Page 2687 of 2775 FirstFirst ... 168721872587263726772685268626872688268926972737 ... LastLast
Results 40,291 to 40,305 of 41611
  1. #40291
    Math apart - do not be focused on the Hp/Torque graphs " crossing " at 5252 - that is a completely irrelevant but automatic metric.
    Set the scales such that they are the easyest to read and interpret , having a wider scale on Torque can reveal subtleties not seen when the Y scale is compressed
    to include Nm that are not even used on track and thus are not needed when dyno testing.
  2. #40292
    11th May 2024 - 06:49
    United States, CA
    Quote Originally Posted by ApolloMotoMoto View Post
    Can someone please check my math and give me a positive confirmation that I = (k)mr^2 only works with SI units for the purpose of using in the formula T=Ia?
    I figured it out!
    It doesnt work with pounds because the pound is not a unit of mass (m) its a unit of weight.
    The Imperia SI unit for mass is the slug.
    This is the first time I have ever heard of a slug.
    1 Slug = 32.17 pounds
    Thus;
    lds/32.17 = slugs
    If you use slugs per square feet for the I in: T=Ia;
    The resulting T will be in pound feets.
    If you use kilograms per square meter for the I in : T=Ia
    The resulting T will be in newton meters.
    When I do the conversion of 280 lds per ft^2 to 8.75 slugs per ft^2 all of the numbers agree weather I use Imperial or Metric inputs in the motion physics formulas.
    Kilograms per square meter of Inertia comes out as Newton Meters of Torque.
    Slugs per square foot of Inertia comes out as Pound Feet of Torque.
    We are re-conducting the drop-test using string wrapped around the flywheels axle shaft, with a pulley at the top of the garage for the longest fall distance we can make happen.
    Thank you very much to everyone's assistance!
  3. #40293
    There are really good reasons that Science and the rest of the world use the metric system (S.I. Système international d'unités.)
  4. #40294
    Michelin tyres and the SI system. Best things to come out of France.
  5. #40295
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    You mean the only good things ever to come out of the land of terrible latin.
    . . . That shit's Nasty.
  6. #40296
    Hi I was talking to a gentleman today at Ruapuna
    He asked about what aluminium to use for sleeves to be plated.
    Also about CF rotary valves and clearances.
    He has posted on here.
    I remember either Wob, Neil , Rob, or maybe Yow using specific a grade I think 2040? or similar that was fee matching an took the replating well?
    I had a man look but TBH I am beat after only a few hours sleep and 600km travel today.
    Good to see the Kr250 out looking all green and mean and a fair few TZ or close analogues.
    My son is finally running comparable times on the Honda well......4t compared to the old Supermoto.
    clean holeshot in all races and clean and tidy lines with the bike staying on the track.
    I was hoping to catch up with DP. but missed him.
  7. #40297
    Didn't they invent the white flag or at least popularise its use? Pretty sure they also did a lot of developments work with scuba diving, limpet mines and zodiac dinghies...
  8. #40298
    As I get older and more exposed to the Internet I realise that people are people and generally good sorts. It's the government's that tend to cause the trouble, and their's have been dreadfully damaging.
  9. #40299
    26th April 2013 - 21:55
    BMW R1200R 2009
    They are great neighbours, but when it comes to inventing really important stuff they are no match.
    https://www.compass-group.be/en/stor...gian-invention
  10. #40300
    25th October 2022 - 04:48
    1974 yz 125
    Minnesota (United States)
    Can't argue with the waffles. And FN Browning.
    LeMans should count for something I suppose?
  11. #40301
    And the croissant. . . Oh. That's from Austria.
  12. #40302
    Heat treated A6061 T6 containing magnesium and silicon as its major alloying elements and easy to find.
  13. #40303
    Yes 6061 T6 in 8mm is what I will be using for the added plate on top of the KR180.
    Is not available in 8mm plate so was sliced off a 127mm bar , CNC machined and bored /drilled to suit.
    It has 0.2mm extra height to be take off after welding around the bore and the water jacket
Name:	Head Spacer Plate.JPG
  14. #40304
    1971 suzuki T350R
    the best island
    So are two holes either side of the top stud hole for the coolant? are you happy that they are large a enough?
  15. #40305
    For casting cylinders fresh, LM13.
    2024 if you want to machine a piston from solid.
