Thats quite alright, I wanted it for my own records as well.
If you can get PerformanceTrends to include the FOS 2-Stroke correction factor in their Dyno software, I would consider that payment in full![]()
I can not find SAE 890836 available as a free download anywhere so far;
It is available for direct purchase from the SAE MOBIUS here:
https://www.sae.org/publications/tec...ontent/890836/
Awesome!
Thank you very much!
The team I work with has also been in contact with PerformanceTrends, and we also requested that they add the FOS 2-Stroke correction factor.
Hopefully with enough pressure and with the support of the published data they will see fit to add it to their software.
I noticed you were talking about jetting and such, i´ll contribute with my redneck method of getting a lectron into the ballpark if having just one metering rod, and don't want to buy so many before getting it right =)
And the missing part:
Lastly, the result, not fully tuned yet, but full throttle seems to get close.
So Patrick ,after you telling the internet with absolute certainty, I was completely wrong about dyno losses , now suddenly - quote " I dont know".
As I told you several times, doing a run down with the clutch pulled in, is not even remotely a valid test of this metric.
SportDevices has an easily accessed % transmission losses entry page under Corrections - where you can enter 15% or anything that will give you the data as seen as crank power in your simulation.
I am happy to report, thanks to R-Tech Racing's efforts and the collegiate sharing of research...
PerformanceTrends just sent over a new version of their Dyno DataMite Software for validation testing.
-Updated to include FOS 2-Stroke Weather Correction Factor!
Assuming all works as expected, the new update should be available for download pretty soon.
Thank you Frits, Wayne and R-Tech Racing!![]()
We had honestly given up hope, and were preparing to purchase the SportsDevices DAQ and Software.
This success saves my team ~$1,000 USD that we had basically already commited to spending.
We are VERY excited to have this result.
I have sent 2 screen shots with differing weather to Rein, showing the FOS corrections to send to Performance Trends so they can confirm the code changes needed are correct.
I am VERY happy to hear it ApolloMotoMoto.
One small remark: I call it the FOS two-stroke air density correction factor instead of weather correction factor. Thankfully most dyno rooms are shielded from the weather so the air temperature and pressure in a good dyno room can adjusted independent from the weather.
Me thinks you are spoiled rotten by the SOTA apparatus at Aprilia Frits.
The only " shield " most dyno rooms have from the ambient weather is the workshop front door.
If I could be bothered , the best/worst pics of Neil is a couple showing his knees in his mid winter shorts - a horror nightmare show not many have survived psychologically intact.
I wonder out loud if the code guy at Performance Trends didnt want people ringing him and mistakenly calling him Richard.
Really glad prodding the Bear actually worked in this case.
For those people who have not actually seen the FOS code in action , here is a shot of the real time screen on my dyno.
The SportDyno digital weather station is calibrated to the local airport, about 5Km away.
There are currently 135 users browsing this thread. (1 members and 134 guests)
