Ah. Are KZs run on full tracks? I'm stuck thinking go-kart tracks with 30second lap times.
Hamilton kart track has a mid 40s lap time and we pull 145Km/h on a good day.
Road racing on full circuits is a whole different class of racing.
I've raced about ten kart tracks in NZ, but never been to Hamilton. Two wheels only.
We raced with 50cc on Grobnik Rijeka circuit in Croatia, and accelerations were like 30s long and we have 80% of the lap full throttle. Sometimes there is really strong head wind and I needed to shift from 5th to 4th on a straight because I only had 14hp. It is very different kind of racing compared to gokart tracks and I been with my bike on both.
https://www.youtube.com/watch?v=N2Trr21edn4&t=5s
14 hp is excellent actually
Rob that main port needs way more chamfer.
Not finished yet, still more work to do. Main Ex timing needs to be opened up and port widened to get the needed STA.
I just had to show off my eyebrow tunneling. Did not think it could be done nicely, but it looks like it is going to work out Ok.
Speedpro helped a lot by making the initial eyebrow cut with his mill.
Watch my space on the tube the coming days/weeks.
https://www.youtube.com/channel/UClY...NLN9TGXDqxr0EQ
I have updated my TZR250 (1KT) engine and will be searching for new higher numbers.
Longer rods with uprated bearings.
Reshaped crankhouse(welded and ported)
Reshaped heads for more possibilities to rev higher.
Larger injectors, might run methanol in the future.
Slightly increased timings
And ofcourse refurbishing, new bearings and new pistons.
Assemble video out now!
@6:28"very small amount" (of sealant on the crankcase)
that is a lot of sealant
I only ever use so litlle, that I can still see the colour of the material under the sealant.
I couldn't see what sealant you were using but I've experienced issues with using the incorrect sealant where it is contacted by fuel. I now use ThreeBond 1104 NEO plus. The spec sheet says it is suitable for use on fuel pump flanges. So far no problems. I got onto it after bumping into an ex ThreeBond employee at the supplier.
150cc two strokes. Might be time to look at a F4 rule change to allow us two strokers to be able access more modern engines and regain some competitiveness with the fast four stroke guys.
i wish i was able to use solidworks. ive only just took the time to learn how to use autocad on a basic level.
i saw this video
around the 2min 30 mark he uses mota8 to do an optimisation of the pipe. dunno if its able to do that with any accuracy or if its just a gimmick. i guess we will find out soon enough. the video maker says engmod2t is far superior in every way to mota8 but he was intrigued by the pipe optimisation feature.
There are currently 50 users browsing this thread. (0 members and 50 guests)
