Page 2677 of 2773 FirstFirst ... 167721772577262726672675267626772678267926872727 ... LastLast
Results 40,141 to 40,155 of 41592
  1. #40141
    19th June 2011 - 00:29
    I have it in german, any good for you ?
  2. #40142
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    I am solo lingual but I could try translating it, so yes I am interested. Thanks
  3. #40143
    Anyone here in NZ got a M30 x 1.5 female puller I could use to yank off the flywheel of the EngMod competition KR150.
    Only need it for the 30 seconds it takes - can send straight back.
  4. #40144
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Frits ignition curves paper you can download in german here
    https://oil-club.de/wcf/index.php?at...urven-132-pdf/
    But Frits?
    Wasnt a Englisch version available somewhere?
    Thanks!
    Wolfgang
  5. #40145
  6. #40146
    ETEC 800
    Minnesota, USA
    Thanks for tracking that down!
  7. #40147
    Gedday all,
    The theme of this post is to get rid of those old fashioned expansion chambers with a straight header, and add some incredibly bulky packaging and an unknown, but complex crank coupling and swap these for something that mightn’t offer any advantages at all. Are you ready?
    OK, recently on Rimar Motors FB page, where he shared the design and mfg of his 587v2 engine (Incredibly good stuff. See https://www.facebook.com/rimarmotors) that utilizes 2 * KTM 300 cylinders, someone asked him could he do a 3 cyl version. His immediate response was to say no, because of the bulk of the exhausts.
    This reminded me of a time, 100 years ago at Orbital Eng Co, we first started testing a 3 cyl Suzuki DT85 1.2 litre outboard engine. We had no useful idea for the exhaust (expansion chambers were not a consideration) and various systems were made with separate headers etc. all worked at some point, but overall useless. Then we just created a simple chamber or plenum close to the 3 exhaust port outlets (similar to all multi cylinder outboards) and immediately got a nice high and flat power curve. This then, with time for emissions reasons, was changed to accept a catalyst brick forming the back face of the plenum.
    Obviously in such an arrangement with an inline crank, there is an asymmetry in terms of communication lengths between cylinders. Unacceptable to any OCD type.
    So, let’s arrange 3 cylinders symmetrically abut a common axis, with the exh outlet face facing the axis, ie inwards. With some form of a common plenum connecting the 3 exhausts, this could lead upwards via a single header pipe.
Name:	3 into 1 a.jpg
    How it would fit anywhere? Fletto, where are you???
  8. #40148
    Well that and a petrol tank for a 900 2 stroke would defeat the whole purpose.
    The only 2 strokes I've been regularly riding recently are 300 enduros. On the dirt they have ample power in all the right places.
  9. #40149
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Gedday all,
    Ken, you are talking about the one long path vs the two short paths.
  10. #40150
    [QUOTE=Vannik;1131232270]Ken, you are talking about the one long path vs the two short paths.
    Yes Neels, that's exactly the arrangement. Whether "actual equal lengths" in this situation would make any difference is unknown to me. One guy (Bromlech?) over here, shortly after GT750s came out, made a 3 into 1 system. I have no idea if they were any better performance wise , they had very long primaries, but they sounded so sweet.
    F5 Dave, we're not talking about chook chasers here....
    See you all next year...
  11. #40151
    3rd December 2011 - 23:33
    2005 aprilia rs50
    UK
    Strike are made for iron liners most KTM are made for coated.
    Strike which is a family business based in AUS will make pistons with custom pined rings in any oversize not .25 of a mm if you use KTM you are stuck with 3 fitting pistons abc . Strike do hone to size pistons.
    http://www.strikeproducts.com.au/pistons.asp
    http://www.strikeproducts.com.au/pricelist.asp
    piston dimenions KT100s
    https://cdn.revolutionise.com.au/sit...avzy51kppz.pdf
    • or custom applications for AIDKA and Speedway racing applications
      Custom options include:
      High Ring
      Rotated Anti Rotation Pin for reeds and rotaries
      Dykes rings
      Sizes are made to order
      Rings to suit are dependant on application
    PSS001 - Piston KT100S Smooth Finish
    Smooth piston skirt finish
    To suit Yamaha KT100S and ARC SPEC100 for AKA racing applications
    Size increments 0.05mm between Æ52.0 and Æ52.75 then 0.01 increments above Æ52.75mm
    Ring to suit is p/n PRS001
    These are aus pasos
    S001 Piston KT100S Std $83.00
    PS002 Piston KT100S >Ø53.00* $83.00
    PS003 Piston KT100S >Ø53.75* $83.00
    PS004 Piston KT100S Special** POA
    PSS001 Piston KT100S Std Smooth $91.50
    *Not legal for AKA sanctioned events
    **Custom options: Indexed A/R Pin Location to any angle
    PRS001 P/Ring KT100S Std $21.50
    PRS002 P/Ring KT100S Big Bore 53.5, 55.25, 55.5 $36.00
    C001 Circlips Ø14*Ø1.0 x 50 off $45.00
    PB001 Pin Bearing Thompson $18.00
    PP001 Piston Pin Ø14*Ø8.9*40.4 $7.50
    PP002 Piston Pin Ø14*Ø10*40.5 (Light) 7.50
    Cheers mate 😃
  12. #40152
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    [QUOTE=ken seeber;1131232286]
    How about if you take your online three cylinder and tip the middle cylinder backwards until the exhaust port flanges of the tipped back middle cylinder and the outer two cylinders from roughly an equilateral triangle? That may allow the other cylinders to be moved in a bit of possibly allow them more room for transfer ports to loop out and around.
    Maybe that leaves the "headers" still too long or gives problems with balance and firing order or some such. Could add a balance shaft and still be way more simple the previous arrangement.
  13. #40153
    [QUOTE=Storbeck;1131232289]
    Storebeck, thnx for the input. Did think along similar lines, but the primary passages would be quite different in length, similar to Neel's pic. So, without being totally pedantic about symmetry, one could rotate the outer cylinders (see A1 & A2) such that the exh axis was aimed to the central plane of cyl B, with "near" symmetry in terms of passage lengths and angles.
    One would have to do a sweetheart deal with a piston mfgr to create blank full skirt pistons and then, say on a 3 axis, make the corresponding cut outs to match the transfers. Would also be issues with the piston pin bores.
    However, the main question remains: Would a single common & low volume plenum work with such very short primary lengths?
  14. #40154
    Suff
    Hi Ken can you do a speil the Special 52-53mm KT100S Strike pistons in custom sizes and finishes and pinning rings or special Windows for RGVbaz.
  15. #40155
    Not really. That common plenum would act like a Honda ATAC volume. In the Honda system this volume is closed when it is not needed; in your situation it will always be open, weaking all pulses all the time.
    What you'd need is some rotating device that couples an exhaust port that is just opening with an exhaust port that is about to close, while the third exhaust port is open to the atmosphere via a sucking (loud!) megaphone.
