Page 2597 of 2773 FirstFirst ... 1597209724972547258725952596259725982599260726472697 ... LastLast
Results 38,941 to 38,955 of 41593
  1. #38941
    21st August 2014 - 13:28
    2001, Honda, RS125
    Melbourne, Australia
    No stress Wob,
    Let me know if you have any luck.
    I would imagine the pipes would have a pretty serious ignition map, porting and combustion chamber requirements
  2. #38942
    2nd November 2023 - 23:26
    east yorkshire uk
    while we are at it has anyone got a pipe design for an rd350A with mild porting?**
    i could exchange a load of designs for mobylette 50v's that DONT work
    here's something that has just dawned on me. whenever the waves encounter a convergence in the pipe they send back a stuffing pulse.
    so at the very end of the diffuser where the belly starts this will happen no? and at the wrong time? and the more abrupt the change the more energy is wasted?
    so, can i "round off" or blend in the diffuser/belly joint to lessen the wasted energy? and again the belly to rear cone seems to me to be returning pulses for the over rev which in my front side cruising pipe is not wanted. if what i suspect is true i can see the advantages of hydroformed/flowing pipes. a short 10mm section either side of the belly could reduce the angles although also increasing the angled cones main angle ever so slightly.
    **i made some pipes 10 years ago using blairs percentages slightly tweaked and they have nice power everywhere but no show stopping massive wheelie inducing hit. they go the bike up to 120mph actual. 100 sat bolt upright, which i was pleased with. now geared down to 110 cos im getting old.
    glad to see im not the only one asking pipe questions. i previously felt like the pupil in the class always with his hand up - please sir!! please sir!
  3. #38943
    19th June 2011 - 00:29
    waves are created when the diameter changes. at the end of the diffuser the diameter stays the same throughout the belly so no waves are created until the diameter changes again with the beginning of the baffle.
  4. #38944
    Where there is no change in CSA there is no wave formation , the belly does nothing.
    Except I sometimes use a slightly tapered mid to create an effect needed ( steeper or shallower ) before or after the mid ( up to 3* included )
    Yes I have tried a two piece belly like a sharp hump back - no power/no loss.
    But the shallow first cone in a 3 cone rear setup does conserve some of the finite wave energy to be made available later down the TL.
    Hydro forming causes huge controversy in the pipe community in that some will swear by it , but I spent months at JL learning how to do it " properly ".
    The vital part was using steel platens in a press to prevent the larger diameters from blowing out first , and finally I could make real nice looking pieces.
    But no matter what , they always lost around 2 Hp to my hand welded cone pipes , on the dyno mule Rotax 125 used to test for the 256 used in Superkarts.
    I made a split clamp thing to hold the belly section straight and round and got back 1/2 a Hp.
    The smooth transitions between sections always lost 1 1/2 Hp and we ended up having CNC press tools made for just the labor intensive curved header section of the front pipe.
    And I noted years later that's how the nice pipes were made on the KTM250GP.
    Note the sharp end of the pressed header.
    I got to talk to a Honda engineer at Silverstone where we were testing the new ZIpKart one weekend and asked about the split formed pipes they always made.
    He said it was done using split female formed tools in an " explosive " process to ensure sharp angles were created.
    Lost in translation somewhat , but Boom was the operative word.
  5. #38945
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    The irony of this is as long as the home hobbyist pays attention to the details when making there pipe, it will be as good as a factory pipe.
    . . . That shit's Nasty.
