZee tested it on a cylinder that was a good one, he buggered that up in some way, then added a high floor or dam and made it better.
    Not very conclusive or scientifically relevant to a non buggered up cylinder.
Name:	Ex Port Floor Glue 003.jpg
    There was some talk about razed exhaust port floors.
    This is Team ESE's attempt. Alloy insert shaped to the exhaust duct floor. Retained by screws and sealed with high temperature epoxy.
    It worked well enough, certainly didn't have any catastrophic negative effects on performance like so many of our other out of the box ideas have done.
    Was it better, yes it looked like it but hard no know definitively. It showed promise. If it was easy I would do it again.
    The hand dug side ports worked out Ok too.
    We eventually destroyed this cylinder trying to improve it, as you do.
    The pursuit of one off special cylinders that take a lot of work were abandoned by the team as replicating them for other team members was not practicable.
There are currently 17 users browsing this thread. (1 members and 16 guests)
  1. wobbly
