Page 2658 of 2773 FirstFirst ... 1658215825582608264826562657265826592660266827082758 ... LastLast
Results 39,856 to 39,870 of 41594
  1. #39856
    16th November 2014 - 00:35
    Simson S51 Evolution
    Thuringia Germany
    Thanks, wobbly! Yes, i know. 54,5mm stroke. Not 54. sorry. I will edit my post.
  2. #39857
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Two Stroke conference in Graz 2024
  3. #39858
    18th December 2020 - 08:47
    kawasaki 250 kr1-s
    Montpellier
    I think your wording is a bit confusing , as I don't believe " volume " compared to " displacement" are the correct way to look at the elements of tuning you are examining.
    The two engines that have had the most development effort put into them , and also have had the rewards gained from that work , are the RSA and the TM KZ.
    In essence the only real difference between the two are the KZ's lack of a PV and its idiot straight line mandated ignition.
    This gives rise to a differing approach to the scavenging regime and as well as slight differences in the port chordal widths, even though they have the same bore/stroke/displacement.
    The RSA had reverse transfer stagger , as this regime favors top end and overev, as well as enabling a higher STA of those ports , due to the total width of the B/C being greater and thus gives extra area
    when they are lifted to be the highest.
    The KZ has normal stagger and the boost port width is slightly wider , giving a greater powerband width at the expense of peak power.
    That is more natural upper mid power and a more powerful overev capability.
    Both have the transfers fully occupying as much bore chordal width as is possible within the limits forced by the maximal Exhaust Port width, but both have the STA needed to support the peak power
    at their desired rpm.
    The RSA made 55Hp at 13,000 and was regularly reved not much past 14,000 , whereas the KZ makes just on 50 Hp at 13800 and is reved to 14800 all day.
    The Aprilia regime , including a narrower boost , has been tested in the KZ, and it gained an appreciable amount of peak power , but lost so much in the useable mid ( 10,000 ) rpm
    it was way too slow off all the several 2nd gear hairpins.
    Thus I believe applying the correct approach to the porting regime , and matching the STA of the Transfers and Blowdown to the required power/rpm define all the ports in a very narrow window.
    Thus I dont believe " volume " as such is a useful metric when both engines have the transfers taking up all the available space , and both have the required STA but utilize that area in differing ways to suit the end use.
    Wobbly,
    I seem to have read somewhere on this "ESE's works engine tuner" that most of the gases admitted into the cylinder during the scavenging were in the ports, hence my question, is this true or not? (without taking into account of course the STA and timing which are important), sorry for ma bad english (i use google translate) and Thank you for sharing all that knowledge.
  4. #39859
    1991 MZ 301
    Denmark
    Quote Originally Posted by Pagi View Post
    Wobbly, Frits,
    I have a question about port A, B, and C.
    Is there a volume relationship between these port and the displacement? If so, what is the distribution between them?
    The problem is language.
    If You had asked :
    Is there an optimum area relation between these independent of cylinder size?
    the answer is Yes and RSA and KZ got very close thanks to a lot money for try and error .
    Max power is proportional to sonic velocity times exhaust blow down area.
    If You try to make that bigger by starting blowdown earlier power go down of course and waves in exhaust start misbehaving.
    If you make exhaust ports wider, rings are in trouble and scavenge ports get smaller.
    To design a maximum power 35ccm cylinder ,You can do Yourself a favour by scaling a Thiel 125ccm RSA cylinder.
    That is multiply all RSA linear measures by Third root of 35 divided by 125 that is around 0.6542.
    RSA 125 bore was 54mm and new wonderkind thus 35.3mm
    The blowdown area goes down with squarerot of 35 divided by 125 that is 0.529.
    When crankshaft power of Your 35ccm creation is 0.529times 55 that is 29 horsepower You know that You are in good company.
    Same cleverness level as the RSA creators.
    By same token a 50ccm should be able to make35 horsepower at crank
  5. #39860
    kawasaki 250 kr1-s
    Montpellier
    If You had asked :
    I totally agree with you (STA, timing,...) but my question was really to know if the volume of a port was significant (google translate is bad at translating from French to English...like me!!!!)
  6. #39861
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    The above symposium has some great presentations on opposed piston engines. One of my favorite engines is being evaluated for military use in new advanced combat vehicles.
