Page 2656 of 2774 FirstFirst ... 1656215625562606264626542655265626572658266627062756 ... LastLast
Results 39,826 to 39,840 of 41608
  1. #39826
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    What cylinder are you using, TZ350?
    . . . That shit's Nasty.
  2. #39827
    RG50 cylinder with the original inlet tract sealed up with Kneed-It putty. Also for the RV, the left side case was filled up with Kneed-It too before milling it flat for the rotary valve and cover.
Name:	Suzuki RG50 RV Conversion (2).jpg
ID:	355034 Click image for larger version.
Name:	Suzuki RG50 RV Conversion (1).jpg
  3. #39828
    Um, have you not made a conventiinal boost port by cutting up to the two rear ports the and blocking the transfers from them?
  4. #39829
    Here is the setup for Lambda used on the CR125 in SKUSA
  5. #39830
    Rob, did you have to cut the end of the crank to fit the carb directly to that stub?
  6. #39831
    Yes. It is also where the ignition trigger gets installed.
ID:	355037 Click image for larger version.
ID:	355040 Click image for larger version.
Name:	Finished first Half.jpg
ID:	355038 Click image for larger version.
ID:	355041 Click image for larger version.
Name:	RG50 Rotary Valve Conversion.jpg
    This is how I went about it.
    I used all the rotary valve parts from a Suzuki GP125 and flywheel.
    1) Salvage the crankshaft hub from an old flywheel.
    2) Cut the thread off the end of the crankshaft.
    3) Drill and tap the crankshaft for a M5 screw.
    4) Machine the hub and crank flush. Then machine 0.005" five thou off the end of the crank to give some crush on the hub. You only just want it gently squeezed, just enough to hold it securely but easy to get off again.
    5) Make a spacer with about 0.010" ten thou clearance between the hub and the rotary valve driving dog.
    6) Insert a 2-3mm thick "O" ring in the face of the spacer to give it some crush on the RV driving dog.
    7) The hub is keyed to the crankshaft. Screw a M3 dome head into the hub for the ignition trigger at the appropriate timing position.
    8) Crush the dome head in a vice to collapse the Philips star. You need to do this so you don't get two ignition pulses close together. One from each side of the Philips dome head screw.
    9) At TDC drill a 5mm hole in the crank shaft for the RV driving dog's driving pin. 5mm fitted the key way in my Suzuki RV driving dog. I cut an old drill bit down to use for the pin.
    10) Used a short piece of hose and two hose clips to secure the carburetor to the inlet stub. I put a larger "O" ring inside the hose to prevent metal to metal vibration contact between the carb and stub.
  7. #39832
    Um, have you not made a conventional boost port by cutting up to the two rear ports the and blocking the transfers from them?
    Yes and no. We did try removing the bridge between the two boost ports. Bad idea. We have not tried the idea you suggest. It looks worth trying. Thanks for the tip.
  8. #39833
    1971 suzuki T350R
    the best island
    I am fascinated. What made removing the bridge between the two boost or C ports a bad idea? I am thinking about doing something like that to a similar cylinder.
  9. #39834
    I did this with my RG Reed valve conversion. Many years ago and cocked up as I made a mistake on the exhaust so i abandoned it. Just turned into a convential design. You would extend boost to gasket face (I did this on my case reed MB100 conversion).
  10. #39835
    Foundry work, the sides go in last so as to be able to check all is in place.
ID:	355053   Click image for larger version.
  11. #39836
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Dear experts!
    Which is minimum bridge of material between main exhaust and the auxiliary ports at a nikasil plated 40mm bore cylinder?
    Does the minimum depend on bore size? On shape and cordal width of main?
    How wide were the bridges for example in the rsa?
    Is there a rule of thump for bridge on a FOS shape 70% cordal main Ex?
    thanks a lot !
    Grüße Wolfgang
  12. #39837
    3 millimeters
  13. #39838
    3 millimeters
    Hey wobbly,
    Thanks for answering 😀
    Do you talk from 125 cc...54 bore...rsa? 😀
    Is there a corelation to other bores or technical datas? Cant belive 3 mm over all?
    Another question to get a feeling what could be minimum bridge at main with auxiliary ports...
    What is minimum rlieable coated surface width at a mid bridge on a butterfly ex port?
    Tanks from germany to NZ 😉
    Grüße Wolfgang
  14. #39839
    3mm is needed as a minimum to have sufficient load area supporting the ring face with lubrication.
    This works in 125 and smaller cylinders - I have seen a 50cc race cylinder with 2mm Aux bridge widths and it wore away slots in the ring.
  15. #39840
    Ouch!!! 😞
    Thank you so so much for warning us from wear of the rings!
    Its a given buyable tuning cylinder that has around 2 mm bridge that has small main under 65 cordal ...its strong called relieable... ouch!!
    My idea was to minimice bridges to get 68 percent because i thaught this is more effective than widen aux!?? Isnt it? 😉
    Long therm project...
    Tanks for advice...
    Have a nice day wobb...got to sleep now here in europe 😉 😀
    Thanks for advice
    Wolfgang
