Page 2619 of 2773 FirstFirst ... 1619211925192569260926172618261926202621262926692719 ... LastLast
Results 39,271 to 39,285 of 41591
  1. #39271
    23 mm is ok for a 125.
    the 1st series of jollymoto for 250 rgv (125 twin) had a 19 mm stinger which caused a lot of engine failure before moving to 22 mm.
    I maintain that 11.6 or 13mm is too small for a 50cc that produces some power.
    I wrote that a maximum power of 13.9 crankshaft-hp requires an 11,6 mm end restrictor diameter. I also wrote that 13.9 hp is about 10 hp below the current 50cc top level.
    Now what is your definition of' "a 50cc that produces some power" ?
    As for the RGV250 example: a well-prepared RGV250 engine can produce about 70 hp at the wheel or about 40 crankshaft-hp per cylinder.
    This requires restrictor diameters of 3,1 x Square(40) = 19,6 mm and stinger diameters of at least 1,2 x 19,6 mm. You do the math again?
    PS: it may be useful to make a clear distinction between restrictor diameter and stinger diameter.
  2. #39272
    15th December 2022 - 06:58
    Tomos BT50
    Croatia, Virovitica
    Hi,
    I want to thank Frits for the additional comments.
    After this I made minor changes to the pipe, by A.I. designed for the AR93.
    The obtained characteristic is much better.
    yatasaki,
    here I transferred the characteristics of the standard Tomos gearbox to the graph.
    It can be seen that the gearbox fully utilizes this power in the graph.
    Good elasticity for your ride, on the kart track in VT.
ID:	354436Click image for larger version.
  3. #39273
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Quote Originally Posted by skako View Post
    Try to model it in the vehicle performance part of Post2T and also show the Power Range as done in Post2T.
  4. #39274
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    Bridged port wings hooks
    TZ350
    If I remember correctly to use these hooks it's better to have plugs in the piston pin ends. If not the shallow hooks are better. If I remember correctly???
  5. #39275
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    [QUOTE=skako;1131223231]Hi,
    I
    yatasaki,
    Red curve from other graph is which I like, it would suit smaller carburetors and angles we use. I found belly diameters larger than 80mm not benefitial in our applications.
    If using FOS concept you have to use different coefficient for belly diameters.
    But as Frits mentioned FOS concept is general starting point.
  6. #39276
    Tomos BT50
    Croatia, Virovitica
    Hi Vannik,
    I tried to put something together from Post2T.
    I'm not sure if you meant this or something else.
    The longest straight section of the trail in VT is approx. 115 m.
    They occasionally race here with Tomos mopeds.
ID:	354439Click image for larger version.
ID:	354440Click image for larger version.
ID:	354441Click image for larger version.
ID:	354442Click image for larger version.
    OK I see now, I will make an addition.
  7. #39277
    Skako, if you rev the engine to its maximum rpm in each gear, you are not using all the available power. If you upshift not at the black, but at the green vertical lines, where the curves intersect, you get the yellow parts of the available power as a bonus.
Name:	gearshift points.png
  8. #39278
    Tomos BT50
    Croatia, Virovitica
    I know this because near the end of RPM the difference in available engine power is zero.
    The power equalized with all driving resistances (air resistance, rolling resistance).
    It is ideal, as you say Frits, to jump into a higher gear just before the end of the RPM at the moment when the power difference becomes equal to the initial power in the higher gear.
    In the attached graphs horizontally, from the right curve to the adjacent left curve, you can see how much the RPM drops in a higher gear.
    The graph below shows the excess engine power in top gear over the required power at those RPMs.
    In the attached graphs, I have drawn the characteristics of three gearboxes.
    Standard 5 speed, sport 5 speed, sport 7 speed.
    I can only say that this 7-speed sports gearbox is not at all comfortable for everyday traffic around town. It's great when you need to accelerate.
    Great traction and acceleration. But when the vehicle in front slows down a bit, you almost regularly have to downshift two gears.
    In heavy traffic it becomes very irritating for the driver.
    However, on a road with slightly less traffic, it's real enjoyment and melody from a small 50cc engine.
    Attachment 354448Click image for larger version.
ID:	354451Click image for larger version.
ID:	354450Click image for larger version.
ID:	354449Click image for larger version.
    Somehow the final speed of 135 km/h in the earlier post seems too optimistic to me. I kind of trust my conservative chart more. It is closer to the reality of the required power and speed of a moped.
  9. #39279
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    new ECU new math suited for 2-strokes
    Hello folks. After some experience with Megasquirt and Speeduino I create my own digital injection and ignition board.
    2ign +2inj channels 2layers 36x50mm ECU which consists of 80% components produced in Russia and 20% of Chinese components.
    100% local possible but would increase PCBA size to 42x58mm.
    The board in next version planned to be a bit smaller and completely integrated into throttle body.
    New version will reworked for other 7.5x7.5mm Russian processor, working at -40...+85C
    Rewritting math as well to be suited better for 2-strokes.
  10. #39280
    A little collage of my injectionbuild.
    I actually got it working really good now when changed the fuelstrategy from only tps based, to tps and pipe pressure.
    Still based on tps, but fuel compensated against pipe pressure, works really really nice.
    In the future i might also compensate ignition some also against pipe pressure.
    Look around in my youtube channel, there are video of dynoing all the way to a little mishap(crank seized)
    But parts are ordered already =)
  11. #39281
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    Just a suggestion, have you considered the possibility that a non-mapping injection would be better?
  12. #39282
    1997 Yamaha rd 350
    Russia
    2-stroke injection
    My project is only started and my exhaust system for amateur aircrafts and paramotors rather primitive.
    It will be long way to achieve results. May be to the end of the year. But I will try implement all essential ideas.
    The problems I encountered to the moment:
    - dynamic performance of fuel injectors are complicate and not so primitive like in math of Megasquirt and Speeduino
    - software make wrong fuel correction it themperature below -18
    - wrong fuel corrections on altitudes more than 2000meters
    Will try find couple of good students and give them to implement some math
    I open to all ideas. You meant some kind of many dimensional interpolation?
    In my first experiences I playing with exhaust gases themperatures making them stable about 650C instead of use Lambda.
  13. #39283
    Tomos BT50
    Croatia, Virovitica
    Quote Originally Posted by vannik View Post
    try to model it in the vehicle performance part of post2t and also show the power range as done in post2t.
    I did it with Post2T and it's good that there is a Power Range in Post2T. I transferred the characteristic power points to excel and made my specific diagrams related to the gearbox. In them I can see the same data better. I will try to describe the method through graphs. There are more graphs to explain what they represent and how to read them, but I can only post 6 of them in the post.
ID:	354465Click image for larger version.
ID:	354464Click image for larger version.
ID:	354460Click image for larger version.
ID:	354461Click image for larger version.
ID:	354462Click image for larger version.
Name:	Comparing6 Acceleration Power over 5_gear after changing 4-5.png
  14. #39284
    Daelim besbi 2008
    España
    Use a method that YAMAHA patented and is now available. It's very simple (if the reeds are curved, the injectors inject)
  15. #39285
    Tomos BT50
    Croatia, Virovitica
    Here are three more graphs to complement the explanation in the last post. The engines are adjusted to have the same final vehicle speed that requires the same power. All further comparisons are made from that point.
Name:	Comparing7  ideal moment to changing gears-4-5.png
ID:	354466Click image for larger version.
Name:	Comparing8  ideal moment to changing gears-4-5.png
ID:	354467Click image for larger version.
Name:	Comparing9  Power and changing gears-4-5.png
There are currently 136 users browsing this thread. (1 members and 135 guests)
  1. Wos
