Page 2629 of 2774 FirstFirst ... 1629212925292579261926272628262926302631263926792729 ... LastLast
Results 39,421 to 39,435 of 41608
  1. #39421
    A wider C port is not optimal ,and means the B rear wall cant be moved around as much.
    The big issue though is the dumb rectangular Aux port - even looks like the useless 4DP.
    You would have to weld up 1/2 that port to get the triangular shape needed to prevent vertical short circuiting , and reduce the effect of port linking
    to the A via the small end hole.
  2. #39422
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    The 3MA cylinder I have looks like just like the one 41juergen posted. I think you have helped make up my mind, The 3XV seems to be the one to use.
    . . . That shit's Nasty.
  3. #39423
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Re spark plug projection: Removing the plug washer is a trick used in karting to get the spark closer to the center of the combustion chamber. I have no data on how much if any this helps.
    Lohring Miller
  4. #39424
    Plug projection - yes and no. I spent hours setting up the long version R7282A -105 used in Honda's with under plug deto sensor to remove the extra 3mm of thread
    to have the electrodes well into the combustion chamber middle. Made no difference at all in a KZ.
    But Frits has done a similar thing by removing the bare unthreaded end of a conventional plug , and reports that its as good as the all conquering R7376 for way less dollars.
Name:	modified spark plug-01.png
  5. #39425
    18th November 2020 - 03:49
    1975 Bultaco Pursang 250
    Barcelona
    A Bultaco head, isn't it? All Bultacos I've worked on had long reach spark plugs so I wonder what type yours is.
    Anyway, never fit a short reach plug in a long reach head or vice versa. And if your head was modified from a short to a long reach plug, chances are that it was not the only modification, so you may forget about the manual in this respect.
    Hi Frits!
    Thanks for the reply. Yes, It's an early Bultaco head yes! It has that typical "trench" combustion chamber.
    You're right, all Bultacos have long reach Spark plug, except the 100cc and 74cc models.
    The bike I'm rebuilding is a Lobito AK 100, a factory racer based on the Lobito trail bike, to compete against Hodakas in the 100cc class in the US.
    It seems to be stock, I can't see any modification to it. I've asked a friend that has the same model and he sent a picture, and the same happens:
    So it must be this way from the factory, but I don't know why. I've tried using a long reach spark plug and protrudes around 1mm:
    What would you do? With this being a 100cc engine with a 14:1 head, using one plug or the other is going to affect the compression ratio considerably also.
    Thanks in advance!
    Lohring Miller
    Hi Lohring!
    Thanks for your comment. Funny considering this cylinder and head where designed initially for the 100cc direct drive kart class.
    The picture above is using the plug washer and a long reach plug. It protrudes about a mm.
  6. #39426
    I have searched again many times , but cant find the original NGK technical bulletin that said the new range of plugs with the end threads removed , were actually intended to protrude exactly that 1mm.
    Any body protrusion into the chamber is specifically banned in many kart classes , but the electrodes are not " the body " , just a piss off it didnt work in the KZ.
  7. #39427
    The water cooled, twin exhaust port, twin blade powervalve cylinder slowly happening. A first I believe?
    I might retain the cylinder from underneath so as to get more exhaust port wall access to water cooling.
  8. #39428
    Anyone rolling exhaust cones?
    You need one of these:
    https://www.facebook.com/share/r/trQ...ibextid=oFDknk
  9. #39429
    1971 suzuki T350R
    the best island
    Ugh!
    I must spent two minutes watching that( the video is only 5 seconds long)
    considering how long I have spend fighting manual rollers I am green with envy.
  10. #39430
    10th April 2013 - 09:59
    Honda NSR 50
    Netherlands
    https://youtu.be/KX6FnYgXdHM?feature=shared
    Just because it can be done
    I’m stunned that this even runs, especially when using such rudimentary tools.
    Verzonden vanaf mijn iPhone met Tapatalk
  11. #39431
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    This guy must have watched an Allen Millyard video then turned to his buddy and said "hold my beer"
    Quote Originally Posted by JdG View Post
  12. #39432
    12th March 2011 - 02:31
    r6ypvs hybrid
    BRC making progress on it's 600 twin. Posted an update and pix on Facecrack. He was clear that Frits, Jan and Wob were a lot of inspiration and it shows in transfers, exhaust and cooling regimes. If only there were more 100, 125 and 175 cc "street" cylinders similar.
    https://www.facebook.com/brcracingca...eric&ref=notif
  13. #39433
    26th April 2013 - 21:55
    BMW R1200R 2009
    Cooperation between some of the best technicians, and the most knowledgeable two stroke geniusses from canada, the netherlands, and new-zealand.
    I hope this cylinder can be bolted on the KTM 300SX cases.
  14. #39434
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    Electronic unit for starter generator
    My tear create Electronic unit for starter generator.
    It is possible use offshelf brushless motor to start engine.
  15. #39435
    29th March 2020 - 09:23
    Yamaha RX 115-135- RS100, Suzuki AX100
    Colombia
    Big End Oiling
    Great info Wob, thank you!!
    Man that would make it all much much easier!
    Hey guys I was searching around for the big end oiling options and couldn't find anything about it here, if someone can point me to the right page would be greatly appreciated.
    The most I've found online is this....Click image for larger version.
ID:	354679Click image for larger version.
