Page 2590 of 2776 FirstFirst ... 1590209024902540258025882589259025912592260026402690 ... LastLast
Results 38,836 to 38,850 of 41630
  1. #38836
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Hi Together,
    This is the original works shape of disc valve inlet duct. Oval like a egg.
    Isnt it better to open and close suddenly? Like i sketched on the housing?
    Merci danke thanks..
    Wolfgang
  2. #38837
    That shape gives the max intake area if that is needed , but the disc closing edge badly wears the case.
    This is due to the fast air column pressing on the shutting area.
    To fix this you need the closing edge on the disc angled forward so that the outer radius keep longer contact with the case surface.
    I will find a picture and post it.
    This configuration has no effect on power with the same closing timing.
    The best shape is to reduce the boss diameter on the disc and have the longest width on crank centerline - and or increase the disc diameter.
    This reduces the port width and gives greater STA for the same timings.
ID:	354031   Click image for larger version.
  3. #38838
    Ok wobbly...if we need ...top answer!
    Think wee need quick force on mass in rotax dammed snorkel??...and maybe a softer closing could be have two positiv effects...more guidance...and a lower/ softer...time shifted...bounce
    Back of the mass in snorkel?...
    Thank you very much !!
    Grüße
    from disc valve beginner Wolfgang
  4. #38839
    Dont even think about damn snorkels , its not physically possible to make a RV intake too short using a normal carb even with Frits insert O Ring idea.
  5. #38840
    That shape gives the max intake area if that is needed , but the disc closing edge badly wears the case. This is due to the fast air column pressing on the shutting area. To fix this you need the closing edge on the disc angled forward so that the outer radius keep longer contact with the case surface. I will find a picture and post it. This configuration has no effect on power with the same closing timing.
Name:	RSW250 inlaat.jpg
ID:	354033 Click image for larger version.
Name:	F81M Rotary Valve - Annotated.jpg
    Picture of an RSW250 rotary disk and the other where Frits points out the error of my ways.
    The disks rotate anti-clockwise in these pictures.
    You can see the beginnings of wear on the rounded closing side of my disk. There was corresponding wear on the closing edge of the crankcases' inlet port.
  6. #38841
    Grüße
    Good morning wobb and tz
    Thanks for tips and warnings
    I know frits idea with a kind off "guidance bar". Is it that what you call o-ring?
    We have a enduro. Boots of rider aside motor covers ...no space to mont carb on disc cover directly
    But we are talking about low revs for enduro use... a overrev to 10500..11000 ...
    Am i wrong with my theory, that faster opening helps to accelerate mass quicker in fucking long missconstruction
    to fill crankcase faster??
    Thanks for your help and advice
    Grüße Wolfgang
  7. #38842
Name:	bronze inlet disk guide.jpg
    This is the bronze inlet disk guidance bar.
Name:	ultrashort carb mounting.png
    This is the ultra-short carb mounting with the O-ring O.
  8. #38843
    Very short frits... top...thank you
    Clutch cover...disc side has height of 85 mm... mikuni 34 about 78 length...6 mm for gap between airbox and carb to breeth... have calculated this
    Its possible...
    But need to cut off part clutch cover...do oilsealing it...its of Magnesium...do complete new channel to airbox...all bullet proof to airbox ... folks... sorry not this winter
    Have patience with us please
    And let me please ask if it would help open suddenly...
    Grüße Wolfgang
  9. #38844
    Short answer about the angled straight sided port , yes it does make a little more power .
    I tested all this at ZipKart when the 256 first came out - dozens of valve opening and closing shapes and must of been a hundred timing combinations.
    Once we had the straight port sides we couldnt go back , but even with the angled closing side on the valve it never really solved the wear issue.
    Not worth the small increase in power in my opinion.
  10. #38845
    Hey wobb...thank you
    Be sure that we have things in mind that are worth to do
    Lite piston
    Welding head to built a squish area
    Reduce ex duct
    Changing transfers to more upward
    Max ex duct to 70 percent and 30 blowdown
    New nikasil coating
    Build a pipe
    Programming a ignition curve
    A lot to do as we only meet every possibe friday :cheers:
    Viele Grüße to all
    Wolfgang
  11. #38846
Name:	Triton Laser (1).jpg
ID:	354050 Click image for larger version.
Name:	Triton Laser (2).jpg
ID:	354051 Click image for larger version.
Name:	Triton Laser (3).jpg
    For something different. The dyno drum had become worn smooth allowing the bikes wheel to spin up more easily than it should.
    It had been a problem for a while. Taking the drum out and re knurling it seemed like an impossible task.
    Today the Laser guy came and started to restore the traction surface of the drum by deep etching it.
    The surface now has the same grippy feel to it that it had when new. A Laser! Who would have thought!
    Amazing technology. It can engrave in different colours and even QR codes below the surface of the stainless top layer so the design stays stainless clean for ever.
    Lots of other normal engraving tricks too. For effects like, deep or through engraving to just removing a layer of paint or anodising to reveal a logo or design.
    It was just a chance encounter that we heard about this. It took only a couple of hours start to finish to restore the dyno drum. Great value.
  12. #38847
    Great stuff Rob. I had the same issue on 'my' (Vash's) dynojet. Was showing up on my 100hp RZ so resorting to deep clean and ultimately tightening the straps a bit more than ideal. Not my problem (or Mike's, RIP dude) anymore.
  13. #38848
    24th November 2011 - 23:24
    Enfield GP5, Alpha Centuri, TZ
    UK
    Ultra short carb mounting
    This must be an Ultra Ultra short carb mounting, this is a Gardner carb built into an Armstrong disc valve cover. It was also done on a Barton I believe.
    https://www.kiwibiker.co.nz/forums/a...&thumb=1&stc=1
Name:	Gardner on rotary valve Armstong cover.jpg
  14. #38849
    Quote Originally Posted by Strokerhaus View Post
    Yes, you cannot do much shorter than that.
    But Armstrong only got away with it because the Gardner carb does not have an integral float that would have been severely confused by vibrations.
  15. #38850
    Inlet can be shorter, with no carburetor and sliding throttle 'Gibs'.
There are currently 187 users browsing this thread. (1 members and 186 guests)
