Page 2689 of 2776 FirstFirst ... 168921892589263926792687268826892690269126992739 ... LastLast
Results 40,321 to 40,335 of 41631
  1. #40321
    Strange. My 50 and 496 were Millennium. Never saw an issue when pulled. Both run in on dyno. 50 a billion times.
    496 was wiseco. Didn't see issues.
  2. #40322
    Any kiwis got one of these lurking about I want one to make a crankcase breather for my Ducati, cough couch 4t project.
    That way despite its over complicated top end with wizwams a tick tock clock pieces It will it at least have a 2t Reed Valve.
    Its normally found an early Homeliite chainsaw
    I thought there was one in the old mans shed but the ratio seem to be more shed than homelite Reed Valve.
    there are jonseerd and old sthil
Name:	Screenshot 2025-02-02 9.54.53 PM.png
ID:	355650Click image for larger version.
Name:	Screenshot 2025-02-02 9.54.28 PM.png
ID:	355651Click image for larger version.
Name:	Screenshot 2025-02-02 9.54.02 PM.png
    These are smaller then they look
  3. #40323
    Finally!!
    I got this 'overkill' Kawasaki engine started.
    It´s been a hectic week, actually for no reason.
    But i wanted to start this bastard of a engine for you guys =)
    It´s a Kawasaki kx250 -96 engine
    Equipped with balanceshaft from Tecate.(parts from tecate but house built by me)
    Lockup clutch.(built it myself)
    Rotating disc intake system(built it myself, some parts from Rotax can am 250)
    TM racing cylinder(ported by me, resleeved by me)
    So it´s a real hybrid of things, like a frankensteins monster.
    Hope it produces monster power later on also =)
  4. #40324
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    I got few homelite reeds Husa, if you need in pm
  5. #40325
    While you are cleaning out the shed, try get the T125 closer to the door.
  6. #40326
    I just noticed where you are from what a beautiful spot. Thanks for the offer, I don't think there is a spot in the world further away from where I live.
    I am sure there is some in the shed somewhere, But Grumph will attest it's a jungle in there.
  7. #40327
    Island of Korcula
    If you need.. it's on me, who else in the planet would need 60years old chainsaw reeds to put on foulstroke
  8. #40328
    1st May 2019 - 20:57
    kr250
    alexandra
    sleeve alloy grade
    plus 10....
    https://www.wakefieldmetals.co.nz/wp...0/roundBar.pdf
    they do tubes in f-grades that suit , but not in the size someone wanted....
    thanks for the replies I will do them with a taper fit that was talked about early in the thread,has anyone here done that and what taper angle was used
  9. #40329
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Scavenging of one and only future MC powerplant.
    A picture
    I plan to let exhaust side crankcase inhale as much air as it can and blow fuel/lube oil for a 15% rich mixture on underside of exhaust piston to keep it cool.
    Inlet side is only allowed to inhale a third clean air.
    The two crankcases are connected by a pipe and contra valve.
    (Not shown yet)
    The scavenge air escaping through exhaust port will be clean, cold air.
    Rest will be correct lambda and stay in cylinder.
    A simple oxidation catalyst will be fine.
  10. #40330
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Below are pictures of my piston ported, crankshaft scavenged, opposed piston engine. It used crankshafts and crankcases I had with adopter plates to a cylinder. The pipes and gears between the crankshafts aren't shown for clarity.
    Lohring Miller
Name:	Engine Assembly new single exhaust 1.jpg
ID:	355665Click image for larger version.
Name:	Engine Assembly new single exhaust v10.jpg
ID:	355666Click image for larger version.
Name:	Engine Assembly new single exhaust passages.jpg
ID:	355671Click image for larger version.
Name:	Engine Assembly new single exhaust front section.jpg
ID:	355669Click image for larger version.
Name:	Engine Assembly new single exhaust side section.png
  11. #40331
    1991 MZ 301
    Denmark
    Lohring Miller
    Was it a simple job to make the geartrain work satisfactory?
    It has been a sore spot on quite some opposed piston engines.
  12. #40332
    A picture
    (Not shown yet)
    Is that made of wood? ECO.
  13. #40333
    Here is one in actual hardware. Waiting on time/money and interest to finish. (My interest is elsewhere pleasantly)
    https://youtube.com/shorts/HGg_mI9OKjI?feature=shared
  14. #40334
    17th March 2023 - 06:08
    1982,Yamaha RD125LC 10W
    Belgium,East-Flanders
    Quote Originally Posted by eddie View Post
    Morsecone
    Aluminium sleeve material:
    4032-T651
    4032-T6
    6061-T651
    6061-T6
    Cast iron sleeve material:
    EN-GJV-500 (5.2301 vermicular cast iron)
    EN-GJV-450 (5.2201 vermicular cast iron)
    EN-GJL-300 (GG30 lamellar cast iron)
    Some are easier to find than others.
  15. #40335
    1991 MZ 301
    Denmark
    Scrapped teak furniture.
    Lubricated for life
