Page 2642 of 2776 FirstFirst ... 1642214225422592263226402641264226432644265226922742 ... LastLast
Results 39,616 to 39,630 of 41630
  1. #39616
    My understanding was in the Aprilia they originally used a stepper motor and it could progressively shut off the flow I assume using a needle valve.
    It was an idle control stepper motor off a Fiat uno. I think they later went to a Keihin part.
    Exactly
  2. #39617
    PISTON PIN PLUGS.
    As it turns out, Vortex have been making plugs for their 60 cc MiniRok kart engine for some years. So, if you've got an engine with a 12 mm pin, here's your chance. Approx 15 Euro each from Mondo Karts. Looks like some form of PEEK high temp material and most likely from bar stock.
    Begs the question as to whether they do (or could do) a version for their (or any) KZ engine with the usual 15 mm pin. Obviously the dimensional relationship of the circlip groove to the adjacent piston skirt face would have to be maintained.
  3. #39618
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    pin plugs
    I ordered a set of these awhile back but never did get them, so I made my own from torlon. I purchased a foot long rod and I have alot of material left-over. I designed them just like Frist's pictures and have had no problems. I used them on a KTM314 motor. Fantastic motor! It was used for GNCC racing here in the states.
  4. #39619
    26th April 2013 - 21:55
    BMW R1200R 2009
    314 ? Did you stroke the crankshaft ? Or is it a big bore ?
  5. #39620
    1980 Suzuki Gs1100E
    SWPA
    KTM314 motor
    Peter
    Stroked 3.5mm with a clean-up bore. (72.16mm I think?) And it seems I was mistaken. The cc's only come out to 309cc's. I built a Yamaha engine to arround 314cc's or something like that.
  6. #39621
    After alot of on line research here is what I believe is the simple/cheap version of a solenoid PJ , as the idiot price original is now NLA..
    The tube solenoid just needs a threaded adapter to the much cheaper and still available Mikuni standard PJ kit , and a jet or insert fitted inside the holder that is much bigger than that used in say a Lectron powerjet system.
    https://www.summitracing.com/search/...power-jet-kits
    https://nz.element14.com/ledex/19520...ous/dp/1331806
    Here is a setup I have cobbled together from bits I had in my parts boxes - perfect for Mr Pig if he wants it.
    This combined with the lever type TPS ( same as PWK style ) now available on the new Lectron carbs would be the trickest setup.
  7. #39622
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    It must be new I could not find it on there site. Must not of updated the site yet.
    . . . That shit's Nasty.
  8. #39623
    Can we get .mov video added to allowable file posting on here ?
  9. #39624
    I have asked the site techy administrator.
  10. #39625
    Having .PDF allowed would be fine too. I'm testing it now. So if I succeed, you can forget about this post.
  11. #39626
    12th March 2011 - 02:31
    r6ypvs hybrid
    It worked for me Frits. Firefox and in the US.
  12. #39627
    Android here, working well.
  13. #39628
    24th August 2023 - 06:21
    1966 vespa nuovo 125
    England
    Hi all, 1st post on here but what a thread this is, taken a while to read but have a few pages left, brilliant
    Re- polini carbs, out of the box they are proper shite and the reason being is that it doesn't have a normal 2 stroke needle shroud, this makes jetting nearly impossible with wot needing bigger jets an richer needles, I have one on my lambretta and had to get the lack of shroud pressed out and a normal one pressed out
    I'd get a genuine pwk 33 or 35mm
    I have a pwm 38mm on my 28hp vespa polini 130 road scoot and its easy to jet and needle
  14. #39629
    I tested the Keihins back to back for the SKUSA Stock Honda classes , the PWM is easily the best.
  15. #39630
    Strange, I've had little to do with PWM as PWK so ubiquitous esp in dirt circles where we feed a lot of parts from.
    Attack of the Clones: I see Aliexpress etc offer PWM things too. Buyer beware in my opinion.
There are currently 51 users browsing this thread. (0 members and 51 guests)