    Lohring Miller
  7. #39862
    Neils , I suggest you check your maths , a 50cc making 35 crank Hp would need a BMEP of 18.65 Bar at 17,000rpm - Im sure I could not make EngMod capable of lying that big,
    let alone construct a realistic working sim..
    And regarding the duct volume - yes , if you calaculate the actual volume of A/F in all the transfer ducts , it usually exceeds the swept volume of the engine.
    Thus any notion of A/F being " drawn " from the case into the cylinder is based on an erroneous assumption.
    I just checked the sim for the 3XV cylinders sitting on a 4DP case and those ducts that are quite short and small in entry area are damn near 125cc - so little to no flow from the case occurs when
    the transfers are open, unless the VE is well above unity.
  8. #39863
    1991 MZ 301
    Denmark
    If a 54mm stroke thing can do 14800 rpm all day according to You, then a 40 mm stroke thing can do 19980.
    And need a BMEP of 13.8 Bar
  9. #39864
    You are not comparing apples with apples.
    Taking the rpm at peak power ( NOT peak rpm ) the the RSA at 13,000 making 55HP had a bmep of 15.17 Bar and that is a piston speed of 24m/s with a 54.5 stroke.
    I think we can all accept that as the benchmark for power and reliability , with " sufficient " overev for road race use.
    Taking the 50cc engine , with a 40mm stroke and reving it to 17500 = the same piston speed of 24M/s then that requires a BMEP of 17.8 Bar to make 35 Hp.
    Believe me , if I or anyone could achieve 17.8 Bar BMEP , and or achieve 35 Hp in a 50cc ,they would be more famous than Jan Thiel - and I sure as hell aint even close.
    I agree, the RSA could be made to overev to 14800 like the KZ does , and the 50cc could also rev to near 20,000 rpm = 27M/s but no one would dream of making peak power at those extreme high piston speeds
    as then there would be no chance of achieving any safe overev capability at all.
  10. #39865
    19th June 2011 - 00:29
    but to make 50+ BHP from a 125cc, it surely needs more than 125cc's of mixture in the cylinder, no ? after all the cylinder is filled with mixture under presure because of the pipe, just like a turbo overfill's cylinders with more mixture than it's volume ?
  11. #39866
    25th January 2019 - 01:33
    Southwest of Germany
    When ex closes you have less than half of the volume. And if you have 2 bar of absolut pressure, this equals to 125 cc😁
    But you are right with the assumption that more volume is needed because some (or a lot?) gas is drawn into the exhaust
  12. #39867
    Well I checked to see if I was talking rubbish , and sadly it seems so. The Aprilia is the only sim I have where the Delivery Ratio is well over unity.
    It peaks at around 1.4 , and that means 175 cc per stroke are passing into the cylinder.
    The scavenging and trapping efficiency determine how much of the ingested gas in the cylinder is fresh A/F at EPC.
    This is the best result I have , all the other sims hover around 1:1, or lower, which is where I got the original logic from.
  13. #39868
    Jan or Frits said on vol 1 or 2 of Pitlane that there was (cant remember what but something like 1.7 x the cylinder volume in the transfers. (might have been more 380?)
    I could look but both would know what they said and correct what I have got wrong.....
    this is not it buggar
    Not really. The RSA's TDC crankcase volume is 675 cc (for a 125 cc engine!) but most of this volume is in the transfer ducts. Over the years Honda has produced cylinders with and without the lip that your picture shows, sometimes both types in the same production year. But flow through the C-port is not the most important item of a fast cylinder.
    Another point to help you make up your mind: compared to a Honda RS125 or RS250 the Aprilia RSA125 produces about 20% more power per cylinder....
  14. #39869
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    I'm trying to understand why the volume of the transfer ports is important.
    In order for air to flow OUT of the transfer ports, doesn't an equal volume of air have to flow IN to the transfer ports?
    So that the volume of the ports is not so important compared to the resistance to flowing in and out? (and through, and the angles and shapes and such).
  15. #39870
    1991 MZ 301
    Denmark
    Quote Originally Posted by Storbeck View Post
    Let us talk of transfer port areas and tranfer channels volume and debate will surely fuck up in some other entertaining way.
There are currently 152 users browsing this thread. (0 members and 152 guests)
