Page 2657 of 2776 FirstFirst ... 1657215725572607264726552656265726582659266727072757 ... LastLast
Results 39,841 to 39,855 of 41633
  1. #39841
    In a T port it seems that 2.5mm is the safe minimum , as the chordal width of each side is alot smaller than that of a 70% main.
    It is very important to get the T port bridge relief shape and depth correct though when going this thin.
  2. #39842
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Wob good morning ...Tanks for reading back my edited questions! 😉
    In case of butterfly we often have lubrication Support from bores in piston at bridge mid under ring...think.. minding 😉
    Do you think, this is possible/ effective at a narrow bridge that devides main from aux to avoid heavy wear of rings to??
    Many thanks!!
    Wolfgang
  3. #39843
    Yes it works , there have been several examples of lubrication holes and slots in pistons over the bridges each side of the boost port - some Aprilia pistons had this.
    This is because of the heavy thrust forces from rod angularity.
    I have put lube holes each side of the main port ,over the Aux bridges , on a big overbore Banshee based engine , as again the thrust and ring tension was wearing
    the piston and bridges badly.
  4. #39844
    I wonder how long those hydraulic pumps will last without oil to lubricate them
    Sadly enough, not to long...
    I ran methanol and 6% oil blend through one when i was trying EFI on my bike.
    I seized quite fast....
    But i ran my pump driven by crankshaft as i had normal efi injectors and fuel pressure regulator.
    It seized between the gears and the housing, i expected it to seize at the shafts though, as there were no bearings.
    When it seized it grinded off small aluminium parts from the housing, and clogged up the system.
  5. #39845
    High pressure gear pump for my electromechanical fuel injection system arrived from china.
    Attachment 354982
    Ignitech Dccdip1/2race has input for TPS, and can output PWM.
    Looks like I'm stuck with four throttle position points, and five rpm points which is restrictive, but might be enough when WOT at pretty much constant load is all that matters anyway.
    I'm assuming there's interpolation between these points, can anyone confirm?
    Attachment 354981
    You see where I'm going with this?
    No RAD compensation, if only the Ignitech could accept TPS and some other sensor simultaneously.
    Easy enough to shift the whole map according to conditions, or even have the pwm signal pass through an Arduino that modifies it based on RAD.
    How do you compensate for increased demand of fuel when 'the heat comes'?
    My experiance is that when nitro burns hot, you need to 'put out the fire' with more fuel.....
    Not doing so often results in damage.
    And you cant run 'this' amount of fuel from the start, as it will 'drown' the engine, and it will never come up on the pipe.
  6. #39846
    Hey wobbly thanks!
    I think the bigger the mass of piston the the bigger the forces and the bigger bore the bigger tilt of piston !?
    And the power you gain..the load on piston crown...
    Which would be the best solution to help narrow bridges wobb?
    Like in picture where bores going thru piston?
    Thanks so much
  7. #39847
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    My new fuel injected paramоtor engine
    https://youtube.com/shorts/KkIgSOC0y...4koZ6-MNlCcp3R
    A question. What is the best sealing material nowadays for air cooled cylinder head?
    I use 0.4mm aluminum and copper sheets, but may be exist other still available variants?
  8. #39848
    Yea , here are the bridge lube holes for each side of the boost on a RSA.
    Edit , re the head seal on an aircooled - the worst case scenario for this was solved many years ago when we were permitted to run Methanol and thus very high compression.
    The copper or alloy gaskets were useless , so I tried two fixes , both worked , but I ended up using both as insurance.
    First both surfaces were lapped dead flat on a surface plate , then the first test was to create a " flat labyrinth " seal by machining 3 shallow grooves in the head 2mm wide , 1.5 apart.
    This worked just fine with no failures , but I noticed that as the head was not pinned or dowelled in place , when it was reassembled the witness marks on the cylinder were not concentric.
    Next was to pin the head and use a single empty groove , then a 2mm Viton O Ring outside that. The groove depth was 10% less than the diameter and the width was 20% wider with the OD matching.
    This also worked perfectly and was used later with a petrol head , so excess temp on the O ring proved not to be an issue.
  9. #39849
    Wobb...are you sure?
    From my view that are bores for lubrication c to b ports 😉 bridges ...hmm 😉
    But good to know even that was done wow 😉
    Frits or Jan told us never!? 😉
  10. #39850
    Well the holes are directly over the bridges each side of the boost port - not sure what the slot actually does , but the picture was published ages ago by Frits.
    If you look closely you can see the boost bridges have left witness marks on the piston skirt, directly over the holes.
    Here is another one showing Frits Torlon piston plug as well.