  6. #38946
    east yorkshire uk
    its at the point where the diffuser meets the belly and where the belly meets the rear cone. those are the only two angles where any waves created are not wanted. in fact for the first third of the rear cones length im guessing those waves created are wasted on what i want for this front side cruising pipe.
    wobblys boom moment noted - re sharp angle changes.
    where you want them.
    i was told any change in angle would trigger a returning wave. for that reason i was talked out of a twisty curly snail like pipe i'd made. whose many angles would rob energy. you do get told a lot of conflicting info on the net though.
    i was told the waves are molecules handing over their energy to adjacent molecules and so on.
    to my thinking the molecules on the outside of the diffuser when reaching the belly joint are suddenly forced right left or up down ie off trajectory and are behaving as if the diameter has changed. if not then they are in touch with their cousins 100mm away etc on the other side of the diffuser and have permission to carry on regardless. which seems a bit far fetched. but then again the whole process what happens inside the pipe is almost unbelievable and like magic.
    im making one pipe with 10mm blending in sections either side of the belly and one without. plus 3 baffle/end cone combinations for each pipe.
    hopefully mr dyno will be happy.
  7. #38947
    A change in section area is not the same as a change in directional vector due to a pie cut , as in the second example there is no change in area.
    Of course there are limits , and from experience I can say that a pie cut closer than 50mm from the port will affect power.
    From observing the wash pattern in the duct it seems that any angle not on the vertical plane creates an asymmetric plugging action on the A/F stored in the duct.
    And where a pipe is bent in one plane , like a KZ rear facing one , having the cone seam joints on the outside , looses nearly a Hp to a pipe with all the joins on the inner radius.
    I didnt believe it , but was told to do it to the laser pattern .dxf by TM , and yes they were correct - humble pie.
    As a general rule having pie cuts greater then 7* ie a 14* bend with 180* rotation will create turbulent eddies and power reduces.
    The idea of having a " blending " section in front of the mid belly joint , will simply replicate the construction of a hydraulically formed pipe.
    In a race only engine this lost power - but maybe having a slightly longer diffuser is what was needed anyway in a road bike application , and it may in fact be an advantage.
  8. #38948
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Wave reflection
    Strictly speaking, the friction between the gas and the pipe wall also sends a very small positive wave back. This is one of the reasons a very long pipe on a low revving engine never seems as efficient as a short pipe on a high revving engine. A curve in a pipe increases this friction losses and does have an effect although small.
    Comparing a blown pipe with an armadillo pipe the armadillo pipe always seem to win by a small amount. My thinking, although unproven, is that the sharp transitions scrub off the developing boundary layer and makes the wave see the full cross sectional diameter and / or minimizes the losses from the friction. How to prove and measure this without a full blown laboratory I do not know.
  9. #38949
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Hello,
    how to make search engine work of forum ? google no longer works on the site
    I want to display posts as results. there are no results or displays the list of entry topics
  10. #38950
    Another KTM example of sharp transition between pipe fat sections after pressed or exploded process. Semi mass production pipe from KTM 125 for Red Bull Cup.
ID:	354136   Click image for larger version.
ID:	354137   Click image for larger version.
  11. #38951
    Quote Originally Posted by aljaxon View Post
    you keep on reading your own thoughts in other peoples words.
    a change in diameter (or better, cross section as Wobbly says, because you could also make a square exhaust) is not the same as a change in angle.
  12. #38952
    23rd March 2015 - 21:24
    Conti RX356 V3
    there is also the "real" process of hydroforming, where you have a fullform negative die and a tube is pressed against the walls of the die oooor the parts could be simply deep drawn. both processes (if done properly) have the limitations of bending radius = ~1 x material thickness, so a transistion with t = 0,8 mm sheet metal can be made quite sharp.
  13. #38953
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Somebody talked about forming with explosives Daniel its possible to replikate surface of for example a money coin or even a oak leave absolutely sharp
    In german its called " sprengformen or sprengplattieren"
    https://de.m.wikipedia.org/wiki/Sprengplattieren
    Let us try with your pipe first Daniel? insert a handgrenade... duck and cover
    Grüße Wolfgang
  14. #38954
    Conti RX356 V3
    i know, i know but doesn't make much sense if standard methods can be applied (or sth was lost in translation). nor does boomforming remove material limits (e.g. minimal bending radius).
  15. #38955
    Right daniel...not without inside model...
    Which sharpness is necessary?
    Maybe a grinding job on Welding seam could do ...
