Page 2592 of 2773 FirstFirst ... 1592209224922542258225902591259225932594260226422692 ... LastLast
Results 38,866 to 38,880 of 41594
  1. #38866
    Ooh. Too soon.
  2. #38867
ID:	354081 Click image for larger version.
    Something interesting on the dyno today. 92% unbridged exhaust port.
  3. #38868
    Ok the 92% cylinder is not the one for the scooter but this home made cylinder has been successfully run in competition.
Name:	Home Made (5).jpg
ID:	354085 Click image for larger version.
Name:	Home Made (4).jpg
    The cylinder uses a small tongue to guide the trapped "L" shaped ring back.
Name:	Home Made (3).jpg
    The exhaust port floor forms a dam that starts about midway up the transfers.
  4. #38869
Name:	Home Made (1).jpg
ID:	354087 Click image for larger version.
Name:	Home Made (2).jpg
    Transfers have removable covers and the transfer windows are CNC machined so that they are radially and angularity are symmetrical and match each other.
    So for those wondering if screw top pistons, trapped "L" shaped rings and exhaust port floor dams are real. Then this is one cylinder where these features have been made to work.
  5. #38870
    Attachment 354050 Attachment 354051 Attachment 354052
    Today the Laser guy came and started to restore the traction surface of the drum by deep etching it.
    Laser etched finish on the dyno drum. Tested it today, it seems to work, great restoration method for old DynoJet dyno drums.
  6. #38871
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    Mesh
    I produce engines for amateur aviation, for customers like this https://www.fulcrum-engines.com/
    Is that a real problem? Especially with Fibre based reeds.
    I had a problen when at -28C original Moto Tassinari V-Force carbon petal in the center were broken and made some further damages.
    It happen at 6 hours 40 minutes of permanent work at 6700rpm. It happen first time, but I very offset and dont want it happen again.
    I will try make 0.4mm kevlar petals as instead of carbon in this valve.
  7. #38872
    So does this Company!
    This looks like a 'business' opportunity!
Name:	6000 drones.JPG
    Slava Ukraini!
  8. #38873
    -28C is the air temperature at 4000m., assuming a ground temp of around 0C. (like say.. mean Winter temp in Ukraine)
    Specified operating altitude of a Shahed drone is 60 - 4000m.
    I really hope I'm just a bit paranoid, but Russia's brutal and criminal assault on Ukraine Must Not be supported.
    Slava Ukraini!
  9. #38874
    https://www.facebook.com/photo/?fbid=10161171465454322&set=a.41107369321&__cft__
    [0]=AZXHmmgugPPjH36MU_QhfYvUjFJkaV_rD7IjwFlHO7BE2BSF8 W3WNAy-aByy-ojUy3VBdvoPTz-B6vvXWO8E5uZXbjEX4aGKd5sm_tMKsbjbBIuPSzLb3CvtcPJqX t6aGEWfPzqpSule3_Be9d7BHgeBzhe2zCfwX8N5RjWlGDKC3o6 gzJ30BBxrrHhhSVdZroJn8ZbPmj8gIZ91v5NOBtxS&__tn__=EH-y-R
    Lets not point the finger at each other but save it for the politics that shook the jar and got the ants fighting.
  10. #38875
    15th May 2017 - 14:26
    2002 Aprlia RS125
    I have a friend who is having problems with a yz250 based kart engine running on methanol. Peak up is at 9250. This is the ignition curve he has. Click image for larger version.
    I think it’s too much and does not drop off.
    He had melted pistons. Egt is getting to 620
    An I on the right track to help him?
  11. #38876
    I think it’s too much and does not drop off.k
    With 'peak up' you mean maximum power? Then the ignition timing is more than 10° too early there.
  12. #38877
    2002 Aprlia RS125
    Yes. Peak up is meant to be peak hp. Dumb auto correct
  13. #38878
    The ignition is way too advanced , but that can be corrected by reducing the static setting - such that you get 15* at peak HP rpm.
    But besides that issue , any engine that sees over 600* egt on Methanol is WAY too lean and WILL seize immediately.
  14. #38879
    Depending on compressionratio 15degree might be low try ~17-18degree if having oem compressionratio.
    BUT!! richen it up a LOT!
    I´ve seen best results with methanol at ~430degree exhaust temp.
    And by doing this you probably need to build a new pipe to get the peak at the same rpm.(shorter pipe for methanol engines)
  15. #38880
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Seems to be a hpi ignition curve.
    This cdi is available with second curve..switchable
    But these universal cdi curves never fit perfect to application...
    Also available for hpi inner rotor ignition are free prgrammable cdis
    Or you use yamaha original ignition rotor stator and combine it with hpi cdi programmable for original yamaha ignition system..
    Yz 250 original curv is only 20- 23 advance to 4000 then falling... reason seems to be to keep it rideable
    Next game changer was to reduze squish gap from about 1,8 mm to 0,9 within keeping compression ratio...area 50 percent...
    Grüße Wolfgang
There are currently 67 users browsing this thread. (0 members and 67 guests)