  11. #39851
    Ok wobbly
    Maybe the slot is for a kind of ventilation to ducts?...maybe to help oil flow?
    Please help us Jan ... Frits 😀 😉
    Thanks to all 😉
    Grüße Wolfgang
  12. #39852
    18th December 2020 - 08:47
    kawasaki 250 kr1-s
    Montpellier
    port A, B, C
    Wobbly, Frits,
    I have a question about port A, B, and C.
    Is there a volume relationship between these port and the displacement? If so, what is the distribution between them?
  13. #39853
    I think your wording is a bit confusing , as I don't believe " volume " compared to " displacement" are the correct way to look at the elements of tuning you are examining.
    The two engines that have had the most development effort put into them , and also have had the rewards gained from that work , are the RSA and the TM KZ.
    In essence the only real difference between the two are the KZ's lack of a PV and its idiot straight line mandated ignition.
    This gives rise to a differing approach to the scavenging regime and as well as slight differences in the port chordal widths, even though they have the same bore/stroke/displacement.
    The RSA had reverse transfer stagger , as this regime favors top end and overev, as well as enabling a higher STA of those ports , due to the total width of the B/C being greater and thus gives extra area
    when they are lifted to be the highest.
    The KZ has normal stagger and the boost port width is slightly wider , giving a greater powerband width at the expense of peak power.
    That is more natural upper mid power and a more powerful overev capability.
    Both have the transfers fully occupying as much bore chordal width as is possible within the limits forced by the maximal Exhaust Port width, but both have the STA needed to support the peak power
    at their desired rpm.
    The RSA made 55Hp at 13,000 and was regularly reved not much past 14,000 , whereas the KZ makes just on 50 Hp at 13800 and is reved to 14800 all day.
    The Aprilia regime , including a narrower boost , has been tested in the KZ, and it gained an appreciable amount of peak power , but lost so much in the useable mid ( 10,000 ) rpm
    it was way too slow off all the several 2nd gear hairpins.
    Thus I believe applying the correct approach to the porting regime , and matching the STA of the Transfers and Blowdown to the required power/rpm define all the ports in a very narrow window.
    Thus I dont believe " volume " as such is a useful metric when both engines have the transfers taking up all the available space , and both have the required STA but utilize that area in differing ways to suit the end use.
  14. #39854
    16th November 2014 - 00:35
    Simson S51 Evolution
    Thuringia Germany
    3XV TZR 250 news and best cheap 54mm stroke cylinder
    Wobbly, are there any news about the 3XV cylinder TZR 250 engine? Have you dynoed it yet and did it actually make 54hp/cylinder? It would be awesome. Those cylinders were never thought of being that capable.
    Talking about that 3XV cylinders you found work so well.....are there any "cheap" "basic" 54.5mm stroke cylinders that good? I can remember once you said the 2004 Honda CR125 is a good cylinder to start with. Are there any other 54.5mm stroke cylinders you know of as good or even better than the 2004 Honda CR 125? Apart from the Aprilia RSA/RSW and the TM KZ cylinders of course.
    Thank you for sharing all that knowledge! It is somewhat interesting and exciting.
  15. #39855
    The 3XV cylinder with 56 bore can be ported to match the scavenging regime of the RSA , but as it sits on a 50.7 stroke it can never match those similar cylinders for outright power
    with a square bore/stroke.
    I developed the 3XV in EngMod using every trick in the non existent book ,to be capable of 55 Crank Hp and that will translate to mid 90 RWHP on a DynoJet using Avgas.
    The cylinders are almost done and I am waiting for confirmation that the pipe centerlines are correct , as the 3XV and the 3YL/4DP header spigot have very different exit angles.
    If that does not happen soon, I can get a 4DP into my workshop in November , apart from the middle week as im going to the OZ Classic titles in Sydney.
    The problem with your request for info is that ALL the good cylinders are sat on 54.5mm stroke , not 54.
    The Honda 125/250 RS and TM 125MX both have good porting that can be easily modified to give great power - with the caveat that they are all T ports.
    I do like the dropping gate PV on the RS and the TM twin slot system.
    The KTM is also on 54.5 but has a dumb PV system the opens the Aux ports from the top down - insane, and does not work well no matter how you go about it.
    The TM KZ does not have a PV ,and although some insist that isnt needed in drag racing I have seen plenty of evidence to the contrary , but for road racing the PV gives a huge
    advantage and much greater options for pipe trickery.
    Sadly I cannot think of a 54.5 stroke cylinder with 3 ports where all are closed by the PV like the 3XV.
    I have just done a project on a TZM150 for Thailand , and that is a super good cylinder , but I have no idea about a 125 version of that sorry.
