Page 2635 of 2776 FirstFirst ... 1635213525352585262526332634263526362637264526852735 ... LastLast
Results 39,511 to 39,525 of 41626
  1. #39511
    4th November 2017 - 05:35
    '78 Bultaco Astro
    UK
    I havn't run them yet but I've got 14.8V LiPo radio control batteries to try in a total loss Ignitech set up.
  2. #39512
    I'd peak power at 13 and overrev from there. Running a convential cheapo rec reg and capacitor I could all gears it through the gears on the dyno reading a meter (or pc) and the Voltage would not drop.
    CR250 alternator was enough to drive as well as an electric water pump. Are you over thinking things?
  3. #39513
    Tim Ey , why would you need Special , unless running odd numbers of lobes to use a unusual rotor setup.
    You need this when cutting one lobe in 1/2 for example to get proper twin fire on a RD/LC/RZ/Banshee
    The Ignitech will be just fine on a 14.2 V normal charging system as long as you run the Ignitech coil , or even better the RGV/ RS Aprilia 125/250 coils.
    Going to 15,000 with 14.2V charging from a CR250 stator was no issue on a KZ.
    But for example the Ignitech will not function at all with a stock Honda RS125 coil as the primary resistance and inductance need to match the DC-DC Converter
    and Honda did the matching in a different way.
    I have run 15.6V Lith/Ion lightweight batteries to 14,000 on a twin with no issues.
    I think you get a warning on screen over 16V and it will auto shut down above this level - 18V is impossible , or it used to be , maybe this has changed recently.
  4. #39514
    15th May 2017 - 14:26
    2002 Aprlia RS125
    For example the Ignitech will not function at all with a stock Honda RS125 coil as the primary resistance and inductance need to match the DC-DC Converter
    I have run 15.6V Lith/Ion lightweight batteries with no issues.
    I think you get a warning on screen over 16V and it will auto shut down above this level - 18V is impossible.
    Woobly.
    Is there a source for coils you could recommend. I am currently running total loss and the coil that came with the KTM
  5. #39515
    The RGV/RS Aprilia are available from bike wreakers , but are cheep as chips on Ebay.
  6. #39516
    23rd July 2017 - 21:59
    n/a
    canada
    Hello everyone.
    I have an exhaust runner to fill in the bottom part along the entire length.
    My runner is quite long (72mm) and it's difficult to access it with the tig torch.
    I think I've already read Woobly or someone else recommending Hobart brazing rods as an alternative.
    Can someone enlighten me on this please?
  7. #39517
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    Yes. Most probably.
    The manual states that the ECU operates from 8-18V and shuts down above 20V.
    I never got the issue that the engine did not want to rev further. Just wanted to see if anyone got other information. Thanks!
    Wob: To be honest, I do not know how I got to special settings. I am using Ignitec stuff since more than 10 years. Looking back I apparently started using "special" three years ago. I do not know how I ended up there. Back to classic it is!
    RGV/RS250 ignition coil is a must have.
  8. #39518
    So no hand drawn Dyno files or CAD renditions - here is the real thing finally.
    3XV going onto a 4DP , Ive got the hardware , now the hours of epoxy and porting starts.
    Then onto the dyno to do the changes needed for the PV ,PJ and Ignition to suit the EngMod cylinders and pipes.
Name:	3XV Inner.jpg
ID:	354762   Click image for larger version.
Name:	3XV Cylinder Head.jpg
  9. #39519
    You can use aluminum stick welding repair rods to fill in a duct - its easy as its so small and you can see what's happening.
    But the trick is to angle the part such that the liquid flux material runs away from the new weld pool , this helps prevent porous holes in the filled in material.
    Of course vapor blasting and or chemical etching away any old oil contaminants is mandatory.
    Even then its not what you would call " pretty " but hey its supposed to make Hp not win a beauty contest.
  10. #39520
    n/a
    canada
    I just had the nichasyl removed from them, they are very clean. Thanks Woobly for the recommendations.
  11. #39521
    21st March 2014 - 22:00
    Hanau, Germany
    Looking forward to see the results!
    BTW: I'm prepraring 3MA barrels with the same idea now, let's see how this will work out...
  12. #39522
    41jueurgen - I did look at the 3MA but the boost port is miles too wide and way below BDC , also wasnt sure as its fitted backwards if the stud pattern is the same as 3YL/4DP and if the cylinder bore
    is Desaxe offset.
  13. #39523
    Hanau, Germany
    is Desaxe offset.
    Of course you are right, but these cylinders will go on a 3MA engine.
    Will see how far I can narrow the C port either with welding rods or welding itself. The plan is to shape the A port to a tear drop shape to get the aux ex port right..will show pics how far I can get..
  14. #39524
    Used to be 18Volts. I run a 5.0 Amp hour 18Volt Ryobi battery drill battery with my DC CDI 2 race Ignitec. I think they must have lifted the Voltage celling to 20Volts. Anyway it works Ok for me.
  15. #39525
    Best check if CDI-2 and Race version if going that way.
