Page 2669 of 2774 FirstFirst ... 1669216925692619265926672668266926702671267927192769 ... LastLast
Results 40,021 to 40,035 of 41608
  1. #40021
    11500, as seen in a glimpse on my Tiny Tach.
  2. #40022
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Here we are Flettner
    Dont mind about values under 1500...this area is only hard to influence in hpi programm
    Black curve is my rebuild from foto of your curve youve showed us
    Red new one from me to have a try...think nothing dangerous...in opposite should be much healtier against deto and too much heat in cilinder
    Other pic shows values of my new curv
    Let us know if you had a testride 😉
    Grüße Wolfgang
ID:	355194   Click image for larger version.
  3. #40023
    I have proposed on the FB group EngMod 2T Users , the we conduct a shootout to design the best pipe for a specific application.
    This will help users understand how to most effectively use the sim , as well as see others attempts at pipe construction.
    It was decided to do something " different " , not the usual 125/250 cc things that have large tech history to draw from.
    I have bought a KR150RR bare engine that is used exclusively in Thailand scooter drag racing.
    Im having trouble finding out what the rules actually are , but know they run VP Q16 fuel.
    Once I have the rules nailed down , I will construct a sim , and people can give it there best shot at designing a pipe to suit.
    When we have a " winner " I will build the engine to the complete sim and dyno it.
    Anyone here who has info on these engines or wants to get in on the shootout , join the FB group ( Im an Admin ) or PM me on here.
  4. #40024
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    My Goodness, I just looked up this VP Q16 fuel, on VP's own site and it has to be the meanest or 'best" fuel I have come across outside of pure methanol.
    . . . That shit's Nasty.
  5. #40025
    https://vpracingfuels.com/products/n...ne-racing-fuel
  6. #40026
    1971 suzuki T350R
    the best island
    I have to admit I stopped reading after the Q16. It did my head in.
  7. #40027
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Is that the same cocktail miser they use in Laos nightclubs?
    (PostalDave on ADVrider)
  8. #40028
    C16 is oxygenated to hell , is full of lead and has a good RVP - perfect for a race 2T
    Methanol has an inherently higher effective octane when run @ 20 % rich and can create more power , but also makes you blind and or dead.
    Just plain greed , like the Chinese bastards that cut NZ baby formula with melamine or some such shit , the CCP gave that company's CEO a dose of Methanol quick smart.
    About the only thing they are good at.
  9. #40029
    Wos
    Had the twin pipe AG out at a VMX meeting yesterday, didn't get round to fitting the video camera, perhaps next time. The little bugger goes.
    But still that weird 'flutter' in the pipes as it comes on song or should I say when it flutters you are buggered as it just wont climb into the power. It seems totally random as to when it happens. Sometimes its just seamless other times a bit of a bitch. Definitely worse when hot.
    Hanging my hat on the new water cooled cylinder although I have a few other tricks to try first.
  10. #40030
    Wos
    Hope i am on right way
    What you discricbe...
    For me a sign the temperatures in pipe are staying to long to cool. Then pipe stucks to long time between reso entry and being really on song.
    Exhaust gas temp on new kurve shoud be generally litle bit higher and after power peak a lot warmer to gain overrev...
    For overrev you need a hot pipe and after shifting gear these heat stays in pipe for a second...
    This could help further to be well on song seamlessly after shifting
    Give new curve a chance...think you will feel very quick if something is better ��
    Grüße Wolfgang
  11. #40031
    Wos
    Hope i am on right way 😉
    Exhaust gas temp on new kurve is generally litle bit higher and after power peak a lot warmer to gain overrev...
    This could help further to be well on song seamlessly after shifting 😉
    Cilinder on new curve is running cooler everywhere to avoid detos or other overheating problems cilinder ...piston etc.
    Give new curve a chance...think you will feel very quick if something better 😉
    Grüße Wolfgang
  12. #40032
    The twin port AG has no issues with detonation, at all.
    The only time Ive had an issue was when I left full advance until 7500 and even then it was bearly noticable ( but it was there ). Since changing to reducing advance from 7500 to 6500 it has gone completely. It is surprisingly detonation proof, even when hot.
    The surging Im experiencing is not detonation, for example I can let it happen indefinitely and it does no damage to the engine, just makes it hard to ride.
  13. #40033
    You told us before that there is no problem with detos after reducing to 6500 😉
    Thats why i kept this point as maximums end 😉
    building a curve is always a gamble...puzzle that we always should start from save side.
    15 degree after peak power nowdays with programmable ignition seems to me much "under state of the art "
    Other rpm points on curve without dyno only to do with many testing rounds with slightly diffrent curves.
    Buy the way flettner... have fun and good luck fiddeling out 😀 I love it 😉
  14. #40034
    Wos, you may well be right, 15 degrees may be too much and I look forward to playing with the curve on a dyno at some point.
    In the mean time that is not my main problem. I have to sort out what these pipes are up to. Last pipes had a large joiner between the mid sections, these do not. I dont remember this issue with the old pipes. These new pipes certainly make more top end power with more accurate press tool sections.
  15. #40035
    Old pipe ...new pipe...dosent matter...you are collecting experience...can do conclusions for next needs ...
    In combination of changing ignition you can even get more insight whats going on... worth doing it before thinking about other pipe...
    Mid section? Cilindrical part? Belly?
    Do you work with fos pipe calculation?
    Very good start and easy with jan bros excel
    Belly diameter now...lengt from piston to end cone?
    If i had to deal with your twin x
    Would calculation do with 50 cc ...go with small diameter/ shallow pipe ...resonance length 8500...9000 wide powerband for enduro use...
    If i am completely wrong...dear other better speacialists here...tell me...tell us!! top!
    Grüße from enduro fellow
