Page 2606 of 2774 FirstFirst ... 1606210625062556259626042605260626072608261626562706 ... LastLast
Results 39,076 to 39,090 of 41608
  1. #39076
    I used this very successfully for many years: Jamathi, Piovaticci, Bultaco...
    Well aware of this sir. Your development and use was argued very well by Frits when it was discussed on here several years back.
  2. #39077
    28th October 2018 - 06:30
    Tomos D6, Cagiva Mito
    Idrija, Slovenia
    The same design as Tomos is using it.
    If my memory is not at fault, one guy told me, patent was bought from Norton. In a time two companies cooperated.
    Jan, I have a question for you. I read your book and at page 78 and 95, you are talking about repositioning primary gears from between cranks to side drive on a Bultaco 125cc 2c.
    I wonder why is power gain so large? From 37 to 43hp you gained 6hp, that is 16% increase.
    Thank you for answer.
    The book was really nice reading I enjoyed. Thanks for taking your time to write it
  3. #39078
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    My guess is two bearings less?
  4. #39079
    Idrija, Slovenia
    My guess is one shaft, 2 bearings, one gear pair and maybe gears digging/splashing the oil. But 16% looks quite high number to me as gear pair loss is usually 1-3% of power. That's why I ask.
  5. #39080
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Quote Originally Posted by Peljhan View Post
    It was because the middle primary drive made an extra drive shaft necessary.
    Eliminating this with the side primary drive also reversed crankshaft rotation.
    I was amazed at the improvement!
    All other 125's had side primary drive, so we followed!
    My mistake was copying the Japanese engines which all had primary drive from the middle.....
  6. #39081
    2008 Yamaha fino
    Bangkok
    The book was really nice reading I enjoyed. Thanks for taking your time to write it :nice one:
    My problem was that I followed Japanese practice of putting primary drive in the middle, which causes a big power loss.
    Where this came from I don't know, probably MZ-Degner...
    Jorg Moller discovered this when helping Jos Schurgers to build the Bridgestone 125-2
    Using Bridgestone crankcases, they were practically 'obliged' to use side primary drive
    And discovered that it went very well!!
    So when Moller went to Morbidelli he made an engine with a side primary drive
    It was a BIG success!
    And I made a BIG MISTAKE, which cost me power for years to come.....
    The book was written by an Italian, it brought me a lot of satisfaction, we did it together using 'SKYPE!
    And it saved my life, because with the earnings we could pay a recent hospital bill.
    Without it I would be dead now..........
    I am very grateful to my friend Dolph van der Woude who distributes the books!!!!!!!!
  7. #39082
    2nd November 2023 - 23:26
    east yorkshire uk
    ...the nozzle with diverging cone at the stinger entry has been superseded by a short section with a step - more power.
    are there any diagrams of this anywhere please? ive searched this thread for stepped stinger entry to no avail
    apart from this reply you made ..
    "and , not having a slow taper exiting from a stinger insert.
    This should have a 45* step , and reduces the effect of the waves bouncing up and down the stinger , from the atmospheric end ( the muffler entry in the case of a KZ ).
    These can interfere with the main positive reflection off the reverse cone , as the + wave bouncing off the open ended pipe reverses sign and travels back to the stinger entry."
    but im struggling to visualise that.
  8. #39083
    Idrija, Slovenia
    Me and friends bought about 10 books combined. I am happy that it helped you as you helped us with 2t tips and tricks. Stay healthy!
  9. #39084
    23rd July 2017 - 21:59
    n/a
    canada
    Jan, are there any English version books left?
  10. #39085
    23rd March 2015 - 21:24
    Conti RX356 V3
    Quote Originally Posted by porttiming124 View Post
    jep, I just ordered one
  11. #39086
    Al , the sketch I did of the KZ stinger tells you everything.
ID:	354260   Click image for larger version.
Name:	TM U Bend Change_0001.jpg
  12. #39087
    east yorkshire uk
    i saw that a week ago but didnt realise that was the stinger diagram.
    i cannot fathom it out sorry.
    sorry to be a pain.
  13. #39088
    What is there to figure out - the stinger is a tube approx 3mm bigger ID than a nozzle insert that is up against the rear cone exit.
    There is a small taper on the insert entry to match the rear cone exit ID .
    The original insert was a tophat to locate it in the end of the tube , and the stinger tube fits into a short female spigot welded to the end of the rear cone.
    But the tophat , with the taper inside , in actual fact made the rear cone longer, so I cut it off.
    In the KZ I cut the stinger short so that the insert would push in , up to where the bend started , so it would not go in any further.
    And instead of a long slow divergent exit on the insert , I cut it to form a 45* step.
    The step has virtually no effect on the outgoing wave , but reduces the amplitude of the return wave bouncing back off the stinger exit.
    The small nozzle , large stinger idea was invented by Helmut Fath for Fast Freddies first NSR250GP Vee Twin , that had one stinger 150 long and one 450 long.
    That small , short nozzle basically all but eliminated the tune difference between the two pipes on the Honda.
  14. #39089
Name:	Jan Thiel in hospital.jpg
    Jan Thiel was urgently admitted to hospital two weeks ago. Three stents have been placed in his heart. He is now back home but it cost him a lot of money;
    healthcare in Thailand cannot be compared to what we know here. That is why a campaign has been started to support him financially.
    https://www.gofundme.com/f/can-you-h...ource=facebook
  15. #39090
    n/a
    canada
    Thank you Frits for the information on Jan's state of health.
    I just made a donation.
