Page 2623 of 2776 FirstFirst ... 1623212325232573261326212622262326242625263326732723 ... LastLast
Results 39,331 to 39,345 of 41626
  1. #39331
Name:	RG50 Insert (1).jpg
    Looks like the piston has been tapping the insert. Skimmed about 0.004" of the face of the squish.
Name:	RG50 Insert (2).jpg
    Pleased to see the plug thread cooling fins look like they have had water passing between them.
  2. #39332
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    I found the long body fitted better on my Husqvarna bike but each to there own.
    It was more to dirt jbiplane towards Victa mowers, which may be uncommon in Russia
    (PostalDave on ADVrider)
  3. #39333
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    How does it work and how many seconds to open again after a failed try?
  4. #39334
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    the black plastic fitting on top of it is for a vacuum line and work's like a vacuum operated fuel tap but the other way around no vacuum(motor not running) it's open and no compression. Vacuum (motor running) it's closed and has compression.
    . . . That shit's Nasty.
  5. #39335
    1991 MZ 301
    Denmark
    Thank You for explanation of the obvious.
    Way smarter than using compression through a one way valve.
  6. #39336
    So when the engine is not running, the valve is open. Then how do you generate enough vacuum to close the valve?
  7. #39337
    24th April 2016 - 19:07
    2001 zx9
    bop
    Even though those Victas were australian they were keen to work ... so partial compression was enough for them to start and once running the small volume on one side of the diaphragm had its pressure drawn down by the vacuum line going to the downstream side of its (quite small) carb
  8. #39338
    1991 MZ 301
    Denmark
    For the benefit of all mankind:
    Can someone from down under, make or point to a video showing start of a Victa lawn mower?
  9. #39339
    2001 zx9
    bop
    The girlfriend has offered to start the lawnmower here but i don't know how to work the video recorder ... sorry mankind
  10. #39340
    1971 suzuki T350R
    the best island
    The valve is tiny, so if you turn over the motor fast enough (like when you kickstart a dirt bike) all the air in the cylinder can't get out of the cylinder before it sparks. So it does have some compression but more like if you left out the compression ring when rebuilding a motor. It makes starting big bore 2 strokes easy.
  11. #39341
    1971 suzuki T350R
    the best island
    Amazing enough there is web site that has old Victa 2 stroke mowers on it. I saw it when setting up my Husqarna. Husaberg it's your time to shine!
  12. #39342
    1971 suzuki T350R
    the best island
    How embarrassing, I was so busy tapping out a reply I didn't see your better reply.
  13. #39343
    I've got a 500 Maico Enduro in the workshop. The decompressor for those is a manual valve about 1/2 way up the back wall of the cylinder, rather than in the head.
    So it's more like starting a 300 rather than the full 490cc. Once started, it will run happily, but noisily, with the valve held open.
  14. #39344
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    Automatic decompressor
    Thank all peoples for decompresion valve ideas!!!
    I own 8 CNC machines and will try make automatic decompression valve.
    For me easier make than buy.
  15. #39345
    One can never have too many CNC machines
