Page 2700 of 2776 FirstFirst ... 170022002600265026902698269927002701270227102750 ... LastLast
Results 40,486 to 40,500 of 41632
  1. #40486
    30th May 2020 - 23:45
    Ktm 990 beta rr 50 racing
    Thats what my wife said.
    I first got an inkling into this years ago when first tuning a 3YL Yamaha 250. It had been moded to hell with new pipes and everything we understood about go fast shit
    at the time. It would misfire like hell at peak torque , and as I didnt know about the trick fine wire NGK sparkplugs , my initial reaction was to drop the spark gap from 0.65mm to 0.35mm.
    That cured the misfire , and then later on the dyno we discovered the absolutely weird relationship between the spark gap and the overev capability.
    Finally settled on 0.45mm as this was just short of misfiring, but gave the best compromise in the overev.
    Recently everything is completely different on a very similar engine , using the Ignitech @ 15.4V and the shorty fine wire plugs we run 1mm , and can manipulate the overev at will with
    the ignition curve.
    Im now seriously looking into setting up a rpm controlled regulator, that can reduce the voltage seen by the ECU and thus the mJoules generated at the plug.
    Thank you very much wobb for flood of Information...top!!! 😉
    My life seems to be to short getting all the possible variations into ball park
  2. #40487
    Edit - Condyn , one of the very few reasons an Ignitech will not produce accurate ignition curves , is EMI. You MUST use resistor plugs and caps. The other issue is the proximity of the trigger or any other input/output
    wiring to the coil charge wires.
    They are on opposite ends of the loom plug for a reason.
    I always run the coil wires on one side of the bike ( or whatever ) frame, and the triggers etc on the other side.
    These simple things remove 99% of issues.
    Also depin any unused loom wires, DONT coil them up to operate as very good antennae.
    Yes absolutely critical. I made a test bench for checking the ignition systems. 1.5 kw engine with maximum 22000rpm.
    With Ignitech SPARKER DCCDIP4P4 I was completely confused for two days due to interference of the second spark after 90 degrees. And yes, the reason was the wires located close to each other. No such problems with the factory units that I tested, looks like Ignitech is very sensitive unit.
    https://www.youtube.com/watch?v=J1-JTUKL0Uk
    https://www.youtube.com/watch?v=a5GkXjsijc0
ID:	356044   Click image for larger version.
  3. #40488
    Yes the P4 seems extra sensitive , I ended up using CAT 5 audio cable with the shield grounded at one end for the triggers - problems gone.
    Not only is it shielded, the wires are twisted pairs, on the scope there is no noise at all.
  4. #40489
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Oh this is very interesting. Along with what Wobbly is saying about wiring layout. I see a lot of rewiring ign wiring loops layouts in my future.
    . . . That shit's Nasty.
  5. #40490
    Thanks for the advice.
    Ignitech allows to choose "Interlock input" function: this option works only for pickup system 1 lobe, 2 pickups. With elevated levels of electromagnetic
    interference (e.g. at the time of ignition) on some motorcycles (e.g. Ducati) unwanted activation of the pickup input may occur,
    especially that input which at the moment is not active. This option prevents unwanted activation blocking input 2 during
    activation of input 1, and vice versa: blocking input 1 during the activation of Input 2. This option, however, may cause
    problems, when combined with automatic determination of sensor polarity.
    After turning off function, the troubles were even greater.
    20 years ago I had this problem with my homemade long duration spark ignition for V 90 2 cylinder engine. Then got out of this by using a more powerful thyristor BTW69 1200v, with less control sensitivity. Just more revs was needed to open thyristor gate.
  6. #40491
    I´d like to give you guys some advice.
    Ignitech and such in all it´s glory.
    But if you are having the budget, go for Maxxecu Mini(or better)
    Working a treat on twostrokes.
    You get a LOT of functions, and also more hardware to use(from the car tuning world)
    I take the opportunity to post new video below, i run Maxxecu Mini in my tzr build.
    In this episode i test the launchcontrol function, just raw no finesse, and also no slipperclutch.
    You can dial in the launchcontrol with delay and gradually roll off(to help traction)
    But not tested in this video, i just wanted to start somewhere and hitting it hard.
    You can set limits and compensation to almost everything.
