Page 2698 of 2774 FirstFirst ... 169821982598264826882696269726982699270027082748 ... LastLast
Results 40,456 to 40,470 of 41608
  1. #40456
    This is where I got it from.
    Whoops stopped the higherlighter short
Name:	Screenshot 2025-04-03 6.42.48 PM.png
  2. #40457
    But too late by then.
  3. #40458
    The way I see it is that Devcon B is a steel based epoxy and Devcon F is an aluminium based epoxy. Surely, in an aluminium cylinder, the F would be the way to go as it would have a thermal expansion approx the same as the cylinder.
    We have used the F on crankcases and cylinders.
    https://www.blackwoods.com.au/adhesi...00g/p/04124908
    Expensive, but you've gotta help Australia's ailing economy.
    Super expensive with a minimum purchase of 6, and impossible anyway, since they won't ship outside of Australia. I thought only dipshit septics did that
  4. #40459
    Ken, Devcon F is a putty , and I tried using that and even with a heated up cylinder sitting at the right angle, the added lump of epoxy would never completely settle flat.
    Its bloody near impossible to get it to sit in the right place , prior to angling the cylinder - you cant simply pour it in.
    When I tested the 3D printed clamp on outer transfer wall cooling system you made , the hottest the cylinder got was 80*C right at the case gasket line - the rest was
    about the same as the water temp at less than 50* - plus the internal transfer walls are all cooled by the incoming A/F mixture.
    So I dont think heat expansion is an issue at all.
    The " B " is very runny and settles flat the instant it is poured into the cavity.
    I have bought several boxes of this stuff from OZ, a friend simply got it and sent it to me by OZ Post, never been an issue.
    As its made in OZ , maybe they would tell you what to add to " F " to make it liquid, but dont hold your breath, as I asked them what to use for cleaning up the large plastic syringes
    I use to dispense the liquid - no reply.
  5. #40460
    Wob, you want liquid, here is liquid:
    https://www.freemansupply.com/datash...iquidputty.pdf
    One major source for Devcon appears to be https://itwperformancepolymers.com, but not sure where it is made. They seem to have distributors everywhere in the world, but not Australia or NZ ??
  6. #40461
    Thanks Ken , never seen that before. On the box of " B " I have it says Made in Australia by ITW-devcon.com.au.
    But I cant find any mention of F2 on the website.
  7. #40462
    Devcon "B" for those that live in New Zealand. Liquid and Putty.
Name:	Screenshot (844).png
ID:	356008 Click image for larger version.
Name:	Screenshot (845).png
  8. #40463
    Australian supplier of Liquid B
Name:	Screenshot (846).png
    Devcon Plastic Steel Liquid (B) Epoxy
    • A low viscosity compound with all the properties of Plastic Steel Putty, but in liquid form.
    • Used for casting low-cost patterns and molds, holding fixtures, tools and dies.
    • Excellent compression strength and high load-bearing capabilities make it ideal for chocking and leveling machinery and bridges and repairing hard to reach areas.
    Areas of Application
    • Holding fixtures for intricate parts.
    • Filling and leveling equipment.
    • Repairing hard to reach areas where a flowable epoxy is needed.
    • Duplicating or tracing masters.
    • Short-run dies and molds.
    Features and Benefits
    • Low viscosity for easy pouring.
    • Can be cast over models for accurate detail reproduction.
    • Can be machined to close tolerances.
    • Low shrinkage.
  9. #40464
    Team ESE have had a great deal of success with using Devcon "B", both liquid and putty. Sticks very well in transfer ports....
  10. #40465
    15th May 2017 - 14:26
    2002 Aprlia RS125
    And in exhaust ports? Or is it outside the temperature range?
  11. #40466
    No - the high heat kills the epoxy in no time.
    I have used J-B Weld ExtremeHeat ceramic paste to fill exhaust ducts , it lasted weeks of dyno testing, with no issues,
  12. #40467
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    I have filled very small weld pinholes in the exhaust duct floor with high temp devcon titanium putty. After dynoing I checked, and it was all gone. I have partially filled water jackets with it as well by using a small airline and a ram rod to jam it deep into the water jacket. It held up well in this area. And of course it always holds up in other areas of the engine. Going to try the liquid stuff and syringe trick to perpendicularize the b-port leading edge soon after plating.
    I have also been advised by a reputable builder to try 3M panel bond instead of devcon, but that will be on a low stakes project in case it does not work.
  13. #40468
    TeeZee , as you found its way cheaper to buy retail In OZ. Get a friend to buy it and send to you, still way cheaper.
  14. #40469
    Nitromethane testing to celebrate my youtubechannel have reached a milestone.
    Can i reach 100whp in my old Yamaha TZ250? (1kt/2ma engine)
    What to expect?
    Will the pipes still tune?
    As i have watched twostroke stuffing(Alex Degnes) i got curios, can it be done better?
    (not more power per cc, but with some more control)
    Head on over to my youtube channel and watch, feel free to ask any question.
    I´ll try to answer.
    https://youtu.be/eLf3PW-9btU
  15. #40470
    ETEC 800
    Minnesota, USA
    Question regarding ignitech model.
    I have 3 ignitech boxes. Two have 5_smd_7 stamped in the plastic, and the third has nothing anywhere. It is the exact same shape and the connectors are the same. With that minimal info, is anyone able to tell me if it is the same box? I have a brand new harness and basically want to know if the schematic is the same between the two.
