Try prox they have an order frrm they do center pinned KTM200 in suitable sizes but not sure in the center pined are single ring.
We have a Japanese interpreter available on ESE as well.
https://www.pro-x.com/wp-content/upl...NICAL-2023.pdf
Husa ,I researched the KTM from PROX the 01.6249 and it says the ring pins are 1.75mm off the center , so two ring , but almost over each other.
Unless I simply leave the second ring out.
Looks like the Meteor TZ350 is the go atm , unless TKRJ decide to reply at all.
Re the YPVS pipe design , the customer is not keen on me publishing it at all , so end of.
But here is the TZ250 - 3XV latest iteration , thats being fitted to the bike as we speak.
The designs are very similar , with the Wobbly duct generating 0.8 Mach and the concave rear cone setup at about the same diameter , but this has peak Hp at 12750 , the RZ350 is at 10750.
The TL is 965mm but I didnt tell you that.
Sorry I was looking at some others that were single ring for KTM200 then looking at the 66mm 250 ones and got a bit confused as some of those are prox single rings.
here is a single ring pined in the rear at least in the pic
https://www.amazon.com/Namura-Top-En.../dp/B00T6JKANS
I am looking for some guidance for what to use for a stand alone det detector.
Googling det detector brings up a bunch of HRC models which don't seem to be available any more.
but searching for knock detector instead brings many 4 stroke solutions.
are the Link products good?
thanks
I have used this on my dyno for over 10 years and sold dozens to customers - works perfectly
https://www.ebay.com/itm/11617450300...1071f2124381e9
Started a new little project, so i´m presenting it here with a little shoutout as i am searching a head for this engine. (SGM Maranello GA207)
Anyone got one lying around to no use?
So how can i destroy this the fastest easiest way without using violence? =)
Thanks Wob!
Dear Jan, Dear Mentor:
Happy Birthday to You !!![]()
Some help needed for this gentleman I think.
If it has been linked before here I have missed it
https://research.chalmers.se/publica...4_Fulltext.pdf
So we now have a proven 50Kw turbocharged 125cc 2T engine = 67 Hp.
Im so happy he did not destroy the whole project by claiming it would rev to 30,000 rpm - if you are reading this Luc , note well.
Also the complete dismissal of a supercharged system , with verifiable logic as to its unsuitability , is something I tried to convince Two Stroke Stuffing of 3 years ago.
The 30K straight came from the horse ass I mean mouth...
https://www.f1technical.net/forum/vi...0966&start=645[LUCFLucF
0
Re: 2 stroke thread (with occasional F1 relevance!)
0
Post 07 Aug 2015, 00:35
Ryger Engine built by Mcd Twist Ryger Engine
125 cc, over 80% less emissions, 70 bhp, max. rpm 30.000.
Ryger Engine production running in high gear in order to meet cik regulations.
I can't find the button to attache pictures!! So .... https://www.facebook.com/mcd.twist.9?pnref=story
He also claimed to have had somewhat fictitious conversations with me via PM where it seems I claimed I would not share the patent holders name.
There are currently 112 users browsing this thread. (0 members and 112 guests)