    Say you run EGT´s into the maxxecu, you can use it to active keep egt´s in check.
    Say you get low battery, you can compsate charging time of the coils to compensate for that.
    Well. you can do almost anything.
    If beeing a mathmatical guy you can also build your own tables.
    The onscreen tacho in the video is done by using canbus to obd2, then into my android device.
    Enough of that
    here´s the video:
    Enjoy!
    https://youtu.be/ZiJxtf3ZKgw
    And oh...
    Even though my posts might be hacked to bits, it is creating topics for the keyboardwarriors *lol*
    Keeping this thread alive =)
  7. #40492
Name:	Air-Fuel Ratio NSR125.jpg
    Air Fuel ratio as seen by an O2 sensor. In reality the AF ratio is probably close to ideal at all RPM but the O2 sensor sees the short circuiting air that was not trapped in the cylinder.
  8. #40493
    https://asmedigitalcollection.asme.o...dFrom=fulltext
  9. #40494
    13th March 2015 - 07:20
    1987 SUZUKI 500RG
    France
    Request
    Hello,
    I also built a test bench for our ignitions, but using a vacuum cleaner motor, which is an AC motor.
    The speed control isn't optimal.
    I am interested in knowing the origin/supplier of your motor and controller.
    Thank you in advance.
    Francis.
  10. #40495
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Quote Originally Posted by fpayart View Post
    Hello,
    Francis.
    Try this for price
    https://www.aliexpress.com/item/1005007913580606.html
  11. #40496
    Hello,
    Francis.
    Hi, very nice test bench, thanks for this picture.
    I wanted to make it as simple and fast as possible, so I chose wooden shields.
    Bought a set including the motor and control unit five years ago from ebay.
    This is CNC spindle air cooling motor, diameter is 65mm 1.5 kw, shaft thickness 14mm, colet ER11,
    Control unit HY01D523B 1.5 kw.
    Another possible 1.5 kw engine is 80 mm in diameter and shaft thickness 19mm, colet ER16
    Made this bench only this winter and didn't think it would be so helpful. I immediately identified several ignition errors that I could not understand when trying before, directly on a motorcycle.
    https://www.ebay.co.uk/itm/256177930...%2C5kw&itmmeta
    https://www.ebay.co.uk/itm/115617328...parms=amclksrc
    https://www.ebay.co.uk/itm/405780924...%2C5kw&itmmeta
    https://www.ebay.com/itm/355838255230?_trkparms
    Robert.
Name:	Rotor adapter.jpg
  12. #40497
    My ignition dyno I built 25 years ago - it uses an industrial vacuum cleaner motor with a simple AC lamp brightness control that
    usually gets mounted on the wall with a light switch. The light switch changes the field coil polarity to reverse the rotation.
    Works perfectly from about 100 rpm to 20,000 with a 2:1 cogged belt and pulleys.
    I mount it on a bench next to the dyno and use the spark triggered signal to generate rpm data , and used to use a VHS video camera to plot the
    angle/rpm on a large protractor on the shaft.
  13. #40498
    1987 SUZUKI 500RG
    France
    Thank you all.
    Regards,
    Francis.
  14. #40499
    1971 suzuki T350R
    the best island
    Grounding Question
    OK, I have some CAT 5 cable on the way to me. Now to made absolutely sure I have understood you properly do you mean the common ground or the sensor ground for the cable grounding? that all Ignatech's seem to have?
  15. #40500
    Yes , and no ,the outer aluminum cable shield is grounded to the supply battery earth only at one end. The trigger grounds go to the separated trigger earth pins , that
    have their own isolation circuitry .
    I also used the same Cat 5 cable wire pairs for the servo and PJ wiring, as these also can inject ignition noise into the sensitive input pins.
    Twisted signal pairs form a very high natural rejection of this power supply line " noise " that seems to be more of an issue with the P4 units having 4 CDI packed into the same box format.
    But as I said , if the coil drive wiring is physically separated, and resistor plugs/caps are used , then any noise issues are largely eliminated.
    The other audio amp trick of creating a common single earth ground point for the coils/case/battery and ECU power supply also eliminates circulating noisy voltage sources from affecting the super sensitive
    ignition chip supply.
