Page 2667 of 2773 FirstFirst ... 1667216725672617265726652666266726682669267727172767 ... LastLast
Results 39,991 to 40,005 of 41592
  1. #39991
    AG100 farm bike cylinder. Not flow restricted at the extremities of the exhaust ports like most bridged ports.
ID:	355169   Click image for larger version.
  2. #39992
    20th October 2024 - 02:34
    Zündapp KS80, 1976
    I’m not 100% sure what I see.
    Does it mean each side has has it's own pipe? Crazy!
  3. #39993
    Quote Originally Posted by Mollihead View Post
    Yes, two pipes.
ID:	355171   Click image for larger version.
  4. #39994
    Zündapp KS80, 1976
    Compared to the same exhaust but single - is it an improvement or was it just for fun to see how it works?
  5. #39995
    It was to see if I could cast something with max blowdown, time / area .... flow. Not like a normal a bridged port. And yes also for a bit of fun in the Vinduro farm bike class. It has never seen a dyno so no real idea but to say it goes pretty well.
    Problems? Building two identical pipes. Ive ended up building press dies to get them the same. It pulls very well down low (6000 and below) in fact I can almost do a whole event under that figure. Top end (7500 to 11500) it pulls hard.... but the transition it falls flat on its face. This being the none power valve air cooled cylinder.
    The new cylinder having a welded on water jacket and twin powervalves Im expecting will sort this flat range.
    It still has an unfortunatly rubbish bore and stroke at 48 x 58.
    Next series engine will correct this at 54 x 54, AG engine Im using now will not accommodate more that 48 stroke.j
    It would be interesting to see this twin port design with a 'proper' twostroke tuner involved, not just my semi educated estimates.
    Simply put, for the same cylinder exhaust span as a three port this only has one bridge and minimal flow restrictions at the port extremities.
ID:	355172   Click image for larger version.
ID:	355173   Click image for larger version.
  6. #39996
    Zündapp KS80, 1976
    I’m surprised to see an aircooled cylinder with that distance between studs.
    Normally there is not enough space for two exhaust ports.
    I could imagine that standard exhaust resonance calculations are not 100% valid any more in case two resonant pipes talk with each other if exhaust port is in open position.
  7. #39997
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Think there is risk of loosing energy / temperature caus of you have much more pipe surface.
    According to this loss it is difficult to calculate for two pipes...
    And if pipes have minimum diffrences ...they talk 😉 against each other... 😞
    Maybe the power flat is caused by that
  8. #39998
    @flettner
    How you did calculation for the two pipes? They look fat at belly!?
    Maybe you had calculated each pipe with complet cilinder volume!?
    Experts 😉
    Isnt it better to take half ccm for calculation for 2 pipes arrangement??
    Thanks to help my understandig 😉
    Wolfgang
  9. #39999
    We could argue about this for ages.
    Just what the thread needs. Stinger has been covered here but it makes sense to me to have the same combined area as a single pipe (so 1/2 by area) and then experiment.
    The belly section should be derived using the same angles but starting with a much smaller header pipe. But my brain is melting here and now I've entered a highly suggestable state so I best go for a walk
    Anyway 3 cheers to Neil for not just asking the question but committing it to metal.
  10. #40000
    2nd August 2011 - 11:11
    Connecticut, USA
    Aprilia RSA Question
    Does anyone have the measurement from the disc to the piston face for the Aprilia RSA?
    Thanks
  11. #40001
    First off, I make no claims, its an experiment and a bit of fun at that.
    Question about the stud pattern, as I make my own stuff I can have whatever I want. Studs go where I decide.
    Im sticking to the two pipes for now to see how the powervalve might effect things. If I can't get a resonable result / answer, Im looking at a two into one true volume split header into a single pipe. See what that brings.
    With my CNC I should be able to make a press tool to make an accurate volume joiner.
    Pipes are loosely based on 2 x KX65.
  12. #40002
    Maybe??
    Lets find out.
  13. #40003
    Maybe??
    Lets find out.
    Don't remember what you're using for an ignition - but can you dial in some more advance at that point ?
  14. #40004
    Gillette principle. Well, we have two pipes.
    How about three?
  15. #40005
    If i remember correctly...a programmable ignition was on the playground
    Thats a good chance to get pipe temperatures more in ballpark
    A child is sound...if it is playing
