Page 2618 of 2773 FirstFirst ... 1618211825182568260826162617261826192620262826682718 ... LastLast
Results 39,256 to 39,270 of 41592
  1. #39256
    2nd May 2020 - 21:05
    Aprilia RS125
    Barcelona
    Quote Originally Posted by Javier Ruda View Post
    Hello wobbly, just an idea. When the fresh mixture must be pushed back in the cylinder it will find an exhaust port that is diminishing the height until it finally closes. Compared to a longer stroke engine the shape of that port could have a worse Cd on a short stroke engine because it will be not so “square”, needing an additional time to push back the mixture.
    I think I was wrong. If the wave comes back earlier, it will be gone earlier too.
  2. #39257
    Na Frits , I was shooting for peak power@12500 with overev to 13,000.
    I simply could not get decent numbers @ 13000 , just as you said.
    Even @ 12500 the STA predictions were maxed out at 43 Hp , and with a clever pipe and some serious fiddling in the sim that is what it made.
    But it fought me every step of the way , detoing at the drop of a hat as everything was pushed so hard to get that theoretical ( but shit never the less ) result.
    Makes it obvious now why the 4DP was a lemon for all those years in the 90's.
    I know Rich Oliver won a bunch of USA titles with one - but even though the Yanks think so , that aint the Worlds by a long shot.
    We have discovered an old guy who won some All Japan Cup races - he has a pair of super special Sugo 4DP cylinders sitting on a shelf in his shop.
    Be interesting to see what was actually considered fast back then.
    But the more I look into it - the 3XV TZR cylinder seems far superior in ultimate power capability.
  3. #39258
    15th December 2022 - 06:58
    Tomos BT50
    Croatia, Virovitica
    Hi Frits,
    I have been customizing various exhaust pipes for the sims for a long time now. I try to compare most of those tubes that are published with the better ones.
    All pipes are connected to the same test model in the sim (50cc).
    They all have the same entrance and a total length of 825 mm. The output from the cylinder is a Wobbly (90%) concept.
    The initial model I started with was the basic FOS-tube model.
    I was looking for as much power and as wide a power band as possible, but so far none of the tubes have been better than these three (P1, P2, P3).
    Frits, are you interested in this and could you come up with a better P4 tube on the default sim model. Pipe which would be above these three.
Name:	Basic FOS-Concept.png
  4. #39259
    Without going back through old stuff and i am open to correction, but i think there was a tie up with Bud Askland and Rich Oliver at time. Pretty sure Bud had also tuned Kokinski 250 tittle bike.
    Is there room in the cases to stroke the engine to 54 ish.
  5. #39260
    Quote Originally Posted by skako View Post
    Hi Frits,
    Hi Skako, I appreciate the offer and I was curious enough to dive into it even though I don't really have time for it.
    I don't have any data on your engine so I couldn't check your diameters and lengths; I could only look at the length percentages of your pipe segments and I found clear differences. The FOS percentages are 32-34-8-26 and your percentages are 34-34-8.4-23.6. Your end cone in particular is markedly shorter.
    The maximum power of 10.2 kW or 13.9 hp in your graph requires a ุ 11,6 mm end restrictor diameter, but in your case it is ุ 13 mm, preventing the engine from building up pressure, exhaust gas temperature and revs. By the way, 13.9 hp is about 10 hp below the current 50cc top level.
    Finally you write: "The output from the cylinder is a Wobbly (90%) concept". But as I have mentioned repeatedly, you must not mix the Wobbly concept into the FOS concept.
  6. #39261
    4th November 2017 - 05:35
    '78 Bultaco Astro
    UK
    https://www.cycleworld.com/sport-rider/dominator/ - We Ride Rich Oliver's AMA Championship Winning Yamaha TZ250 - This motor hits hard, hits now and is tuned for a rider that values top-end steam over midrange drivability. Rich confessed, “My work goes toward top-end power. I spin my engines hard and that means I replace parts more often than most, but it's worth it to me. I've worked with some good tuners over the years and Bud Aksland has answered a lot of questions for me, helping me arrive at this particular combination." Oliver's right; most of the bikes in the AMA 250 field don't see 13,000 rpm all season and peak out between 12,300 and 12,700 rpm. Rich added, “If this was a national, I'd work on the jetting until it spun even higher.”
  7. #39262
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    13mm was dangerous, 11.6mm will still more be fun
  8. #39263
    13mm was dangerous, 11.6mm will still more be fun​
    If it's dangerous, remove the danger; don't increase it.
    But how is it dangerous? Too little cooling, too much ignition advance, compression ratio too high, squish gap too big? Bad fuel? All of the above?
  9. #39264
    Tomos BT50
    Croatia, Virovitica
    Hi Frits,
    I'm glad I caught your attention. I am attaching a graph with your last recommendations, from which I started researching the best tube for my model. I know that it is not the maximum. That's why I check possible combinations before cutting the sheet and making the pipe itself. I need to perform certain operations on the cylinder, which are very limited for my capabilities.
    If you can spare some time, I would appreciate your analysis.
    I can send you these few pack-files for a quick check.
    I apologize to everyone for some sentences that may not be well composed in the spirit of the English language because I use google translator to convey my thoughts.
Name:	Basic FOS-Pipe2B.png
  10. #39265
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    Skako, are those pipes/curves for standard gearbox or it is new independent sim?
  11. #39266
    Tomos BT50
    Croatia, Virovitica
    I need to transfer the characteristic of the pipe to my program and see it exactly (and this is done manually by typing, so it takes a long time). This way, at first, I can conclude that it can use a standard gearbox.
  12. #39267
    I am attaching a graph with your last recommendations, from which I started researching the best tube for my model.... If you can spare some time, I would appreciate your analysis. I can send you these few pack-files for a quick check.
    Skako, the length percentages of the pipe segments are still the only data I can check with the info I have available, and these percentages are now in line with the FOS concept.
    The initial diameter X is an important part of the concept and my first impression is that your 24,3 seems rather large but without knowing the exhaust timing, the cylinder capacity and the rpm of maximum power, this is just a gut feeling. But as I wrote yesterday, I don't really have time for it so I have to leave it at that.
  13. #39268
    1988 cagiva freccia
    france
    on a 50cc of 13 hp a stinger of 11.6 is equivalent to a stinger of 17 or 18 mm for a 125 cc of 30 hp.
    it does not exist and the temperature will soar and burn the oil film
  14. #39269
    Philou, you may notice a couple of things in my exhaust concept.
    1: The end restrictor diameter depends on crankshaft horsepower. The cylinder capacity does not play any role in the calculation of the restrictor diameter.
    2: The stinger, as you call it, should have an internal diameter of >1,2 x the restrictor diameter. For 30 hp that stinger diameter should be >20,4.
    I have no data of a 125cc engine that produces 30 hp, but I can provide you with data from a 125 cc engine that produces 54 hp at the secondary gearbox shaft, which corresponds to approximately 57 hp at the crankshaft. The restrictor diameter of that engine is 23.3 mm. Do the math if you wish.
    That engine did not suffer from soaring temperatures and it did not burn the oil film. It did win a number of world titles....
  15. #39270
    1988 cagiva freccia
    france
    23 mm is ok for a 125.
    the 1st series of jollymoto for 250 rgv (125 twin) had a 19 mm stinger which caused a lot of engine failure before moving to 22 mm.
    I maintain that 11.6 or 13mm is too small for a 50cc that produces some power.
