Page 2688 of 2776 FirstFirst ... 168821882588263826782686268726882689269026982738 ... LastLast
Results 40,306 to 40,320 of 41630
  1. #40306
    cheers
    plus 10....
    https://www.wakefieldmetals.co.nz/wp...0/roundBar.pdf
    they do tubes in f-grades that suit , but not in the size someone wanted....
    Both Fletchers and Ulrich do heavy wall alloy tube in 6000 series.
    This plates just fine according to Grant at the platers down South
    For casting cylinders fresh, LM13.
    2024 if you want to machine a piston from solid.
    Hi I was talking to a gentleman today at Ruapuna
    He asked about what aluminium to use for sleeves to be plated.
    Also about CF rotary valves and clearances.
    He has posted on here.
    I remember either Wob, Neil , Rob, or maybe Yow using specific a grade I think 2040? or similar that was fee matching an took the replating well?
    I had a man look but TBH I am beat after only a few hours sleep and 600km travel today.
    Good to see the Kr250 out looking all green and mean and a fair few TZ or close analogues.
    My son is finally running comparable times on the Honda well......4t compared to the old Supermoto.
    clean holeshot in all races and clean and tidy lines with the bike staying on the track.
    I was hoping to catch up with DP. but missed him.
    Heat treated A6061 T6 containing magnesium and silicon as its major alloying elements and easy to find.
    Yes 6061 T6 in 8mm is what I will be using for the added plate on top of the KR180.
    Is not available in 8mm plate so was sliced off a 127mm bar , CNC machined and bored /drilled to suit.
    It has 0.2mm extra height to be take off after welding around the bore and the water jacket
  2. #40307
    Lugging my hair yesterday, dynoing the Kartengine.
    Well, it all falls in place in the end :O
  3. #40308
    Kawasaki is coming out with a new full sized 2 stroke dirtbike. Last year of production was 2007 for their KX line.
  4. #40309
  5. #40310
    Cylinder back from NZ Cylinders.
ID:	355633   Click image for larger version.
  6. #40311
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    I have to know "what's in the small jar"
    . . . That shit's Nasty.
  7. #40312
    21st June 2012 - 14:20
    1974 Yamaha RD250
    Camden, S.C. USA
    Photo #1 instruction sheet says Motul Kart synthetic castor for pre lube..
  8. #40313
    1971 suzuki T350R
    the best island
    Makes sense. Thank you
  9. #40314
  10. #40315
    This is something that Millenium struggled with for years and are still getting shit poked at them even now.
    They keep getting random " streaking " up the bore at the first heat cycle - nothing to do with port edges.
    If you use a ton of castor based oil on the bore/piston , and DO NOT rev or blip the throttle for at least 5 minutes of just slow first start idle, this does not happen.
    The heavy compression induced ring bore tension is reduced doing this initial break in procedure and bore streaking created by micro ring face particles being torn off - goes away.
    It looks bad when you see it , but not long into normal use it will quickly wear off.
  11. #40316
    11th May 2024 - 06:49
    United States, CA
    I have seen so much shit poked at them over this that I had decided to go to PowerSeal for their Nikaseal plating instead of Millenium.
    Thankfully the engine manufacturer my team has been working with in China has accepted the need to convert from chrome plating to "Nickel Silicon Carbide" process.
    So far it appears they have found a facility to shop out the plating too until I can convince them to ditch their in-house chrome process completely and setup for Ni-Sic plating like they ought to be doing...
    I sent them a few Chinese language patents, I dont get whats so difficult about it
    The facility they are shoping out too claims they purchase the Sic powder straight from Germany, which at least sounds promissing.
    Once the first batch of "nika-whatever" coating cylinders get here I'll have some pistons made up for 1.0mm chrome face rings and see what happens.
  12. #40317
    .........China?
  13. #40318
    The coating chemical process , can be easily adjusted technically to achieve a wide range of surface hardness values after final honing.
    PowerSeal errs very much on the hard side , and thus receives big reps as though their process is " superior " because they don't suffer anywhere near as badly from initial streaking
    up the bore during the first break-in heat cycle.
    But in realty, of course , there is never a free lunch , and the harder honed surface immediately wears the coated ring face , and thus the longer term seal efficiency much, much faster.
    Swings and roundabouts, where they sacrifice good long term ring seal , for short term perceived superior coating performance.
    It is in no way superior at all - if the simple, correct break in process is adhered to, and then the so called shit plating performs perfectly in long term reality.
  14. #40319
    United States, CA
    Thank you for sharing the empirical experience Wayne.
    The process itself is simple enough to understand in principle...
    But as I got deeper into what happens when you hone the cylinder, and how the coating has certain parameters that are tuned to work in conjunction with the method of honing, the ability to effectively determine the best solution quickly exceeded my pay grade.
  15. #40320
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    The “Millenium barcode” can be avoided, however the Platers themselves do not even know the solution. They blame wiseco rings, the customers constantly blame the honing, and Facebook warriors blame ring end gap lol.
    On my last replate from millenium, I used wossner pistons/rings, however I also used copious amounts of permatex ultra slick assembly lube and spent hours with a cotton mop burnishing the nikasil points from the port edges. 1/2 way through the dyno day we did the obligatory head pull, and there was no “barcode”. Looking forward to trying this with wiseco pistons and rings to narrow down on a common denominator.
There are currently 50 users browsing this thread. (0 members and 50 guests)
